Username Change Requests Here
Could you PLEASE :( change my user name to CL11QE :(
Done :down:
Hi Admin,
can you please change my username to DaN[e]
thanks.
Sorry, can't have square brackets in your name :(
Guest TALEB-TYRES
Is it possible for an admin to delete this account,
reason is i created this account when i started my trading, but i was given a new account(Taleb Tyres) with the business trader privileges which is what i use now, so i dont use this current account(TALEB-TYRES), i wont be using it again so feel free to delete this one thanks...
can i please get my username changed to beRwick_GTRage
thankyou
Could you please change my username to:
gersfan
much appreciated, thanks :)
Both done! Sorry for the delay, just got back from holidays, being back at work ftl
Normally we wouldn't delete but there was nothing other than two posts (no PMs or trader ratings etc) associated with your account, so it's gone :)
My son reckons that my username sounds perverted even though it is me who does all of the work on his car so can I change it to 2KR34 or 2000R34 or R342K please!
Cheers, Mark.
Post your username change requests in this thread, and an admin will sort it out for you, provided of course that the name isn't already taken (click Members at the top of the screen to check it out).
Other than the obvious change of your login and display names, this will not affect your account in any other way (eg your post count, avatar, sig, contents of existing posts etc), and you will receive an email from SAU once your name has been changed, confirming your new login details.
- Revhead
Just wondering,
Is there anyway to have my username changed? The problem being that there already is another user on SAU and just my luck in WA as well by the name "GOT BOOST". I don't want to invade on his username and would like to have my username changed if possible. It has been told to me that I should delete my username and re-register but I don't wish to lose my trader rating and history.
Does anyone here have the power to do this?
Cheers,
Hi, Can you please change mine to Sklyn,
Thanks muchly..
Cheers, Mark.
Both done :laugh:
    • Suspension bush. Got urethane bushes in the upper arms?
    • thanks for heads up on actuators - will sort something as back up or solution as yes dont need that have enough trouble but no doubt some addition of something to spares boxes is required yes have a clue about WTAC but nothing has been officially put out yet so will wait to see exact details Pro class is, has been and will become a draw card for lap records and one off builds for show and thats about it I think - be interesting to see how open they make it Pro am is the old Pro in reality Open class will be split into 2 with slicks and 050's with no doubt slight variances in allowable drivers and changes in aero Clubsprint + apparently a true street class   They have to and are refreshing it all and bringing things up to current standards and need to 100% adhere to rules because whether people like it or not / or say it or not - for alot of competitors it is sheep stations and has been for a while when Im getting told I was illegal because i cut my rear bumper too high and yet others where in the grey areas of legality with everything from engines, suspension, ride heights and more serious influences it actually got quite out of control and heated this year so as much as I may be impacted by some of the changes and prob spit the dummy when I have to spend money changing things I think its a good thing for all
    • I can’t tell if it’s suspension related or maybe wheel bearing or motor mount.  IMG_6209.MOV
    • Start with a multimeter, and see if you're getting power at the TPS. There should be a manual for your car somewhere on these forums and it'll have the info for what closed TPS signal voltage is, and how it should sweep to full throttle. Same as for other sensors / valves.   Have you checked things like your base timing etc? See if anything looks amiss there too?
    • here are 2x options to consider: https://www.selby.com.au/price-promise/tonewinner-sw-d6000-subwoofer.html https://www.apollohifi.com.au/svs-pb-3000-ported-subwoofer-black-ash-pre-order.html I'm waiting for a good BF/CM sale and will pull the trigger on a new sub, I do like the SVS PB-3000 (13") but you could nearly buy 2x Tonewinner D6000s (15")
