I still don't understand :cheers:
I can't stop thinking that despite backpressure, the wastegate will not open until there is 10 psi in the system. If it doesn't open, pressure will continue to rise until it reaches 10psi, then the gate opens.
wouldn't backpressure just make it take longer for the turbo to build 10 psi in the system ?
You are right if it is a 10psi actuator that is all you will get. If you free it up it doesn't matter.
Where things differ slightly is with the R33, they have a solenoid that bypasses a certain amount of air. Fitting a bigger intercooler or exhaust can effect the boost you see because there is something else aswell as the actuator controlling boost that depends on the airflow. Standard actuator on the R33 is 4-5psi, once the solenoid opens it bypasses enough air to hold 7-8psi. If you free things up a little you will need to bypass a little more air to hold the same boost. This is why if people fit exhaust or intercooler to an R33 they gain 0.5 to 1psi.
With the R32 I believe it only has an actuator to contol boost so should be same irrespective of exhaust mods etc
THis is how I see it anyway. May be a little incorrect
I still don't understand :D
the actuator "sees" 10psi sooner as there is more pressure.
with less it runs more.
my 17psi gate combo only runs 15psi. Meh, its finer details.
jsut accept that boost will rise :cheers: hehehehe
    • Update: I got the magnet out. I bought 3 different flexible magnetic reach tools, but none of them worked. The magnet on the tip was all less than 2lbs of force, so i had to buy a special cylindrical magnet that had a pull force of 9lbs.  The magnet finally came in the mail yesterday, so i got under the car to get to work. The super strong magnet isn't that long, so i only have about 1 finger pinch lengths to hold it. I was so scared when i was going in the hole, that the 9lb magnet would just fly away inside the oil pan never to be seen again, but i had my butt cheeks clenched and finger gripped on that thing so tight, i managed to get it to suck the other magnet out.  It was a victory for me last night.
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 馃槂
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
