Got my car (2000 gt-t coupe) delivered the other day, sent it to autoworx for compliance. So Paul (cool guy) rings me and says he needs the Japanese deregistration papers before he can put the plate on which is due in the mail in a week.
I think back to a couple of weeks ago when my dad (who I don’t live with) said he got some mail from Japan which was probably for me. I said I wasn’t sure if i would need it and I would let him know when i saw him next. So anyway I ring to ask if he has the papers and to check if he has the de reg papers, he tells me he threw them out.
WTF!!!!
So like my dad looks to have thrown out my original papers which I need to get my car on the road.
Worst case scenario if the supplier doesn’t have a copy is to get another copy off the Japanese authorities, who knows how many weeks that would take!
I hope it isn’t to much of a pain in the ass, all I have been thinking about for the last week or so is my car and how good it will be driving it.
*TEAR* :~(
lol
https://www.sau.com.au/forums/topic/75307-my-dad-sux/
Pity you didn't use an import broker, they would have recieved it and processed it on your behalf :P or at least adviced you that you needed them.
Good luck with it all, but it dosen't sound like a major hurdle to have the papers resent.
https://www.sau.com.au/forums/topic/75307-my-dad-sux/#findComment-1382050
Getting the papers resent should not be a problem. I don't know if it's the same in Australia as over here in UK though - but when I've had papers missing for a Hilux Surf that was imported several years ago and never registered, I was able to get a letter off Toyota UK. All they needed was the chassis number and description and they sent back a certified letter with all the original specs, weights and so on. The registration authorities over here accepted that in place of the dereg doc.
https://www.sau.com.au/forums/topic/75307-my-dad-sux/#findComment-1382118
we use an import broker once, i think the one you work for shan.
we bought the car asked for de reg papers for the 3 months. and then when you guys finally found them we had to pay for them to get shipped out to where the car went
so import brokers arnt always the way to go
https://www.sau.com.au/forums/topic/75307-my-dad-sux/#findComment-1382202
Pity you didn't use an import broker, they would have recieved it and processed it on your behalf :D or at least adviced you that you needed them.
lol Import brokers are NEVER the way to go. :rofl:
So far I am not even delayed by my dads stupidity, I am still waiting on the plate from RAWS.
spoke to my english speaking contact in japan a moment ago and he was chasing it up for me.
*crosses fingers*
https://www.sau.com.au/forums/topic/75307-my-dad-sux/#findComment-1382581
    • @Ozdavroz Not going to get a better deal than that. Cash up front and ongoing payments. 🤑
    • I wouldn't even move it like gTSBoy is saying. I'd seriously do what Duncan is saying. Unplug the injectors, and unplug the fuel pump.  Pull the spark plugs out. Have a look in quickly with a bore scope if you want. At most, you can't spray a bit of oil into the bores so there is lubricant in there while you crank it. (Don't fill it, as it's only going to enter the exhaust, or spit at you out the spark plugs holes. Before cranking the engine on the starter, after a 5 year sit I'd probably prime the oil system manually. Easiest way to do so is to look at buying an oil filter relocation block, fit it to the engine. The pressure line going into the engine on this block you can then shove into some sort of oil pump, or put it into a bottle, with that hose going to the bottom. Fill bottle up with oil. Now seal the bottle and add a compressed air line to the top of the bottle. Feed compressed air in, about 20psi will be PLENTY. This will pump oil through the motor. Be aware, it also means it will drain back to the sump, so make sure you don't end up over filling the motor Now bolt the old oil setup back on (or fully install the remote filter system).   This way you've at least pushed fresh oil everywhere, then you're letting the motor crank to then do its own oiling. Then I'd tap the key to make sure it can start to crank, if the motor free bumps, then I'd just hit the key and let it crank. After letting it crank and seeing you can get real engine oil pressure, put new spark plugs in, reconnect the fuel system electrics, and send it.   Additionally, you can look to remove the fuel feed line to the rail, and divert it to a tank so you can get the bottom of the tank shit out, and just incase there's some crud sitting anywhere that gets passed the fuel filter (or is already ahead of it).   If fuel injection at the injectors ends up appearing to be a problem, you can dump the injectors into an ultrasonic cleaner for a quick flush clean out. Note this isn't as good as new injectors, or getting them pro cleaned and flowed
    • All I can say is, that's still bloody awesome! No plans on caging it I'm guessing?
    • It seems you'd like your Skyline to go to a great home, that can keep it as a beautiful museum piece.  I feel I can provide the perfect place for it, however, I'm not sure I can justify so much money for a Skyline that has only been crashed 3 times. Due to this and market prices, would you be against me buying it for $100.00, with $60 to be paid upfront, and the remaining $40 to be paid annually in equal payments?
    • I did say no low balling (Insert copy and paste article from Motor mag with complete history of R32 GTR development and racing history here)
