Guest two.06l
two.06l: why didn't you tell me this when i pm'ed you the other day about his clutches - i just sent mine up there to get built!!
Because I had this built for one of our customers....only to discover yesterday that he has a PUSH type clutch. I would have sold it to you otherwise. Im in this game to help not hinder.
how would this compare to a exedy 3 puck ceramic ? (cause its around the same price )
Would actually prefer a twin plate but dont have that kind of money right now so I was going to go with the above mentioned clutch to see how long it holds out.
I'll take a guess at answering these questions but don't take my word for it.
Single plate, probably around 3300-3400 pounds clamping pressure. Probably rebuilt from a standard GTR clutch (or maybe a excedy HD clutch)
HP hard to say, If its the same clutch that DIRTgarage use it, they run over 400rwkw :D
Hope this helps (and hope its right :( )
Guest two.06l
Brand new modified excedy 10" pressure plate (standard GTR is 9.5"), carbotic 5 or 6 puck sprung centre. It has been setup and tested in house at Race Clutch, and is developing around 4500lb of clamping force. We have used the same clutch in our race car for nearly two seasons, and can't speak any more highly enough of its performance/longetivity. Our car is producing 411awkw and 467rwkw so it can certainly do its job.
p.s. please pm for more info.
Would it be a straight fit into my R33 gtr?
Im looking at making around 380rwkw, do u think it will hold up?
Just askin cause I had a exedy single plate with 3400 tonne pressure, 5 puk button and it only lasted 6 weeks. I've been told I will need a twin plate to hold up with the power I'll will be makin.
    • Well, hydraulic lifters will get noisy if they are dirty/fouled in some way, and exactly how that manifests will depend on exactly what schmutz is where. There is a procedure on here somewhere for dismantling and soaking/cleaning them. Replacing them with new is about 50% of the work and about 5% of the money!
    • Thanks for the reply @GTSBoy this is is a hydraulic lifter engine. Yea right i did not realise the lifters were supposed to be compressible while installed. I could push them down but i had to lean almost my while body weight on them.  I have never heard of a lifter/ lifters ticking only at hot idle and getting worse the hotter it gets. I have owned a few jdm cars with noisy lifters. This noise is slightly more subtle, it is more of a sharp gentle metalic tic than the solid and more loud tapping I've heard on lifters. I have used a metal rod, alloy tube, hose and stethoscope and could not find the source of the tick. But it appears to be loudest on the actual engine block behind the exhaust cam gear and next to the oil filter. I had mate (40 year old mechanic) go over it with me and he couldn't find it either..  Could it be a cam seal issue of some sort?  Cheers
    • This seems problematic and unlikely at the same time. Vanilla RB2Xs have hydraulic lifters. They do have "zero" clearance, but only when running with oil pressure inside them. When not running, you should be able to compress them and obtain heaps of clearance. RB26s and Neos have solid lifters. They should have ~0.3mm and ~0.5mm on the inlet and exhaust respectively. If they have zero clearance then bad things are happening. With nothing else being wrong, it would mean that the valves would be held slightly (ever so slightly) open when they are supposed to be closed and it should have all sorts of problems when running, caused by leakage in/out through the valves. Or, zero clearance can indicate severe valve seat recession. None of it is good. Have you used a piece of hose as a stethoscope to try to localise the noise?
    • Sorry for reviving an old post, but I'm having the same hot idle tick issue. Did anyone ever find out what it was?  I have checked/ replaced Injectors Coils checked Lifter clerance (is at zero) Checked Cam lobes Replaced exhaust gasket and studs Would appreciate any advice this is driving me nuts
    • There's a huge reason manufacturers are tuning in dead flat torque curves... Make them reliable (and more drive able)
