Hey riggaP, what could be some possible causes of a low mph. I'm kinda suspecting that my boost may not have been getting to 12psi in higher gears. Could this be the problem?
:rofl:
Do you have any aftermarket engine management? If not it could be too much boost. The stock 33 ECU dumps shitloads of fuel when you start running more than 10psi. A piggy back is probably the way to go (ie SAFC etc). You should get more out of the coola too.
that was the 1st time i ran my car on the qtr mile and i got a best time of 13.8..
mods i have are: hks pod, exhaust (stock dump pipe), adj damping on rear suspension which i dont know what brand it is....
i ran with 225/50/r16 silverstones at 20psi at the back
and i need a new clutch to get better launches
Not a bad time for the mods. What 60' and mph where you pulling?
Hey guys
Thanks to all who attended the event (both competitors and spectators).
Pics from the event can be found on mazdarotary.net now as well:
http://mazdarotary.net/nisdatdragchal0501.htm
and also fullboost.com.au
Cheers!
i'll type out the time slip just cos i cant scan it at the moment
(im on the right btw)
Reaction Time: 0.9781; 0.7493* (time diff 0.2288)
60ft: 2.3315; 2.4162* (time diff 0.1441)
330ft: 5.9634*; 6.2632 (time diff 0.0710)
660ft: 8.9389*; 9.1797 (time diff 0.0120)
660ft mph: 84.76; 82.57
1000ft: 11.4674*; 12.7623 (time diff 1.0661)
ET: 13.5786*; 13.8082 (time diff 0.0008)
MPH: 107.71; Error
NB. * denotes leader
yeah well i didnt get a trap speed, and u can see the big jump between 660ft and 1000ft in the time differential, i thought itd be due to the stuffing up my 2nd to 3rd gear changes....
is the elapsed time wrong? if i didnt engage 3rd gear, that means my car would be roughly doing 100kph when it was time to go into 3rd, which i think wouldve ocurred between the 330ft and 660ft mark, but at the 660ft mark theres only 0.012sec diff
ah coool should be good!!
That last run pissed me off so much cos I had to race in the right lane - there was no bloody traction down that side, then after my tyre warmup they made us wait for so long - tyres got cool and just didnt hook up at all.
    • Sorry Duncan, I didn't get a notification for the replies.  Thanks for responding!  It's a full Android device, but does allow you to use CarPlay/AA as well.  This is the one I bought from NaviRS on AliExpress: https://www.aliexpress.com/item/1005006368602668.html?spm=a2g0o.order_list.order_list_main.111.59aa1802JDzQ0E - the 2K 8G-256G CAM variant but it seems to have gone up by £170 since I bought it!  My purchase was £307.14.   It's not the fastest thing in the world but performs perfectly adequately.  It stays on standby unless I disconnect the battery and let it power down, then it's just a fairly standard Android bootup time from cold.  The DSP Equaliser is very nice and made the standard stereo system sound pretty decent compared to the stock screen.  Perhaps I can take a video of it when I get a sec. It *allegedly* supports the reverse camera, but I'm yet to get that working.  It has options for reverse cam (a camera unit can be bought separately) or 360 cameras (also bought separately).  To be fair it doesn't seem to detect that the shifter was put into reverse but I'm working on a theory about this as well.  At the moment I'm going without which is a bit annoying considering the car is an absolute canal barge but so far I haven't caused any damage I'll grab a picture of the wire I'm missing later today when I can get outside.  My theory, by the by, is that not only is the head unit different, but the CANBUS network has different signals for the different years.  I think this because I have a spare AC panel from a newer Infiniti G37 (as opposed to my Nissan panel) which wouldn't control anything except the volume when I had it wired up with the stock system.  I'm going to throw it back in and see if the screen will respond to it.  I've just ordered an arduino CANBUS module so I can have a look at the signals going around the car and see if I can spot anything.  I'm thinking if I can work out what it's expecting vs what it's getting I might be able to translate and relay the signal back but so far just a theory anyway. I also found this on my travels, so far the only one that specifically matches my car: https://www.aliexpress.com/item/1005002822934280.html?spm=a2g0s.imconversation.0.0.33433e5fgttovi If you look at the picture of the before, it has the card reader slot, and the picture of the head unit is exactly the same as the one pictured in my original post.  I asked if they sell the cables separately but sadly they won't.  I didn't want to just buy this one because it's a super old Android version and only dual core - likely slow as hell.
    • To be fair - you see the same thing for every clutch. There's always someone making an installation error.
