hi i have a s1 r33 gts atm and im looking at buying a front cut and atm i can not afford the manual gts-t cut. i was just wondering could u buy a rb20det manual front cut and use that??
if so wat would need to be changed and wat additions to the 32 front cut would i need to buy??
my other question is wat would go harder a manual rb20det in an r33 or the rb25det auto as i do have the money for that. ive also bought, turbo back xaust, cooler, and b control take that in to consideration wen comparing the 2.
cheers alex
https://www.sau.com.au/forums/topic/75382-front-cuts/
Id save up for the manual and turbo RB25 no use just settling for what you can afford now if you have saved this much its not going to hurt saving a little extra for the manual. You will get sick of the auto if ultimately your after a manual. The reason they increased capacity was because of the extra curb weight. You will be behind the 8 ball if you put an RB20 in there.
My 2cents
https://www.sau.com.au/forums/topic/75382-front-cuts/#findComment-1389062
    • You're 20 years too late mate. Used to be 80% skylines back in team trackday days
    • There's a lot of drug money on that side of Sydney. Just sayin'.
    • At SMSP, I mainly see Hondas, M cars, A90 Supras and of course, plenty of Evos. Have not seen a single R32 ro R34 Skyline on the night sessions that I've been to. That's really saying something.
    • I like mine. Much better than stock. Like i said before the reverse/parking cameras look even worse than normal, still useable. When you buy one make sure it's the latest version. Heaps of cheap ones that run the old hardware and software. Got mine from AliExpress. Mine is quick no lag, boots up 1-2 sec. Menu is fast. Netflix is fine and so is YouTube. Android Auto is random taking 3sec to 15sec. Most of the time it's quick. Very rare it doesn't connect. But that could be a phone thing.   Now I think they use a Pixel 3XL to run this whole thing which i guess is fine, but the problem is that some apps will not work on old hardware like Disney Plus  Maybe Prime Video too 🤔. they will not update. Iv'e tried getting the APK Disney + but i still couldn't get it working. I have a Data sim installed so i have internet all the time. You can't Hotspot off your phone and connect Android Auto at the same time. Not that you need too, if you want you can hotspot off your phone and run any internet map app (google maps) and you can run the Spotify app on it's own (the app runs better than android auto) You can still access the INFINITI intouch system for all the o.g stuff    P.S i got new non Polarization Sunglasses too 😎
    • I also don't mean to rain on your parade. But with a 5-10k budget for road only? I'd want to check confirmation that everything IS working correctly and I'm with @GTSBoy for a plan of action here. I'd be checking subframes, bushes, exhaust hangers, interior bits and generally QOL things and CONFIRMING they are working right before thinking about motor. You can get 250KW+ on stock RB26 hardware by simply removing the built in restrictors and tuning the stock ECU. If you want purity that's as far to take it, which I would be worried to do and won't think the budget would allow for when earnestly checking for 30+ year old car stuff.
