Finally run a half reasonable time
12.1 @ 111mph
but i have a question... last time with 200rwkw i ran a 12.90 with 200rwkw or there abouts.
now im up around the 300rwkw.
My time has gone almost a second up, yet my MPH hasnt changed one skeric really. Any ideas why that is?
I made a nice 1.90ft, same as my old 12.9 run was.
So they were pretty similar, jsut the times changed :headspin:
https://www.sau.com.au/forums/topic/75175-finally-a-decent-time-and-a-q/
At Heathcote i was running 12.7@111 and i have around the 235rwkw mark. What was your half track speed? Should be around 87mph. Something sounds a miss even with a 1.9 60'. Are you sure you werent shutting down just before the line, Ive done that before.
What mph was your 12.9?
12.1@111mph you must be getting of the line pretty quick!, i only ran 12.4@112mph when i went - and i have 4wd launch!
oops, it was 109mph, and id run 110/111 just for times of 13.00/13.10 etc
my 660ft times was 9.3/80.7 mph... i wasnt backing off thats for sure.
I kept my foot in right past the little white checkers :rofl:
i went easy on the launch as the cars just burns the tyres if i try a decent one
There is something wrong with that 660' time, your at least 1.0 off the pace and 8mph. Check it with your other runs at the 660' mark.
correction, stoopid a$$ me looknig at the wrong sheet
660ft was 8.00
mph/660 was 94.8=68
It has way more than it did wheni ran a 12.9, i seriosuly doubt there was another second in there back in its old form. I've changed nothing traction wise at all.
If anything the tyres are a bit older and crappier now than they were a year ago (12.9 @109mph/200rwkw)
I know the problem. :P
Well m yguess anyway is that the clutch was starting to struggle in the top gears, and what you though may have been wheelspin into 2nd nd maybe into 3rd was actually the clutch starting to give up...well perhaps a combination of both.
That night at Clader where you chopped me my clutch was getting worse with every run, by the end of th enight my mph had dropped 3-4mph when only running approx 200rwkws.
Anyway food for thought:)
with the power you claim your trap speed is way down might be an idea to run it up on a dyno just to double check maybe you have a problem ?. Your abit slow to the 660ft mark and you mph is down thing is your 60ft times aren't bad at all .
For whats it's worth I know my car is abit of a differen't kettle of fish but I have one of the slips here for a [email protected] and on that run went
660ft 7.837@91mph with a 1.8 60ft .
Also don't be fooled into thinking peak power dyno read outs are everything can you tell us abit more about the car and mods .
    • I have offset Nismo brackets so the fact the gktechs can pivot is less important to me. I have 170mm JIC arms with bushings - but they provide no adjustment and I'm not sure whiteline eccentric bushings will fit them (I don't want to ruin the bushings currently in them to find out). Ideally I want something with bushings + adjustment; hence why I'd like to find a pair of these. Unfortunately they aren't easy to find.
    • @Vee37 How much do you really care about finding these pads again? If your pads are quiet, work well and produce minimal dust, really isn't that enough? If you are set on finding the exact pads again, I suppose I'd do something like this -  Visit your local Jax, find out what brand of pads they carry. If the Jax workshop you previously went to had the pads on the shelf, then you can almost guarantee it will be of said brand.   I'm guessing you don't have the receipt for the previous work and pads. Can you visit a Jax workshop and see if they can look up your previous job to see what pads were fitted?  Still no luck? Put your stalker hat on, find the staff that used to work at the Jax store and ask them. Talk to local workshops, try to find out where the mechanics went to. Talk to Jax workshops, maybe they relocated to another workshop. When it comes to mechanics, its a small world. You'd be surprised how easy it is to track someone down. If these ideas don't work, shit will start getting crazy very quickly.... You could find out every brand and model of pad that fits that car... and try them individually ticking each off the list if it wasn't the one you were looking for.... If you go down this path your going to want to learn how to swap pads yourself, it is very easy, takes minimal tools and space. If you have room to park the car you have room to swap the pads. Plus you have the advantage of making sure all the brake hardware goes back in so they won't squeal!
    • You miss spelled bearings...
    • Just putting it out there, that's a decent list. You would be better off *not* doing *any* of that and buying someone else's modded car. Like mine. Or anybody else's. Yes it's lotto dependent and all this and that but that 70K (remember, double your guesses) could go elsewhere. Keep it stock, save your money, go lowball @Dose Pipe Sutututu :p
    • Does not mean what you think it means. The continual rising coefficient is the coefficient of friction that continues to rise with increasing temperature. Not "rising during a single stop", except inasmuch as the brakes should get hotter during a single stop. The RR would not be the best choice for a streeter. Yeah....no it's not. JAX would rummage around in the "shit pads we use for all shitboxen that come in here" and install those.
