howdy!! I have a R32 GTS T and was out for a drive last night and something was going on with the car. At aroung 4 - 5000 rpm under boost the car just start making a gargling noise out the exhaust and car starts jerking a bit. sorta feels the same as the speed limiter. Just wanna see if anyone has had a simular problem and could help us out at all???? :cheers:
https://www.sau.com.au/forums/topic/75157-miss-under-boost/
Just a quick suggestion that I was informed about. My R33 had a misfire under boost, I figured out it was the coilpacks as I had just changed the plugs, I was told that the coilpacks hae a tendancy to get hot and start to fail when the cover is on, so, I took the plug cover off, and, hey presto....no more misfire :rofl:.
https://www.sau.com.au/forums/topic/75157-miss-under-boost/#findComment-1379310
cheers fellas, i was thinking plugs but thought it was weird that i changed them about 6000 klms ago, and there platnium gold with 100,000 km warranty. So i will check out the coils and give ya the results. CHEERS :wassup:
https://www.sau.com.au/forums/topic/75157-miss-under-boost/#findComment-1382195
    • I have a heap that i have collected if you want some authentic ones still. Pm me if your interested!
    • Hey lads, reviving an old thread.  As an update, since the last time replied to this thread, ive done mostly suspension. Havent touched the motor except for maintenance. Though upon changing spark plugs, found out i had splitfires pre-installed! Updates: - Got me some stock airbox top cover and snorkel to fit onto the original intake. Should be free of defects - Bought a set of R34 GT-T brakes (not installed yet, going to rebuild + respray in champion blue + white 'Nissan' text) - Bought the last set of bilsteins from @Sydneykid and had them installed. Has been making some sounds on the rear but hopefully should be sorted out after this New Year break. - Regreased front caster rod bushings (poly bushes..) - Rear upper camber arms - Whiteline sway bars (BNF27Z 22mm + BNR11XXZ 24mm).  The rear sway bars are a bit short (ive read 50mm else where) but was still able to get them in.  Anyhows, I reckon suspension is sorted now. Maybe replace bushes (do have a set of front upper control arms from SK not installed yet) but should be okay for now. From now, I'm wanting to start working on the motor, drivetrain etc etc. Still debating on the order to go on and what to buy etc but: - ECU ( Haltech or Link ( Link states that it dont support A/T or AWD functions... Can anyone attest to this? ) - Highflow turbo ( ATR43ss2 ) - Intercooler ( Not decided yet, but cant find many good afoordable ones. Toshi says to opt for crossflow Japanese. Bit difficult this one, unless I get a returnflow Blitz from JJ? ) - Injectors ( Any recommendations ? I do have a nismo FPR ( Thanks SK ) ) - Seats - Tune by either Toshi or DVS To be fair, I did consider just keeping the stock turbo and nistuning it. Sat in a mates stock N, that had something like 200kw, and I reckon that felt more than enough. Maybe I should just go this route ahhaha. Too many choices.... Planning a trip down south, so wanting to just clean things up and make sure it gets to and from in one piece. Anything else specifically I should do before ? Cheers lads
    • Must be for the car’s lucky charm 🤷🏽‍♂️ She runs fine, but it just seems to take about 1L less. Maybe I’ll have the oil sump dropped at some point to check if there is anything
