I live near it.
ALl i wanna say is, If I were you...... you know the story.
My cousin got rang up the other week cos he has a rare 96 FTO GPX mivec 5 speed for sale - mint nick - they called him up and said they had a buyer the usual bullshit and wasted his time and called him down and when he wudnt budge on the price - there was none of the happy promises and fone call that he first recieved!
They must always do it and sometimes a desperate seller will crack and sell it for some riduculous cheap price.
https://www.sau.com.au/forums/topic/75181-jsa-imports/#findComment-1379713
I bought my car from JSA.
No problems at all you get a pritty good warranty.
They look after you pritty well.
But I dont know about other peoples experiance there.
My dads really good friends with his uncle so i sorta got a good deal.
Im happy with my car no problem at all.
https://www.sau.com.au/forums/topic/75181-jsa-imports/#findComment-1380028
Rang them back today. Soon as I said Im not moving on price they werent interested. So yeah they obviously were hoping i was desperate for the cash. I personally think its a bit rude. They should have made their intentions clear in the first place. Werent very friendly on the phone either.
https://www.sau.com.au/forums/topic/75181-jsa-imports/#findComment-1381429
yup... all backyard work too... find a problem with the paint?? thats ok... it will get redone in their backyard again... my mate bought a 180 from them against my word.
front bar was held on by 2 screws... all the weight from the massive bogged and glass bar buckled the panels... 18s on it had retreads... paint was all over the rubbers so thick that the tape had ripped when they pulled it off and was still under the paint and over the rubber... was massive rub marks from 400 grit paper all through the paint work... rear spolier was held on by 4 screws... not nuts or bolts... screws....
25k for an early 96 model 180... what an idiot...
https://www.sau.com.au/forums/topic/75181-jsa-imports/#findComment-1381579
Guest
    • Sorry Duncan, I didn't get a notification for the replies.  Thanks for responding!  It's a full Android device, but does allow you to use CarPlay/AA as well.  This is the one I bought from NaviRS on AliExpress: https://www.aliexpress.com/item/1005006368602668.html?spm=a2g0o.order_list.order_list_main.111.59aa1802JDzQ0E - the 2K 8G-256G CAM variant but it seems to have gone up by £170 since I bought it!  My purchase was £307.14.   It's not the fastest thing in the world but performs perfectly adequately.  It stays on standby unless I disconnect the battery and let it power down, then it's just a fairly standard Android bootup time from cold.  The DSP Equaliser is very nice and made the standard stereo system sound pretty decent compared to the stock screen.  Perhaps I can take a video of it when I get a sec. It *allegedly* supports the reverse camera, but I'm yet to get that working.  It has options for reverse cam (a camera unit can be bought separately) or 360 cameras (also bought separately).  To be fair it doesn't seem to detect that the shifter was put into reverse but I'm working on a theory about this as well.  At the moment I'm going without which is a bit annoying considering the car is an absolute canal barge but so far I haven't caused any damage I'll grab a picture of the wire I'm missing later today when I can get outside.  My theory, by the by, is that not only is the head unit different, but the CANBUS network has different signals for the different years.  I think this because I have a spare AC panel from a newer Infiniti G37 (as opposed to my Nissan panel) which wouldn't control anything except the volume when I had it wired up with the stock system.  I'm going to throw it back in and see if the screen will respond to it.  I've just ordered an arduino CANBUS module so I can have a look at the signals going around the car and see if I can spot anything.  I'm thinking if I can work out what it's expecting vs what it's getting I might be able to translate and relay the signal back but so far just a theory anyway. I also found this on my travels, so far the only one that specifically matches my car: https://www.aliexpress.com/item/1005002822934280.html?spm=a2g0s.imconversation.0.0.33433e5fgttovi If you look at the picture of the before, it has the card reader slot, and the picture of the head unit is exactly the same as the one pictured in my original post.  I asked if they sell the cables separately but sadly they won't.  I didn't want to just buy this one because it's a super old Android version and only dual core - likely slow as hell.
    • To be fair - you see the same thing for every clutch. There's always someone making an installation error.
