-Installed a JL Audio sub (10") a few months ago, since the day I installed it I haven't driven the car. Went to start the car yesterday and it was flat as a tack. I've previously left the car for similar periods of time and never had a problem. Just wondering if I've done something wrong? The amp is an audison not sure which model, it had outputs for a sub - simply marked + and - . Obviously I ran cable from these to the red and back terminals on the sub. Cable is fairly heavy, not sure what gauge etc, but thick enough that you could only just fit it into the terminals on the sub. Any clues?
Thankyou
https://www.sau.com.au/forums/topic/75067-can-a-sub-drain-the-battery/
Try not to do that, put a ammeter across it... Spikes are painful, and I have seen them blow up a regulator on an altenator.
Sparks are how the bush mechanics go about things.... :D
Cheers
Sumo
I won't argue about the bush mechanics - however I've never seen it blow anything up though and it happens to me everytime I re-plug my battery up so I didn't think it could blow anything up. I'd actually be interested to hear bout the theory of how it would (not doubting you, just wondering).
Multimeter is the preferred method but not everyone has em.
The alarm could be it but alarms usually tend to draw very, very little
How long was it since you started it last? I know you said you have left it a similar time period before, however you should start (and drive...not just let it idle) your car ATLEAST once a week. If you have a bigger/smaller battery than standard you may need to do it more or less often.
I have had a battery last 6 months off a car, and still crank the car, but the same battery 2 weeks later (also been off the car) was dead as. They don't seem to be a sure thing.
The amp would only effect it if either 1) it was faulty or 2) you wired it wrong, but since you say it turns off with ignition, 2 is not the case. So that leaves the amp is faulty, or the battery is..or there is something else in your system that is draining it.
Grab a mulit meter and see if there is any power on the remote lead, at the amp, while the car is off.
I have seen blokes checking for drains by pulling fuses and running the lead across the battery terminal. What turned out to be a faulty boot light switch also resulted in his Bosch RE60 regulator giving up the ghost. Coincidental, possibly - but there must be a reason the NSW government puts it in the auto electrical sylibus. We have not gone into ECU's yet (still in 2nd year). But a good way to set off airbags is too give them a nice spike. They also should be able to go off 15 seconds later after the power source is removed (by law - safety feature).
CC also i forgot to mention, if you have a faulty cell in a lead acid battery that is bubbling.... Leave it too your imagination on the resulting explosion - I have seen what batteries do when they explode, although it has never happend to me - but my boss copped one (disconnecting a battery charger). He got drug out and layed under the tap for 15 mins then they took him to the docs.
Cheers
Sumo
    • Really? That's piss weak. I didn't know they hobbled the shitboxen that badly. OK. So probs need to buy a flywheel too. But that's not too bad.
    • Hi all. I already posted some newbie-ish questions here and there but this will be my first "big" post. Last summer I went and fulfilled a kind of childhood wish, because I just thought I needed this experience in my life no matter what. The car I bought is a mildly modded 1995 BCNR33 Vspec. It was repainted to a metallic orange color all around and it had all windows reseated. Not so well done black respray in the trunk and a metallic black in the engine bay. From outside it looks very nice except for a minor paint error on the roof and the rear spats needing new adhesive tape. The inside is pretty clean and no broken plastics, missing or faded buttons. Even the adjustable mirrors and trunk antenna work like a charm. Despite a moderately long list of issues I don't (yet) regret buying this car. Most mechanical problems are just due to age, like worn rubbers here and there. The underside sadly has lots of corrosion, especially to the back. It looks like it either has been driven in the winter for a while or it lived near the saltwater in Japan, the rust is nothing terrible but it'll require to be looked after. Mostly panel gaps and all the mounted components underneath are a bit crusty, but I don't think anywhere has progressed so badly that there's going to be holes. Front right jacking rail is crushed and needs some care so it doesn't develop into a rust crater at some point. Worst part is definitely the strut towers. I thought they looked fine but after taking off the strut bar I noticed that it actually started bulging up on the passenger side. Probably would have passed on the car or negotiated down by some thousand Euros more if I had noticed this before buying, but here we are. Trunk area also has signs that there was a water leak to the interior once but nothing too crazy, I guess lots of Skylines had this at some point. As for the list of (known) issues, I'll try