well i havent had much breathing space these days and heres why....I am opening a new crash repair shop for motorcycles(altho i will still be doing all sorts of car related work) and have moved into a place in tullamarine when i have been working around the clock playing bob the builder,heres some pics of what i been playing with....first i made various benchs for preparation(water rubbing ect)you can see the mother of all stainless rubbing down bench :) Then i started building our spray booth/bake oven...Now these units are quite an expensive jigger(around the 60k mark new) so we decided to build our own....first we bolt down some channel for the wall sheets to ride in then build an elevated floor,the idea behind this is to have a grated floor with filters and an airtight chamber underneath it with a suction fan to expel the fumes/overspray from the booth(the booth is actually pressurised by the incoming air fan being a greater cfm rating than the one under the floor) next is the crossmembers are being fabricated.After thats sorted out we start assembling the walls and mark out our doorways then dismantle it again and cut them out and reassemble it again using the corner channel...then we cut our door jamb material out with mitre cuts to make the nice and neat(these things really mess with your brain!!)the waste that has been cut out from the doorway becomes our door after the apropriate alloy coving has been mitre'd and fitted....you can see the two alloy front access doors into the spray area then the other door on the left of them leads into a baking room and the one on the right leads into the paint room there is a door leading from the paint room into the spray area then another door leading into the baking oven from the spray area....so this is the system....parts get loaded in via the two front alloy doors,doors get closedand then you enter the paint room to prepare your materials,you then enter the spray area and do the job where is lies for 15minutes while you clean your gun up,then you re-enter the booth and shift the parts into the bake oven where they get cooked....while there getting cooked a new job is getting loaded up,saving down time in waiting for baking,the baked parts can be accessed via the front alloy door at any time...I still have to construct the roof which will cantain inlet filters and lights ect...I would like to say thanks to adzmax and ocean who have come down and lent a hand....it was very much appreciated :D so for those that have been waiting to bring jobs in...now you know what the delay is!(And thanks for being patient!)
https://www.sau.com.au/forums/topic/74957-my-latest-project/
Hats off to you. Looks like a lot of effourt went into that work shop. If you ever need a site forman for your next project let me know, I'm great and drinking beer and shouting orders from the sides. I dont want to get these fingernails dirty, you know how it is...ay adzmax
Hey Troy, is this booth just for painting parts or can u fit a car in there too???
the booth is 6m x 3600 but has a divider wall that breaks 1.5m off the end for the bake room.......the spray room will be heated by a dirty great big truck radiator with a pump circulating water from a hot water service the radiator will be shoved in front of the inlet fan(this design is pat pending :D) the doors on the booth are too small for cars and i i delibratly made the booth too small(coz of the divider wall) for cars ......There is just no money in car stuff as the ratio of people that actually want a good quality job as opposed to people that want to pinch a penny is just far too small....My mate in the next street has a large size booth that i use if i need to paint full cars....my main target will be motorcycle parts and i can also do hanging panels from cars if i need to
Troy no wonder you'd gone all quiet. Good luck with it all, and as always, if you need a hand I've got a pair to lend.
As he pours in a Sprinter and miscellaneous parts to fill your nice workshop.
Good luck Troy, I hope it does well.
They're housed in a very nice workshop already geoff :D
Been meaning to pick tory's brains about some mikuni sidedrafts though, seeing as he's a motorcylce nut.
They're housed in a very nice workshop already geoff :(
Slide throttles are the answer, off a motobyke, but Troy will be your man.
Looks good...quick question what material have you used for the booth's walls?
Looks like it may be Expanded Polystyrene (EPS Panel) If so you may want to check with the building's insurer as they have been giving the occasional small operator a bit of grief over the fire ratings of these walls, especially when they have electrical conduit concealed in them or fastened to them:(
Dunno about that.
There was one door where the mitre cuts were kinda dodgy. :kick:
hahahaha i though he dun well....at least the angles were correct...anyway i am thankful it at least fitted as here was one stage where i looked over and he was scratching his head and the peice of material had that many lines marked on it it looked like a roadmap :P....oh and i have a peice of scrap metal here with eagle shit welds on it :kick: :) And roy the room is made of bondor paneling....my insurance company came in while i was building it,they thought it was and engineering feat :P, they loved it :(
    • Rear doors central locking wiring removed and cleaned. See the first 8sec video of when it鈥檚 filled with river silt. its a snip of what I鈥檓 up against. front and rear doors complete now. Maybe another day removing carpet and bits and pieces. Then the re assembly begins. 馃 att.DqweJqhY5MZiZYQDVMhn3LtvdD1RBZ7TBG4f2s7W1zM.mp4 att.lFuN22MZEowqCbFAXoDw009r2gHL76ChMVfxMfBX-uk.mp4
    • There aren't boost creep issues, it's not engineered around the restriction of the cats but if you haven't tuned the engine a full decat + exhaust can flow enough air to run off the end of the OEM load scales and you will get a pretty substantial reduction in ignition timing as a result. I recommend using DFCO, avoiding ignition cut limiters, and avoiding popcorn tunes along with running a cat unless you enjoy a perpetually soot-covered and potentially burnt bumper.
    • Small update, it's been slow moving over the Christmas period with money having to go everywhere thats not my car 馃槄. I got myself a little present to myself from "santa" in the form of some tidy radiator mounts from fitmint automotive to get rid of the stock ones that look like they have been in an accident before and then straightened by a caveman. I know I should've replaced the rubber bush at the same time but I had no idea how bad they were until I was replacing the mounts. Decided to order their dash mat while I was at it as I feel like I am lucky enough to have a pretty decent condition dash and I don't want to risk it being ruined while it's parked in the aussie sun while I'm at work. I have found another electrical fault to add to the evergrowing list to eventually chase down. Every time I replace my taillight globe it blows within a day of use, I'm starting to think my life would be easier if I took a few minutes to learn how to use  a multimeter 馃槀.   Had some luck with finding a series 2 drivers headlight on marketplace to replace my mismatched series 1 headlight, a subtle difference but it's nice to have a matching set of lights now.   I returned to the air con problem due to being sick of this summer heat, found a good condition condenser to replace my leaking one! I got it in the car and was happy when I got the thumbs up that the system was now holding gas. Sadly the compressor is not kicking in for some reason, we even tried branching the relay in the fuse box. I have tried to do some research on the issue with no clear understanding of what the fix is, so for now it will be placed on the backburner until I can be bothered to look into the wiring to the compressor. The last small mods I have done was cutting the horizontal vents out of the front bar, not really in a functional airflow sense but I just think it looks better as I am not a fan of the series 2 bar. I also switched the shift knob out for a hosoboyo aluminium grex style one, it has a really nice more direct driving feel than the outdated rubbery oem one. Thirdly, I chucked on one of the ebay bonnet strut kits. The fitment is decent and they seem to work fairly well. They have only given out once while the car was parked facing downhill, I think if I was working under the bonnet I would still put the oem hood stay up to be precautionary as to avoid getting a speedy concussion.
    • Got pneumonia, haven鈥檛 played with her in a while, but I鈥檓 back now. Previous owners cut bonnet pins into the bonnet. My choice try find a replacement or spend $15 get some pins myself to cover up. Now only one small hole to cover. looks shit now, but when the bonnet is red again. Be good 馃
    • No R32 GTSt had 15" wheels. 205/55-16 was standard GTSt fare. 4.36:1 is standard R32 turbo auto diff. I think the manual was too, not 4.11. 4.11 and 4.08 were R33 namual and auto respectively.
