Could you please change my username to:
Spraderz-33
Thanks a lot guys :)
Hi, Could i please have myname changed to:
GtstCoupe
Thank You :)
Done!
Hi, If possible could I change from madbung to Bung..thx
Bung is taken sorry
Damn...thx anyway,just checked he's had 1 post and been inactive since 2004, any chance?
Not really mate, about the only way I could do it is if you can convince the person with the name you want to give it up. Given that they've been inactive for that long it's likely their email address isn't valid any more but you can give it a go.
Hi Guys,
Can you change my name to
85URE
please,
thanks
Mark
Sorted!
Can I change my name to
Norman
Please? Thanks!
Can't actually do yours atm mate, someone already has the name Norman :)
may i please get mine changed from rad33 to rad32
regards,
adrian
i will give you virtual hugs if you change my name to "SKYL1N"
could o get mine changed to James_31 instead of what i got now?
All done! Awaiting virtual hugs :)
  • 3 weeks later...
Sorry guys, have been out of action for a bit :P
hey guys
could you change my name to Nene260RS
please :P
Hey guys,
Could I please have my name changed to Drifterdan
Thanks,
Dan.
can my name be changed to
itchy
thanks. ;)
All done!
Grats on the upgrade Nene ;)
    • Read the ECU for fault codes or have someone else do it. A faulty coolant temperature sender is usually listed in ECUs. If the sensor itself is not busted it can also be a bad ground connection. Or in a really unlucky case, damaged wiring.
    • Can't be a Futjitsubo as those are made with a flex piece and Reimax is smaller in pipe diameter. If anything it is closest to a Mines pipe, but evidently it is not an actual Mines pipe.   Classic word humor
    • Alright I will try to not forget.   As GTSboy replied to you already, problem is mainly the mismatch between the actual exhaust part and the denomination in the papers. That basically just looks like tampering to a cop, if they were to check your car and notice. If it had been done right they would have clarified it to be a custom pipe and just given it a certain part number that you have to engrave or weld onto the pipe. I will definitely inquire on what to do. Changing the pipe wouldn't be my favorite solution as it costs a bunch of money and the cat was fitted with the front pipe and exhaust under the car, and if the front pipe flange does not sit in the OEM location the cat will need to be refit for any other pipe to work. It also usually doesn't need a brand name or something like that, but more something like a part number. Usually for exhaust parts, on silencers and cat units specifically, there is a badge that reads the certificate number that belongs to these exhaust parts under EU regulation. You get these numbers after you put a part or group of parts through the tedious testing according to EU vehicle legislation and they pass. You can find these "part numbers" on various parts throughout a EU vehicle. On windows, headlights, engine parts, seat belts and so on. All these parts have gone through standardized testing and acquired a so called ECE or EG Certificate that makes them legal to use by themselves in all countries that adhere to these standards. You can also not alter these parts in any way, if you do they become illegal. An example for stampings on an exterior lighting part, the people who need to know can find the documentation for this unit in a database. I do not know what all the standards and so on mean.
    • If that was the case I suppose you could call it "Mein's" brand....  ... I'll see myself out... 😅
