need some cash so ive got my blitz supersound bov for sale with piping and stock cooler..
BOV - 180ono
Cooler - 50bucks.
Will consider swap for audio items or other 32parts.
Steve.
https://www.sau.com.au/forums/topic/75352-fsblitz-supersound-bov-stock-cooler/
  • 3 weeks later...
BUMP
this stuff has 2 go..
BOV - 150bucks!!!
Stock Cooler - 40bucks!!
Need $$s cause got defected n tickets n stuff.. Not lookin @ swapping no more.
Thanks,Steve.
    • It is an absolute lottery. They can and have died at stock boost with low usage at all. The turbos are now anywhere up to 36 years old!
    • Huh, wonder why it blew then. I never really beat on the car THAT hard lol I dailyed it and the turbo blew after 6 months
