ARC intercooler Suit up to 450 hp $399
Core 380x 270x 75
Overall 630x 330x 80
Good for up to 230 rw kw and drift sized for excellent responce
Apexi Intercooler (no pipes) Suit up to 450 hp $399
Core 390x 330x 80
Overall 630x 320x 70
Good for up to 240 rw kw and drift sized for excellent responce
Universal fit, no pipes and used but in excellent condition. You pipe kit up for a budget kit
Greddy Type S bov $350 Shipped (Universal fit, immaculate, 35mm Valve)
Trust 40mm wastegate $499 (Replacement cost is $1350!)
2 pot rear brakes, professionally drilled for 4 stud but still fits 5 stud. Completely rebuilt callipers, braided
rear lines, carbon metallic pads (4mm) and braided lines $450 (Maybe able to help out with a front set of braided lines for $110 new depending on car)
HKS GT3040 (500 ps) 1.12 exh hsg 8,000 klm on 1 Bar $2600
Engine running in klm only! Made 300 rw kw on RB30/RB25 11.6 1/4 on 1 bar.
R32 GTR Throttle bodies (2x 3 pairs, 6 all up) Perfect for conversion $350 shipped.
Nismo GTR Adjustable actuators $250 Shipped (pair)
R32 Cusco adj strut brace (GTS and GTR) $120
rear lines, carbon metallic pads (4mm) and braided lines $450 (Maybe able to do a front set of braided lines for $110 new depending on car)
HKS 550cc Injectors RB26 $650
RB26 Stock rods and rod bolts, available in 3 weeks $250
R32 Areo mirrors (Electric) $300 (available in 3 weeks)
ER34 GTT HKS coil overs $1200
http://www.skylinesaustralia.com/forums/sh...ead.php?t=74627
ER34 GTT Apexi GT Spec FMIC (new)
http://www.skylinesaustralia.com/forums/sh...ead.php?t=72844
RB25DET Nismo 550 cc injectors $650 cleaned
RB25DET SARD 550 cc injectors $650 cleaned
http://www.skylinesaustralia.com/forums/sh...ead.php?t=71995
Garrett GT30R 500 Hp turbo $1799 (new, was for my SR20 *sigh)
R32, S13, A31 C33 rear toe kit (non hicas only) $170 shipped
I have an ARC cooler for a GTR 23/33 but one of the pipes has been shortedned for a custom pipe. This means you will need 1 hose longer for it to bolt up
$1050 600x 300x 76mm core
I am not desperate for cash, no low ball offers, period.
I would rather sell this stuff then cart it around to my place.
Some of this stuff is off my older brothers R34 GTT and younger brothers R33 GTS.
The GTR Stuff is mine
hay bro,
do you have the flow sheets fror the injectors when they where cleaned?
how many kms did the GT30 see?
would you consider a package deal on a set of injectors and the turbo?
do you have any photos the turbo?
could you please send them to [email protected]
cheers,
boz
Firstly before posting/pm/email NO LOW BALL OFFERS
I will say it again for the slow
NO LOW BALL OFFERS
If you have sent a low ball offer and have not got a reply:
NO LOW BALL OFFERS
End rant :wassup:
is the arc intercooler a front mount or side mount? cheers
Universal FMIC (no pipes)
got pics of the cusco strut?
Email address?
how old are the nismo 550cc? what level of tune was the rb25 they were they used on?
about 2 years from memory. they where on the above combo (hks gt3040)
Pics please
[email protected]
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
