Here goes
1996 Series 2 Nissan Skyline - white
Dual airbags
Full Electrics
Digital Climate Control and aircon
96,000km's
5 speed Manual
Exterior
Carbon Fibre vented bonnet
Nismo 400r sideskirts
Stealth spoiler
Nismo clear indicators
Tinted windows
Engine
HKS 3.75" Super Dragger catback exhaust system
3" Dump pipe
HiFlow cat
Apexi Power Intake Pod Filter
Blitz LM Intercooler
New Bosch 040 fuel pump
GFB bleed valve running 10 pounds
Greddy Oil cap
Heavy duty timing belt
New NGK Platinum plugs
New Motul Engine Oil
Driveline and Suspension
17 inch Blest Rims - plenty of dish
New rear tyres
Brand New Exedy H/Duty clutch
Slotted front rotors
Slotted rear rotors
Brand New japanese 'Project u' 0-800degrees racing brake pads
KYB street shocks and springs
Cusco front strut brace
Rear strut brace
New Motul Gearbox oil
Interior
Razo shift knob
New Autometer boost guage
Oil Pressure guage
Oil temp guage
Water temp guage
Dual A - Pillar guage holder
Kenwood Double-Din Cd player
Many more extra's....
Has been run at 10psi max. Serviced every 3000km's with motul oils and high performance oil filters. Timing belt has been changed 1000 km's ago. Never had any mechanical problems and the car mechanically is very sound. A couple weeks ago at some cost, the new clutch kit was installed along with new NGK spark plugs , brake pads (as mentioned),engine/brake/gearbox/diff fluids. The timing belt was replaced 2000 km's ago. The car was dynoed at 145rwk when it only had the exhaust and airfilter, running only 6psi! So it is a very healthy engine.
There is a bit of dash wear under the gauges and there is a slight exhaust gasket leak(doesnt affect power at all), which i will get fixed if sold for 20 or more.
20,000 firm. It is in the trading post for 22,000 ono
https://www.sau.com.au/forums/topic/75076-series-2-skyline-modded-cheap/
  • 4 weeks later...
hey,
is your car still for sale? im not a tyre kicker i am genuinely interested....although i live in nsw.
where abouts in vic are you? is it possible to send anymore pics? if so could you please send them to.... [email protected]
thanks,
curtis
    • I know right. It baffled me. There's no way when the engine is off, key is in ignition, (coils are dissconnected aswell), also my sound system was dissconnected (I don't run any audio capacitors), battery reads 12.2v and with the 10amp fuse blown I was measuring 24 to 30v. The reading would move a bit from 30v to 24v which was weird. I took a pic of the multi meter reading 🤣: (This is a brand new single channel digital oscilloscope that also has a multi meter mode).   Before when the fuse was blown, I had one lead on the 12v supply (green/white wires) of that brown relay and the other lead on the negative battery terminal. When I turned the key on ignition (engine off), it would read 30v. Then when I removed that relay from it's plug and tried putting ignition on again, it would read 12v, but I think it's because it can't turn on the ecu now that I removed it. I asked Chatgpt and this is what it had to say:   Not sure if those theories would be possible but, any auto sparkies here? welcome to confirm. 🤷‍♂️  No idea, but if it happens again, atleast I know what type of issue it is, unlike last few months where I didn't know what was causing all my issues and I was just taking stabs in the dark to figure out what type of problem it was. If it does happen again I'm going to investigate futher and trace back the source even more and inspect more circuits. I drove it to work this morning and the car drove and boosted fine. Yeah I was thinking the same, so I've imported my back up saved map (which is the map that I saved when it got done tuning) back onto my haltech with the base fuel pressure set to 43.5psi.
    • Yeh nice, if your in melbourne could you recommend any exhaust shops in the east that do a good job?
    • Sorry yes, this is what im after Also, that jpjdm site appears to be offline
    • @Duncan Random side note, did the cops give you the driver/owners details of the taxi and then did Shannons give you a refund of the excess once you supplied those details?
    • Yeah to be clear I'm not naive, I'm sure all insurance companies are a bunch of arseholes who pay people bonusses based on the value of genuine claims they avoid....I just don't want to go back to one that has personally f**ked me multiple times in the past