to make this compact. I hope the coloring is self explanatory. Mechanical: -Various busted or soon-to-be busted rubber bushings and ball joints. Will replace ball joints with OEM or better and bushings with polyurethane where possible. -Shaking steering wheel at above 80kph -downshift from 5th to 4th is a bit crunchy unless I rev-match, might just try to renew the shifter assembly, but it's not a priority issue -tailshaft centre bearing could use a replacement, is it worth going 1-piece tailshaft as it doesn't look too fresh all around? Chassis: -underbody corrosion on many spots and in hollow spaces, needs to be treated -corrosion on many bolts, hoses, lines, suspension components, subframes, will be treated when replacing of the bushings is needed as time goes on -strut tower top panels and some of the surrounding panels are rusty, so needs fixing. Will look into doing this with a buddy in the winter, otherwise bite the bullet and pay a professional -driver side door is misaligned to the body and needs to go a slight bit more inwards -both door windows are misaligned and have an airgap where the window meets the door at the B pillar -The Aerocatch latches for the bonnet have locks but no keys, need new keys. -driver side door window is kind of gritty and could use a polish -damaged jacking rails and front frame rails, from people lifting the car the wrong way, might have this fixed by a bodyshop Electrical: -Nismo tachometer is just bouncing and displaying nonsense, supposedly worked fine when the stock ECU was still in the car -An old Greddy boost controller sits on the dash which will be removed as it servers no purpose anymore. -a led segment rpm gauge is on the steering column, will probably also be (re-)moved once the Nismo tacho is working correctly -there was an attempt to make the sound system better by the previous owner but it was just inducing noise all the time, ripped out the amp and filters in the back, no music for now -trunk antenna goes up as long as the radio is on regardless of the mode, I want it to only rise if I choose Radio specifically or per switch -3rd brake light is a bit dimmer than the taillights but everything was converted to LEDs so mabye now it just seems dimmer? -reverse light flickers, have to test if that behavior changes when I fiddle with the gear stick. Hope I can get around changing the switch. -Left side taillight, blinker section has minor water intake and is humid after washing. Other side has a hole in it, probably for that exact reason. I'll probably reseal them entirely and plug the holes. Engine: -minor coolant drips on one or the other hose -rear turbo leaks oil onto the exhaust making the car essentially undriveable due to fire hazard -Oil filter relocation kit has an oil drip at the Dash lines, will probably make a new connection there and tighten real good and pray -throttle body assembly is slightly stuck for the first throttle pedal input after sitting for a while I'm always open to suggestions and advice from more experienced people, I'm sure half of this list is easily dealt with and just requires some time and effort to sort out properly. Once I have some proper pictures of the car I will post some in this thread, I just have to remember to take some more once I get the chance to. Will post updates when I have news on anything, I want to try to keep this thread as kind of a logbook as well. Ultimately my goal for this car is to just enjoy it. An engine rebuild is probably going to happen sometime as well, because it is old after all. It will never be fully new again, I am just not that rich. But I want it to look good, work well and not rot away while I drive it. I'm probably gonna spend a lot of money on this journey, hopefully not an unreasonable amount.
    • Hi all. So one of my major issues at the moment is my rear turbo leaking oil on the exhaust (and the general area). I presumed it was the rock hard super old drain hose, which it was not. So now I am in the midst of removing the rear turbo to get access to the banjo bolt that goes into the turbo oil feed. As one of the previous owners accidentally? tore off the OEM oil feed hardline that reaches behind the turbo, they ran braided lines directly to the turbo, presumably PTFE. Now, regardless if the line has rubber or teflon inside, is it just generally a bad idea to do this? I imagine these lines get quite hot being between the engine, turbo core and exhaust manifold. I suppose it's not too far fetched to think the line may even have melted. I'd love to hear your opinions on this as as the replacement OEM hardline piece is 130 per unit. And cutting open the currently mounted line to see inside will mean I just have to get a replacement either way. So far I am hoping maybe the bolt just loosened or (god forbid) they forgot one of the crush washers.
    • If it's a factory 20de manual probably has the 6 bolt flywheel in which case the det clutches won't work as they're 9 bolt.
    • All RB push clutches are interchangeable. AFAIK, the 4cyl ones are not. Different flywheels. The RB small box is not identical to the 4cyl boxes. Just very similar.
