Hi..
My standard steering wheel (along with probably the majority of R32 GTST owners) is all peeling and crap.
So I went out looking for a new steering wheel and found a few I like.
Then it came to the boss kit..
What's the deal?? I've been told by all the places I checked that the boss kit for my car is different to the standard ones they have for sale due to the HICAS on my car.
So basically instead of paying $70 for a standard boss kit, I've been told that it is going to cost closer to about $180 JUST FOR A BOSS KIT...!!!
Can any of you R32 GTST owners out there tell me different?
Have you changed your steering wheel? boss kit?
where did you go? how much did you get it for?
if you know any places in sydney, I'd really appreciate your help.
thanks.
https://www.sau.com.au/forums/topic/7517-steering-wheel-for-r32-gtst/
Guest Boxhead
Originally posted by GTST
Hi..
thanks.
i have a solution, get rid of hicas...
some guy was sellinghis r32 that previously had hicas but he had it removed, so i guess he would know where to get it removed...
my mate has a silva with it, and he said sometimes the tyre people look at his tyres when there changing them and give him weird looks as to hwy they die in certain ways... ohwell.. just a thought
You know the only difference with a non hicas to a hicas boss kit is a peice of plastic at the the back of it so it can turn the sensor. Its a load of shit to pay extra for a peice of plastic that is only worth 2c. I couldnt beleive when I compared the two of them.
I got a spare one for a 32 if anyone would like to purchase it.
Doc
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
