hi guys,
got 231awkw @ 1.1 bar with PowerFC on the dyno yesterday. Happy with the results but not happy that the laptop (datalogit) and ITC shows KNOCK value = 1. Tuner said that the knock sensor might be disconnected and the reading will be a constant "1" regardless whether the engine's pinging or not. He had to use a oscillascope (sp) to listen in for any pinging/knocking during the tuning and 231kw was supposely a safe tune for me :cheers:
i have been reading through the rb26 user manual and tried locating the knock sensor but to no avail. Any of you guys know where the sensor is located?
thanks in advance.
https://www.sau.com.au/forums/topic/75139-rb26dett-knock-sensor/
thanks in advance.
There are actually 2 knock sensors on the RB26.
Both are located on the inlet side, under the intake manifold. (approx 3/4 way up the block)
1 is in line with Cyl 2, the other is in line with cyl 5.
They're round & black in colour with a 10mm bolt throgh the centre.
Plug is also black, 2 wire. Projects from the circular sensor @ approx 45deg.
Hope that helps.
Hope that helps.
thanks Adrian. i did try running my hands down the manifold to try feel for it but nothing. I guess i will jack the car up to have a better look from undernealth. It's irritates me to look at the ITC and have the knock value at "1".
Sorry i know its off topic but who tuned your car and what mods do u have.
car is being mod for the occasional trackwork. For the engine department, i have got ARC intercooler with pipings, Trust oil cooler, Trust sump, JUN adj exh/int cam gears, new belts, oil/water pump catch can, crank, twin air pods, avcr and power fc. Induction side, i have R34 GTR turbos pushing a safe 1.1 bar with full turbo-back exhaust system.
Chapmans & Chapmans at Wollongabba did all the engine work/mods for me and Mercury Motorsports did the tuning because they have the datalogit software and also one of SAU_QLD sponsors. Would have preferred Chapmans to do the tune because i have seen some very positive examples of Andrew's work.
Glenn,
Look on the block, just forward of the water~oil heat exchanger where the oil filter mounts, above the front diff... Almost directly above the engine mount bracket, high on the block, hard up against it you should see the sensor (the forward one)
If it's not present, you'll see a raise circular boss where it should be. (With a central thread for the retaining/attaching bolt.
You will probably need a mirror & a torch...
Cheers
Adrian
I had a knock sensor problem as well, seemed a former owner had not liked the reading it gave. So right at the computer they wired the ECU knock sensor input to a constant 0v...so it always read 0.
Anyway, check that first, find the ECU pinouts, follow that wire and make sure it hasnt been fiddled with :rofl:
I couldn't agree more, I hooked it all back up.
My theory is there may have been an "overactive" knock sensor that was sending the ECU into safe mode...and it was easier to cut a wire than to replace the sensors.
After all the knock sensor is just a little microphone
many thanks to Adrian and Duncan.
Spent some time tracing and testing the wires and found out that the connector was dirty. Gave it a good cleaning and woops, my knock sensor is back online :(
went out for a drive and highest knock value registered was '32'. Did some research in here and it seems that anything less than 40 is fine. Will probably give it a good hard drive soon to see if the value goes up any higher.
Correct me if i'm wrong, but i believe the knock sensors do nothing but give a number when connected to a PowerFC.. as unlike the stock ECU the PowerFC does not remove timing etc if it sees knock..
It says this in the manual, also I think says anything under 60 is normally safe. :P
  • 1 month later...
Yeah i am having the same problem. Had the car on the dyno and my tuner said that the knock sensor isnt giving a reading (i also have a PFC and want the numerical reading for further tuning).
I will try and give it a clean out, i thought i needed new ones!
I priced new items from nissan and they quoted $300 each!! I found a wrecker with a half cut who will sell them for $95 each which isnt to bad.
Does anyone know if these sensors usually fail??
    • You've just discovered a really good reason to tell yourself, yes, I do need to buy an aftermarket ECU. Put the MAF in the bin. Slap in the new ECU and have a think about what turbo sounds you prefer.  Do you want a 90's style BOV wooosh? Do you want a hektik tsututututu?  Mate, can't go wrong. Just gotta get that ECU and the world is your oyster.
    • Hi. Iam just curisou about this topic. I saw this video. It is about Greddy Type FV2. I know that BoVs are about that sound but how and when to use it? I read some topic here and from what i have understand on stock RB with MAF there will be some "problems" if you use this BoV? It vents the air in to the atmosphere and the MAF on stock car needs this air back in to the intake and not out? Or is it wrong? If so...i saw you can put some adaptor to circule air back...but does that not "loose" that sound? I saw another BoV from Turbosmart and it has two "exhaust" like ports? One is for the stock tubing for letting air back and one is for "sound" and let the air in the atmosphere? Can someone please explain? This is the Greddy one:  And this is the Turbosmart.     THANK YOU!! EDIT: So i read about this topic some more and i if i understand that correctly: That Greddy can function either like BoV or 100% Bypass valve? And that Turbosmart is what they called hybrid so you can adjust what and how many air can be vented out or back in? Is this right? THX!
    • That dirty voltage drop is the culprit I suspect
    • i cant get them all in 1 screenshot unfortunately as i just dont know how to move things around tbh, but they are all from the same log and the line crosses at the same point for all of them
    • It's about time I start work on my sun tan. So I knocked up a few parts that will all combine together to become my new power steering reservoir. Now just to produce an abundance of UV and IR rays while melting a heap of bits of alu to become one... Well, that's after I put one more hole in it for the return line to plumb to. It likely won't be this weekend, as Sunday I'm meant to be in doing some last minute stuff to the AMG race car, and the weekend after will be filled with non my Skyline stuff, followed by Bathurst 6 hour. So I don't expect to get to melt metal for at least 3 weeks.   I also managed to stuff up and start cutting the hole for the res to pump pipe on the wrong side of the line... It means instead of the lines being nice and tight against the inner guard, they'll be out off the guard.    The size of it means I should end up with about 1.8L of power steering fluid, and still have space for another half a litre before it reaches the overflow/breather. This is wayyyyyyy more capacity than factory, which should help keep Powersteer oil temps lower, and the design hopefully allows it to prevent any aerated oil being able to makes its way down to the bottom as it'll have a couple of baffles and some hopeful trickery to force air bubbles away from the bottom.
