  • Replies 84
Faxed the form on Wednesday afternoon. The fax at work has been playing up so let me know if it didn't come through.
I deposit the money today. If you want a copy of the deposit slip let me know and i'll scan it and send it.
Should be a great weekend. Is anyone doing the Maserati day as well?
Might enter Deca on Saturday, and race winton on Sunday...
Anybody else attending the deca day going to race on Sunday?? Snowy?? Chris?? Anybody????
Don't know about show off, Haven't done track work before and in a new car after being used to driving Rex's.... hmmm, could be interesting LOL. Looking forward to it though!! Maybe I can learn from you Snowy, if there is a video camera around I'll try that pose you did on that DVD! :jump:
B :evil:
I think Crazy Tony is doing both mate. And I'm pretty sure Marcus is doing Winton - but he's not doing DECA at this stage.
Personally I'm booked for 3 days at Winton in July so I'm giving the Maserati Day a miss. Plus is so expensive to run with those guys IMO. Their price is a bit rich for Winton.
I've paid up, but yet to fax the forms etc.
Originally went to common wealth for some silly reason trying to direct deposit, but the lady said it wasnt theirs, and would take a week to process. (week? must be worse case, figured overnight).
So walked up to westpak, and filled in the forms. Then she said i couldnt put DEC-name; they can only do numbers, so put me membership numbers. whats up with that? i always tell people at work to put their invoice number on deposit slips. grr.
So anyway, just got sort out if im coming down friday night.
Jarrod I got yours.
Anthony duely noted.
Ryan - good stuff. We need to get your driving skills increased so you can give Ant a run at the track days. You got the closest anyone had go so far this year at Sandown!
Current list of SAU entries I have recieved.
Andrew Richmond
Chris Thomson
Peter Blyth
Phillip Karski
Tom Giordano
Adam Webb
Nick Edlin
Shan Moorthy
Gareth Rowell
Craig Moor
Ben Lippa
Denham Melder
Geoff Williams
Jarrod Moore
Anthony Nowlan
Ryan Bell
Nigel Beale
And there are now 16 spots left.
:stupid:
not to be pedantic, hehe, but looking at the times from sandown it says i got a 1,37.6 as my fastest, but actually got a 1,36.7.. its no 1,22 but i thought id point it out. heh. i love a bit of competition! cant wait till deca!!
Guest
    • A lot of what you said there are fair observations and part of why I made that list, to make some of these things (like no advantage between the GSeries and GSeries II at PR2.4 in a lot of cases) however I'm not fully convinced by other comments.  One thing to bare in mind is that compressor flow maps are talking about MASS flow, in terms of the compressor side you shouldn't end up running more or less airflow vs another compressor map for the same advertised flow if all external environmental conditions are equivalent if the compressor efficiency is lower as that advertised mass flow takes that into consideration.   Once the intercooler becomes involved the in-plenum air temperature shouldn't be that different, either... the main thing that is likely to affect the end power is the final exhaust manifold pressure - which *WILL* go up when you run out of compressor efficiency when you run off the map earlier on the original G-Series versus G-Series II as you need to keep the gate shut to achieve similar airflow.    Also, how do you figure response based off surge line?  I've seen people claim that as an absolute fact before but am pretty sure I've seen compressors with worse surge lines actually "stand up" faster (and ironically be more likely to surge), I'm not super convinced - it's really a thing we won't easily be able to determine until people start using them.     There are some things on the maps that actually make me wonder if there is a chance that they may respond no worse... if not BETTER?!  which brings me to your next point... Why G2 have lower max rpm?  Really good question and I've been wondering about this too.  The maximum speed *AND* the compressor maps both look like what I'd normally expect if Garrett had extended the exducers out, but they claim the same inducer and exducer size for the whole range.   If you compare the speed lines between any G and G2 version the G2 speed lines support higher flow for the same compressor speed, kinda giving a pretty clear "better at pumping more air for the same speed" impression. Presumably the exducer includes any extended tip design instead of just the backplate, but nonetheless I'd love to see good pics/measurements of the G2 compressors as everything kinda points to something different about the exducer - specifically that it must be further out from the centerline, which means a lower rpm for the same max tip speed and often also results in higher pressure ratio efficiency, narrower maps, and often actually can result in better spool vs a smaller exducer for the same inducer size... no doubt partly due to the above phenomenon of needing less turbine speed to achieve the same airflow when using a smaller trim. Not sure if this is just camera angle or what, but this kinda looks interesting on the G35 990 compressor tips: Very interested to see what happens when people start testing these, and if we start getting more details about what's different.
