what do you mean by SAFC or PFC im getting a turbo back exhuast next week and the speed cut defencer i was toying with getting a ECU but i should leave that till one of my last mods is that correct?
If i was you i would just go PFC and get it out of the way :P Ecu is a great mod, im wishing i did it before fmic, as it keeps the tune nice a clean and the car wont run overly rich and make less power.
Leaving ECU to last mods is smart as you will save the $$$ in tuning it each time you get a new mod, but you will make more better pwoer with ecu
https://www.sau.com.au/forums/topic/75275-r33-mods/page/2/#findComment-1381997
No offense, but if you want power, sell it and get a turbo line, it's just wasting your money on a n/a trying to get big horsepower. It's so easy with simple mods to really boost the horsepower of a car with forced induction like everyone has said. If you want your skyline to be as fast as your excel was (i can't even type that without laughing out loud), sell it and get a turbo car. The disadvantage of simply adding a turbo kit to your car would be smaller breaks, no LSD, 4 vs 5 wheel studs, higher compression leading to lower boost and the list just goes on.
https://www.sau.com.au/forums/topic/75275-r33-mods/page/2/#findComment-1383088
if i get the compression changed on my enging to say 9.0.1 or what ever it is i need would that be ok? and would any one know what the compression is on the RB25DE? and how would the studs on the wheels make a diff? might be a dum question but yeh i dont see how that can change anything
https://www.sau.com.au/forums/topic/75275-r33-mods/page/2/#findComment-1383288
Ok zer0rez, here a few things you will need to change on your n/a line to run a turbo
1.Compression
2.Piston
3.Injectors
4.ECU
5.Fuel Pump
6.Brakes (GTS have smaller brake)
7.LSD
8.Intake Pipe
9.Intercooler
10.Turbo
11.Exhuast
Or else you can go sell car buy turbo r33 S1 (import one cost you anywhere from 15 to 20k)
or get frontcut of rb25 cost no idea :S
https://www.sau.com.au/forums/topic/75275-r33-mods/page/2/#findComment-1383425
if you managed to get 180kw out of your excel with the stock engine,
you shouldnt have any trouble getting 180kw with a non-turbo skyline...
just put your special capa supercharger/turbo in it :cheers:
seriously though, sell ya car and buy the turbo. Its gonna piss you off when you spend like $2-3k in mods and you still get beaten at the lights by a lancer :)
https://www.sau.com.au/forums/topic/75275-r33-mods/page/2/#findComment-1383638
    • Updating results following our SR20det project. Data collected form improves future turbocharger making and high flowing services. So far differences between G and GT series turbine wheels, we are in the process of making a new turbine, the aim is for better mid top range flow without gain too much lag.  Result is back to back comparison of G25-660 and GTX2867 spec turbochargers on the same car, nothing changed apart from turbocharger. Both tuned to knock limit from pump 98 fuel (US Ron93). GTX2867 was about 400RPM more responsive making 255rwkws while G25-660 made 17 extra Kws with wider spread of torque after 4500RPM finishing off at 272rwkws.
    • @GTSBoy i tried to jumper the wires and got the steering wheel light to come on which is right under the gear indication but that still doesnt come on.  Can it be an issue with my cluster?
    • Given that you have seen the dash indicator work briefly, then it would seem like you have a simple wiring problem. What happens when you simply jumper the wires on the "steering wheel switch"?
    • Yesterday's day in review: All the wiring to the lights up the front how I want it, is ran, terminated, and all to length. The only lighting up front I haven't finished is the side indicators, as I need to get to the partly cutup factory loom, and find the plugs for them. Interesting note, the side indicators use the exact same plug that's in the doors for something else that I don't remember what it is... So that plug better be careful...   Power steering solenoid, on the R33 is variable, and from memory PWM. The Ford's control from the docs I have so far, is it's just a on or off control. So I'm not sure it's what I want, and in any case, power steering running, but at its heaviest (solenoid off) is likely what I'll want anyway, so I'm not yet touching it at all. All the wiring I can complete so far, is done. There are 3 wires I need to make a plug for at the ECU, and these are just for the vehicle speed sensor, of which I need to get a T5 from an AU, so I can use its output that has the speed sensor on it. (My car doesn't have ABS, otherwise I'd set it up to use one of the ring gears on that). I need to buy new headlight globes and front parker globes, otherwise I could show photos of lights working. Current fuel lines in and out on this motor are "5/16". I'll order hardline, and some AN fittings for that, and I just need to 100% check fuel line size at the tank end, to get the ends for it. I'm also looking at a few options for the banjo bolts to AN fittings for the power steering rack. I'll pull the reservoir off the Barras PS pump. There's an off the shelf fitting for that pump for a -10 AN feed, and it'll use a 16mm to dash -6 an outlet to feed the rack. I'll be making my own power steering reservoir, I'm going through the thought process at the moment of how I'll run the baffles, and I need to research another idea for it too.
    • Two inlet runners changes the engines characteristics requiring less fuel to make torque at different points in the rev range. The smaller diameter inlet runners on the DET increases air flow speed, which improves atomisation of fuel, particularly in low load/idle for better burn, and in specific areas of the engine, (areas you would use when driving normally) increases the efficiency. All of those items change how efficient the engine is at different speeds. The changes on the neo help slightly to improve emissions where it matters. The overall improvements won't be the likes of going from an engine built in the 70s to an engine built in the 2000s, it's just a small step. But still leaves it the RB with the best chance of improvement.   As for your comment about the whole using a cat to not need to worry about those gases. Two things, no system is 100% perfect. It won't eliminate everything. So reduce the quantity you put into it, you still reduce the output. Two, make that system do less work, and it's likely to survive a little bit longer. Funnily enough to, one trick employed to get cats up to temp, AND to drastically reduce emissions before they get up to temp, is to reduce ignition timing.
