Hi,
Just had a couple of questions on intercoolers..
1) What are the differences between tube & fin and bar & plate?
2) What would you reccommend for an r32 GTST? (intending to do turbo upgrade later as well)
3) How much would it cost all up including fitting and piping kit?
4) What is the difference between air to air and water to air?
I'm considering an r32 GTR FMIC.. i've read the other post about GTR FMIC's and Hybrids.. what other brands do you guys recommend?
Thanks guys.
https://www.sau.com.au/forums/topic/75333-questions-on-intercoolers/
The difference is in the core type. Tube and fin are generally recognised as being the better flowing cooler with slightly less effeciency (ie ability to cool air) whilst bar and plate are generally recognised as flowing slightly less but are more effecient.
Bar and plates typically also restrict air to the radiator more then tube and fin, but this also depends on cooler thickness etc.
My thinking is the quality of the core and end tanks is more critical then the type of core used. Either correctly sized to your application and budget will be fine:)
Id say grab a neat tube and fin one cooler approx 600 x 300 x 75mm with at least 2.5" inlet and outlet" (3" ie GTR is better again). Unless budget isnt an issue id be more concerned about finding a cooler complete with some nice pipes. GTR is fine but be sure you look into the price for piping before fronting the money for the cooler...it can soemtime work out more expensive then buyimng a bolt on HKS/Trust etc intercooler complete with pipes etc.
Depends. Id say a budget of $1,100-1250 should see it all installed, be it as a bought kit or seperate intercooler piped up.
One uses water to cool the air going into your engine, think or a radiator inside out. Isntead of air passed around the outside to cool water, water passes around the outside to cool the air
The other uses air passing through it to cool the inlet air
    • I would paint match the whole thing to avoid unwanted attention  I had a similar bonnet, paint matched, on my old R33 GTST, but mine was a fibreglass jobbie made by Blitz in QLD, they work extremely well for radiator efficiency and under bonnet temps
    • Does anyone run this kit with factory plenum? Does the adapter and bosch tb fit under factory strut brace? I wanted to get this setup before going forward facing manifold. Thanks
    • small update time, after always wanting a "cool" looking bonnet for my car and always struggling to find one for the series 2 that i liked and wasn't an insane amount of money. Saw one i liked on RHDjapan from D-speed in Japan the price was very good for a carbon bonnet so good infact i was a little unsure how much i trusted it, decided to bite the bullet and with the help of jesse streeter in not long at all it was at my door. Once it was delivered i ran in from work and quickly unboxed it and to my surprise the quality was actually pretty good i quickly removed the old bonnet and placed on the new one to test it out and even the fitment wasnt too bad at all. Then decided to paint the little grille in the bonnet black to stop it sticking out so much.   I decided to not mess around with the hood latch and just install some aero catch hood pins, having never installed them before did some YouTube university classes and i was good to go. fair to say it is not a fun job at all from making brackets so the pins sit nicely and actually cutting through the bonnet but also being very scared of cutting the holes too big it took wayyyy longer than i would like to admit but finally got it there. Then it was time for a quick test drive to ensure the latches actually worked and thankfully the bonnet looked very stable. I still think paint matching the bonnet and leaving just the part that sticks up as carbon would help make it all look alot neater as im not sure how i feel about all that carbon on a very fridge white car but will leave it as is and see how i feel with time.
    • I think it's bound to happen, you finally get it all perfect, and bam, something will happen. I took a while to get a Commodore rear quarter repaired where a P Plater clipped it. Two days after getting it back, Sarah wiped it out on a concrete pillar in an underground car park... This is why I take forever to repair them, it stretches how long until it gets bent again... 😛
    • Nah, not really responsible for that little fiasco, but I'm still pissed at myself for writing off my 86, or when I reversed my VX into a pole just before selling it, but, meh, 5hit happens to stuff, all it takes is a slight distraction, and life is full of distractions, and "dooh" moments
