It's all right for tonight, cruising in a corvette and feeling alright!
matty can u sms me ur moby number i dont think i have it nemore, 0417 608 538, i have to wait till tanya finishes work at 9 but should be cool ill catch up i guess.
  • Replies 100
It sure feels like it. My car has not run properly since 3rd or 4th Quarter last year. I will admit it has spent some time in the garage with me just too annoyed to do anything about it.
I have known what needs to be done to fix it since mid April, but the budget has been the next problem. I have ordered some of the stuff I need now so it will hopefully be running by track day, if not definately by next track day and hopefully a few cruises before then.
Good to See, was wondering when was the next Meet.
My car running all sweet after few hick-ups. and now running 10psi
See ya's there.
Don't forget the Long pants and jacket.
Later guys
Only problem is I will be in either the sedan or mini as the GTR is away getting a few more goodies added to it. :rofl:
Got one question, is your dual dragger melting your rear bar?
Only problem is I will be in either the sedan or mini as the GTR is away getting a few more goodies added to it. :D
Hey mate.. bahh take teh beast out this thurs!
btw, my zaust is fine, i left it just enough cap for it not to touch the rear bar.
What cats did u end up using? i had to use 2 oval cats made by toyota..
    • That ring thing is interesting how it's holding everything together
    • Hey guys. I have a 400R on its way to Australia from Japan currently and have a few questions I’m hoping others may be able to help with.   Wondering if anyone here has had any luck getting the Sat nav unit to work in Australia!? Assuming the Stereo is as simple as a band expanded and tv won’t work?  Seeing as they’re based off a Q50 which is Aus delivered is there any way to link that system to the nav? Nav modules and head unit are different part numbers and appear slightly different at the rear with plug ins etc. can I put my xtrail sd card into the rv37 and will that convert the maps or update to Australian? Has anyone got any advice here?     also has anyone fitted the factory remote start and Security system once it’s landed in Australia? I put an enquirey to Nissan Japan in via a third party, and they suggested it needs a Nissan Japan dealers device to setup and couldn’t guarantee if one here could do it or not. They can supply and I can physically fit it but to setup I would need a dealers device. Any information here would be appreciated also. I’ve seen one here with it fitted already prior to leaving Japan at a dealer/inporter, so clearly passes compliance and works when fitted Japan and doesn’t need changing here.      also, does the tyre inflation sensors work here? Does anything change with them when the vehicle arrives? Where are they actually situated? I’ve read they have batteries and they need to changing at times and seems like resetting involves the nav system?    any help here would be appreciated and any other aust specific information to help would be great. Looking forward to see what the current generation skyline is like and eager to see how many of the gadgets can be utilised here.  Thanks in advance
    • Do need to take it with a pinch of salt. One of the adapter failures, they clearly had setup issues with the flywheel.  One of the slipping ones I spoke to and it was pretty clear the throwout was riding, rather than fix, just swapped to a new clutch.    These clutches are being put in anything from 5k offroad 4x4 beaters, GR yaris, 500hp commodores to 1200hp barra monsters. Bound to be some issues in some of them when they are not a simple bolt in affair due to the changes in height.    There is a lot going on in this picture and unless I did the job myself no way to tell what really happened.
    • I did this mod in 2019  You just have to modify the top bracket of the ABS/TC/Fuel Pump Control ECU so it sits more upright and closer to the back seat and run a good quality positive battery lead from the engine bay, the negative lead i just bolted down to the body in the boot.
    • Damn... Not the feedback I want to hear.
