thanks guys, i'll get the hammers out tomorrow!
  stagefumer11 said:
Please Picture Document this brake swap for us, I REALLY want to know how its done :(
i've only started on the drivers side so far so i'll take pics when i do the other side, they'll be from my phone so not the best pics
  machg said:
If you are using hammers on the tops of the joints, leave nuts on or you'll f*** the threads.
machg
what your saying is leave the bolts loose so the bit i'm trying to remove can move just enough to loosen but not dig into the threads...
Yeah the easiest way is to slug it with a hammer and loosen the tapered joint. As what's been said, put a nut on the thread to protect it so the hammer doesn't damage it. I always find it useful to also pull the arm down, usually comes out easier this way.
  rsx84 said:
got it off thanks guys, might need to machine the s-13 hubs a hairs width to let them slide on a bit deeper just so i can tighten it enough to put the pin back in...
thanks guys..
Machine what to tighten up to what??? You've lost me :headspin:
the steering arm bolt and the hole on the s-13 hub dont match, the hole is just to small to let it slide down enough to put the pin in place, i've threaded the nut trying to tighten it so i'll get it rethreaded or a new steering rack (need power steering anyway).
  DR JOSH said:
I think you will find that the s13 runs a tapered tie rod where the r30 runs a straight one. So they will need to be drilled out, I reamed mine for a nice tight fit.
it might be the other way round as the arm on the hub has just stopped, leaving about 3mm of thread showing...i might just get a grinder drill bit and trial and error it till it fits. i'll need a tap and die set too to fix the thread ;)
the best way to release the tire rod end from the stearing arm is this:
grab 2 hammers and swing the both athe the same time either side of the steeering arm... leving the nut on but loosely. you need to hit it with both hammers simultanisly in order to shock the taper locking the tire rod to steering arm, releasing the taper. may need a couple of hits, but this should do the trick. by leaving the nut on, its stops the tire rod end hittinfg the ground then you can undo the nut and remove the arm
i have done many a joint before and its worked a treat.... ( shown to me by my motor mechanic)........
    • Atmospheric vent requires something that doesn't use a MAF for load. You would need a standalone ECU for that.
    • Hey all,   I’ve got an RB25 with a trigger kit that includes a crank wheel, and I’ve hit a wall trying to sort a timing belt tracking issue. The belt either rides right on the edge of the cam/crank pulleys or walks slightly forward once the engine starts. It tracks okay-ish for a moment, then creeps right to the edge—and honestly, it’s stressing me out.   I’ve spent hours removing and reinstalling the belt, double-checking everything:   Tensioner setup is good, checked multiple times Idler pulley and washers are all in the correct places Followed the RB25 timing procedure step-by-step     The only thing I changed was the rear crank washer—I swapped the OEM one for a Neato version, and it made things worse. The belt now sits even more forward than before. I’m beginning to think the crank trigger wheel itself (from the trigger kit) is the issue—poor design or slightly off dimensions.   What’s strange is that with the previous belt setup, it actually ran fine for a couple of years—around 4,000 to 5,000 miles, even with hard driving and high RPMs. But even then, the belt was always riding right on the edge, and I know that’s not ideal or safe long term.   At this point, I’m debating whether to:   Machine a few mm off the crank trigger wheel to bring it back in line, or Replace it entirely with a better-designed unit     Only thing is, I already have the Cherry Hall sensors, bracket, etc.—I just want to replace the wheel only, not the entire kit. Anyone know a brand or supplier that sells just the crank trigger wheel on its own?   Would really appreciate any feedback—especially from anyone who’s run into this exact issue and found a reliable fix.   Thanks in advance.
    • Hi...a little refresh. Is Nistune gonna be enough to run BoV? Or do i need some proper ECU?
    • Yep that's pretty much what I want to see. Racecars that look and sound like the Group A but with newer tech underneath to make them faster and safer. I'm sure there's enough VK-to-VN commodore, E30 BMWs and Foxbody mustangs shells around to make up a decent number of cars with hopefully a couple of sierras, rx7 and R31s in there too.
    • Contact Jessestreeter.com/Skevas Racing/JustJap for a new r34 rb gearbox or go a cd00# conversion. No point playing with unknown condition gearboxes.
