Does any one get back to you for a name change does not look like it's happening here!
You waited 3 minutes before complaining? Yikes. You've been suspended for 2 days. When you chill out and calm down remember that you're asking people for THEIR TIME when you ask for things on a forum. When they have no time for you (because they may, you know, have other shit to do) then you need to WAIT.
When you come back, be patient.
  • Like 4
Haha cheers mate :P Both name changes done
Crazy/Crzy - if you can send me a PM or post in this thread using the other account I'll merge the two. I'm guessing you want to keep the account you've used above, as it's the one with the most posts (even though most of them are in here lol), it's just the name you want changed. Let me know if you want it the other way around.
And as Prank says - relax :)
  • 1 month later...
Hi, can change my username to STARSKR33M
Hello
Would you please change my username to R-sanichi
Thanks in advance.
please and thankyou, dudn't realised i missed those, was late when i wrote original post
Both done - and cheers, call me old-fashioned but I do appreciate the manners :)
Arkan - as I said above, if you can send me a PM or post in this thread using your other account (to confirm that it's yours) I'll merge the two. By that I mean that I'll join the two accounts together - you'll have one account at the end, and all your old posts will be moved to your new account.
  • Like 1
    • Old Son, did you re-use the Holden ABS in the new shell or try a different module?
    • Yeah, nah. I had the actuator rod off it today. The arm will not move at all. Neither out, nor in. Yeah, you'd think so, but I've been thinking about that. Even when the actuator rod fell all the way off at the beginning of this saga, it would build more boost and faster in lower gears than it would in higher gears, and you'd think that that was the opposite of what should happen. But I strongly suspect that there is a thing with the gearing getting the revs to rise faster, that there must be some transient effect with the gas flow rate rising quickly, that you don't get with the more steady state case of the higher gears. Keep in mind - the gate is not shut in either of my weirdnesses. So things are not "normal". We normally think about a turbo spooling up (below the wastegate target) with the gate shut. I have all sorts of mental models running now where the gate is a little bit open, and having it stuck open allowing gas out while it should be going through the turbine has all sorts of weird effects (in these mental models). I'm thinking in the higher gears, the ex mani pressure builds to the point where enough gases spill out the wastegate to just prevent the pressure rising much more at all, or just creeping up, all the whole the revs are increasing and getting closer to the point where a gear shift becomes necessary.
    • Is it possibly wastegate actuator itself is sticking, or even the rod to flapper? Otherwise I reckon things are getting a bit rusty/worn   Also odd it won't boost in 3rd to 5th, but will in 1st, I'd expect the other way around with it slightly open as there's more time on your way to redline for it to spin up
    • Does anyone know ow what these two plugs are for and if they should be unplugged? Just put the dash back together and can't remember if these were plugged in before or unplugged! (Blue and white plugs) 🤦🏽‍♂️
    • Did some FASTing ...got the impression that the actual part# was a moot point ; seems all of these hardlines for coolant are discontinued/NLA... like, I take it you're after the hardline that bolts onto to the manifold...that's NLA according to amayama & nengun .... ...just to clear up some confusion, they typically mounted the AAC valve to the intake manifold somewhere near a coolant passage, so the body of the valve heats up & holds it open when engine's up to temp - no coolant flows through the valve, it's a mechanical, thermal connection.
