hay guys as it says i need anew clutch,
On the weekend i went to the drags with ash and a few other boys and stuffed the clutch buy frying it hard and now slips after 4000 in any gear so what should i get?
i have a R33 gts-t running aroung 220rwkw when boosted back up
i would like to know where to get it fitted and how much a new clutch will cost in total( drive in drive out all fixed) yes i am in melbourne and will travel most places.
Willing to spend say $1000 all up for everything is that enough?
thank guys
( and yes i have read all the post on the patrol clutch and still are a bit unshore of that direction)
https://www.sau.com.au/forums/topic/75228-need-a-new-clutch/
I just had one fitted. 5 puck sprung ceramic clutch with upgraded pressure plate. Was $850 all up.
The pedal is now lighter than stock (yes, lighter) and bites like hell. Shudders a bit without enuff revs but I spose thats always going to happen. PM Dr_Drift as he installed mine...
what brand is it?
is sam at his new shop yet?
All the Rumors aside **Nissan Patrol Clutch fits**
http://www.skylinesaustralia.com/forums/sh...ead.php?t=21958
will suit your car if its 1993 - 1995. should handle what power your throwing at it, work out a bit cheaper and have same pedal feel
i have some one a everlution R looking in to the clutch from the patrol if it does fit cos the part number from that tred does not match the books every one has, so he is going to find one and try to fit it and match it so i might buy one from him.
what brand is it?
In the PM he quoted a Nismo clutch plate but may have put a different one in (long story). The pressure plate is custom. It is very streetable. Like I said earlier, the pedal is lighter than stock.
He's still at XTC in Coburg.
cool, thanks paul
:cheers:
  • 2 months later...
hey mate,
sorry to dig this up, but did you end up fitting the patrol clutch?
if so do you have part no. of the clutch fitted? also where did you get the work done and what extra parts were replaced (bearings etc.)?
looks like mine is going, trying to weigh up all my options
cheers
I bough one off Jim Berry in QLD. It uses a gtr pressure plate reworked to just under 4000lbs and a 5 puck centre was $1300 delivered with a machined flywheel. It feels great softer than the Nizmo twin plate that i stuffed and grabs hard.
    • If it's for a SR20, make sure it's not the American Poncams, might as well call them Poocams. Had a set in a friend's car, all scuffed up after a few track days. Like the metallurgy Tomei USA used is junk. Went back to JDM OG Tomei Poncams, no issues till now.   Tomei USA is not the real OG Tomei.   Random rant over, fk the US of A, bunch of c u n t s.
    • Most of the industry in North America either runs on Siemens or Allen Bradley. I have two redundant S7-1500's on my desk right next to me for simulation. Siemens has been losing ground though since Stuxnet, as cybersecurity is a big thing. In my line of work that is federally regulated, you must by law have a cybersecurity management program in place and its audited and inspected every so often.  I work with Emerson PLC's daily (RX3i's) and have done large biogas/refinery projects with their DCS's. Their PLC's are somewhat OK minus the way they do PLC redundancy (You have to download on both PLC's separately every time you make a change )  As for their DCS's... you'll be limited financially first before anything else stops you. Costs are exorbiant at roughly 10x what it would cost you to do with any other system (e.g AB PAC).  1990's, those suckers are brand new haha! Kraft-Heinz (An old client when I use to work for an ESP) still runs Siemens TI505 PLC's from the mid 80's. Ohh how I don't miss working with those... you could only do a certain number of online downloads until it's "Change" buffer would be full and you would then need to go offline to do a full download. There was no warning of when this was coming up and it generally would happen when you would go in at 2am to make changes before production -_-.
    • Unfortunately, not only is that not the case, one of the main "Selling points" of safety over comms is they clearly state in writing that there's no need to segregate safety networks from non-safety networks. It always gets intermingled with everything else on an ICS/OT network.
    • Hello. I have an a31 cefiro but since I am in Turkey we have a CA20S engine. I did some research. Then I found that I can swap with a ca18 but when I heard that it has the similar substructure as the s13. I thought I can swap with an sr20 because the sr20 was used with the s13. So can I easily swap the sr20 on my cefiro or is it difficult?
