im haivnig problems with boost in my 32 im not sure whats the problem is
in my first gear boost doesnt seem to hit (or very little) when i rev past over 3000
and then in second gear it only seems to go up to 4 psi even wen i pass 4500 revs
but in 3 and 4 it boosts up to the normal 7 psi
i dont understand why ?
i got a r32 gts-t 1992 it was originally an auto car converted into a manual
the cars got about 150,000 km on it.
is the turbo going out ? or is there anohter problem ?
https://www.sau.com.au/forums/topic/75156-problem-with-boost-in-my-32/
not sure how can it be a leak when it can hold boost when im in 3rd and 4th gear
and i bought the car with a auto to manual conversion already.
no i dont hear any ticking noises
except for this weird one wen i got over 100 km i can hear a ticking noise
When I bought my R32 it had a 108kph+ speed alert ding dong thing that could only manage a ticking sound after I wore it out on the freeway.
Just a thought.
I thought RB20's ran 10PSI stock. Unless you have a different turbo or a BC?
are you working off the stock boost gauge or an aftermarket one.
cause the stock one doesn't read PSI.
just a thought.
you still didn't answer if this has always happened since you bought the car or recently.
if this only just started hapening now, have you made any recent changes?
very true 'Cubes' as soon as i put my exhaust system on the boost jumped to 10-11 psi. for the other question about not hitting boost well my best guess is that u might have a leak in ur intercooler pipes, check them all and check the standard bov it might be leaking.
how does putting an exhuast on a car increase its boost ?
If you dont have a boost controller eg. AVCR wouldn't boost still be controlled by the wastegate ?
what is the stock boost on a 32gtst anyway ?, some say 7 some say 10. Im getting an AVCR soon and i want to know what is safe to run. I was thinking 12 psi....
it makes it rise due to less backpressure.
the enemy of a turbo car is backpressure in the exhaust.
having one free flowing gives good gains in many areas
as for manual/auto ECU, that wont make much of a difference
i have a similar problem...
standard my car ran 11psi with a Autometer boost guage...
I noticed that same prob, when boost kicks 2500-3000rpm it feels as if its loosing it, and at about 5k its comes back.. didnt register on the boost guage but..
Hooked up a Turbosmart dual stage boost controller.. and it does the same thing but worse.. 90% of the time it does it... sometime it works and hammers..
Im thinking it has somehting to do with the fuel cut as im running 13-14psi boost...
Bu then again.. it was doin it before i strapped the boost controller..
R32 gts-t run 10-11psi stock
My car was also converted to manual from auto... but didnt have the problem after the conversion..
it doesnt change the spring.
my understanding is (without even bothing to be technical)
By not leting the gas out freely, the turbine cant spin as freely.
If the rear is going no good, the compressor isnt going to go any better either.
So you make the rear work, and the front follows suit and the whole circle goes a lot nicer
    • I just got to work and skimmed through 61508 and 61511. I was surprised the CSA adopted both, but neither are enforced. To recap what I read, it states that in a perfect world, they should be segregated but they acknowledge that this is not industry standard and clearly mention that they allow mixing of safety and non-safety. 61511 also mentions software segregation like AB does in their safety PLC's.   Now if only I could go back to control, let alone safety over comms. In my current line of work, we're only allowed monitoring over comms. Everything critical must still be hard wired.
    • I've unfortunately never been as they're on the complete other side of the continent and another country that isn't currently letting us in as easily as they use to. I even heard their stop signs over there actually say "Stop" instead of "Arret". If I decided to trek the 48h drive, I wouldn't know when or where to stop haha. Whenever I order parts from UP Garage, I order from Japan as it's cheaper. Same with GKTech... oddly enough, it's cheaper shipped from Australia then it is the US.  UP Garage Japan operates their US leg though, unlike Tomei. If Tomei JPN had the power to close down Tomei USA, I'm sure it would be done in a day. They're two completely separate entities. Tomei JPN messed up somewhere originally agreeing to its creation and got sacked big time.
    • I asked someone about this and he told me about the Audi 1.8T engine. But I think it would be difficult to swap
    • I don't know that machine specifically, but I'd personally go for something with a little more kick than 130amp. Around up to 180 would be good. At the 6mm range, you're really pushing the machine hard and don't have a long period you can run for with out needing to give it a rest. Lots of MIG machines come with a regulator and hose. A lot will come with a starter roll of wire too, but it isn't too expensive to buy. I'd recommend NOT buying a massive roll too, as you don't want it sitting around FOREVER in the machine between uses and potentially going to shit. For thin sheet metal, get a roll of 0.6mm if you're doing over 3mm and above, switch over to 0.8mm wire. Even by 2mm you'd probably really want to switch. As for gas battle, it's all swap and go style now. You'll pay a bottle deposit, and then X amount to swap for a full one. I think it's like $200 or $300 for a D Size bottle upfront as "deposit", and like $110 to $150 per swap. My D size CO2/argon bottle lasts a fair bit of welding on the MIG. And I run an E size bottle on the TIG. For DIY MIG, stick with a D size bottle. If you really start to get into a LOT of welding and doing it really regularly, then upgrade. If you're like most DIY car guys, one D bottle will last you 2 or 3 years easily. I think I've been on my current bottle about 5 years. It is starting to get low, but I've been smashing it a lot more the last 6 months.
    • SR20s came with cars like the Bluebird and Primera, but the RB20 never came. The ones in Turkey were either brought in specially or from abroad. That's why RBs aren't as common as SRs. And if a part breaks or I need to replace it when doing maintenance, it's harder to find parts for RBs.
