got my N-1 oil pump yesterday and took it apart to compare to my std R32 GTR oil pump...(2 screws worked loose as they do )
here are the differences for interest sake:
1: the relief spring
std has a twin spring system N-1 has a single...both measured identical spring rates at 3 different heights starting from the installed height.
Interestingly the N-1 relief plunger has a small oil hole drilling about 8mm down from the top edge, level with the relief oil passage in the pump housing. This would have a dampening effect on the way the relief valve works as the spring cavity would have a head of oil in it that would have to squeeze out the small oil drilling first.
Plunger size was the same and relief valve cavity was the same.
2: the oil pump gears are where the biggest difference lies.
The N-1 inner gear has 1 less lobe (11) vs the std which has 12...this allows the internal volume of the pump gears to increase using a redesigned shape on the outer gear/inner gear meeting surfaces. We didn't CC the difference as the N-1 was obviously much larger than the Std R32 gear.
3: The gear hardness and material...
a hardness test was performed using a proper hardness tester in the machine shop. The std gears were a 0.56 and the N-1 scored a 0.96 a marked difference!
Also the gears were made out of the same material!! Sintered steel.
The major reason , I believe , that the N-1 gears have been hardened is that in order to increase the pumping volume the outer gear wall thickness has been dramatically reduced thus hardening is required to keep the strength up.
4:Internal channels are all larger in the pump housing and redesigned to increase flow
5: the pump backing plate has a redesigned screw fixing arrangment with an extra screw on the N-1 ( 8 screws vs 7 in the std ) Also the backing plate is 0.5mm thicker ( 6.5mm on the N-1 vs 6mm on the std )
A note worth noting :D the backing plate screws were not lock tighted, needless to say that they where during reassembly!!!
Cheers Mike
https://www.sau.com.au/forums/topic/75069-n-1-vs-std-oil-pump/
Good stuff. I had been led to believe the N1 was just a higher spring rate on the relief so it's good to see some testing.
What I have confirmed from FAST is that the RB25DET and RB26DETT oil pumps flow exactly the same amount, but it doesn't detail any defferences in construction, so to all intents it is the same pump. I can't recall if the part number was different.
$850 NZ.
The Rb25 and the R32 GTR pump are indeed the same. We also happened to have one off a dead Rb25 and compared the two.
Interesting how the relief spring have the same spring rates eh?
Isn't the HKS pump worth a small fortune ??
Mike
    • Stock ECU (or more accurately stock tune) absolutely refuses to go over 10psi and behaves like you have seen. The Nistune is the same if it is the stock tune. If the Nistune chip has been tuned, the resulting tune could be literally anything for any combination of parts. The Nistune just makes the stock ECU Tunable.
    • So stock ECU does not like anything above 10 psi?  That Nistune one is just for "try" if it will be any different, I know it need to be tune for that. I know but YOU may know about these problem but i/we dont. They few little Skylines here let alone people who know anything about tham so that is why iam asking here
    • So now we have a radiator with no attachments whatsoever. It lifts up with a particularly tight spot between the drivers side air box mount and the lower radiator outlet, but if you've got this far you will sort that too. This is the lower mounts with the rad out so you can see where the rubber bushes go, it is a straight shot upwards Done! Assembly is the reverse of disassembly, with blood less likely to be shed.
    • Right, onto the second last trick. The Air Con condenser is mounted to the front of the radiator and stays in the car when the radiator is removed. There are 2x 10mm headed self tappers holding the top of the condenser to the radiator, remove those The bottom of the condenser is attached to the radiator with clips. You need to lift the condenser out of those clips and clear (up, then forward). f**ked if  could work out how to do that last bit with the front bumper on. I hope you can, and you share the trick.  Bumper removal probably deserves its own thread one day once I've recovered the will to live, but basically you need to remove the wheels, front inner guard liners (clips and 10mm headed bolts), the self tapper between the guard and the bumper at the rearmost point of the bumper (same as an R32 that bit), any remaining clips at the top/front of the grill, an absolute bastard design with a plate that holds the top of the bumper above the headlight each side (only 1 bolt which is tricky to get to, but the plate catches 2 places on the bumper and must be removed....carefully!) and push clips between the bumper and guard under the headlight. If you've done all that you will be faced with wiring for the fog lights on both sides and in ADM Q50 RS at least, 4 nasty tight plugs on the driver's side for the ADAS stuff. So, the clips at the bottom look like this on drivers side (looking from the front) And on the passenger side (also from the front), you can see this one is already out Clearance on both of these are super tight; the condenser needs to move up but the upper rad support mount prevents that, and the radiator can't move down far because it is (rubber) mounted. Once you achieve the impossible and drop the condenser off those mounts so it does not stop the rad moving, you are good to go
    • OK, next the shroud needs to come off and there are a couple of tricks. Firstly, there is a loom from near the passenger side headlight to the fans, coolant temp sensor etc and there is no plug to undo.  In my case I was OK to leave the shroud on top of the engine so I just undid the passenger side fan plug and about 10 of the clips which gave enough free wire to put it aside. The fan plugs were super tight, the trick I used was a small falt screwdriver to push down on the release tab, then a larger flat screwdriver to lever the plug out of the fan unit....be careful with how much force you apply! If you need to remove the shroud altogether for some reason you will have to deal with all the plugs (tight) and clips (brittle)....good luck. I removed all of the clips and replaced them with cable ties that I will just cut next time. Also, in the Red Sport / 400R at least, the intake heat exchanger reservoir hose is bolted to the shroud in 2 places with 10mm headed bolts; so remove them (the hose stays in the car; no need to undo it at the t fittings down at the radiator lower mount. Once you've dealt with the HX hose and the wiring loom, there are 3x 10mm headed self tappers holding the top of the shroud to the radiator; remove those.   The shroud then lifts out of the bottom mounts where it sits on the radiator, up and onto the engine out of the way. Simples
