Hi all,
I've got to move my RB26DETT which came in my car. I got approx 6000-7000km out of it since buying the car. By all indications the motor should have 120-130K on it (a serious estimate) based on car, odo, and condition of the motor.
The motor had the standard oil pump fail on the drag strip just before the line, coasting through to a 12.5 @ 111mph on .7 / .8 bar. The motor was shut off immediately, but sustained some bearing damange (Scored not spun). The motor is currently sitting on the engine stand with the crank out (needs to be linished, but should be otherwise fine, would recommend microtest). The motor made 253rwkw @ 1 bar on the dyno, and compression tested at 160psi in all but cylinder number 5, which was 155psi.
Basically on offer is the lot, complete head with coils, complete block with crank, rods, pistons, sump, inlet manifold with plenum etc, exhaust manifolds, standard turbos, dumps etc.
The engine is missing alternator/powersteering/AC/starter motor/injectors/loom.
As I have to post a price in this section, I'll say $3K ono and take it from there.
YES, I will seperate parts - however please email me [email protected] so this dosent turn into an unmanagable post. Please feel free to ask me any questions.
Also available:
- JUN Crank collar (BRAND NEW) - $200
- Aftermarket Front pipes to suit twins (not sure on brand) - $200
- Standard RB26 AFMs $150 ono
- APEXi power intake pod filters (practically brand new w/ brackets) - $250 ono
- Standard ECU $200
Will update this post accordingly.
Cheers
Rick
https://www.sau.com.au/forums/topic/75399-eoi-rb26dett/
  • 2 years later...
    • Hey lads, reviving an old thread.  As an update, since the last time replied to this thread, ive done mostly suspension. Havent touched the motor except for maintenance. Though upon changing spark plugs, found out i had splitfires pre-installed! Updates: - Got me some stock airbox top cover and snorkel to fit onto the original intake. Should be free of defects - Bought a set of R34 GT-T brakes (not installed yet, going to rebuild + respray in champion blue + white 'Nissan' text) - Bought the last set of bilsteins from @Sydneykid and had them installed. Has been making some sounds on the rear but hopefully should be sorted out after this New Year break. - Regreased front caster rod bushings (poly bushes..) - Rear upper camber arms - Whiteline sway bars (BNF27Z 22mm + BNR11XXZ 24mm).  The rear sway bars are a bit short (ive read 50mm else where) but was still able to get them in.  Anyhows, I reckon suspension is sorted now. Maybe replace bushes (do have a set of front upper control arms from SK not installed yet) but should be okay for now. From now, I'm wanting to start working on the motor, drivetrain etc etc. Still debating on the order to go on and what to buy etc but: - ECU ( Haltech or Link ( Link states that it dont support A/T or AWD functions... Can anyone attest to this? ) - Highflow turbo ( ATR43ss2 ) - Intercooler ( Not decided yet, but cant find many good afoordable ones. Toshi says to opt for crossflow Japanese. Bit difficult this one, unless I get a returnflow Blitz from JJ? ) - Injectors ( Any recommendations ? I do have a nismo FPR ( Thanks SK ) ) - Seats - Tune by either Toshi or DVS To be fair, I did consider just keeping the stock turbo and nistuning it. Sat in a mates stock N, that had something like 200kw, and I reckon that felt more than enough. Maybe I should just go this route ahhaha. Too many choices.... Planning a trip down south, so wanting to just clean things up and make sure it gets to and from in one piece. Anything else specifically I should do before ? Cheers lads
    • Must be for the car’s lucky charm 🤷🏽‍♂️ She runs fine, but it just seems to take about 1L less. Maybe I’ll have the oil sump dropped at some point to check if there is anything
    • Hmmm interesting. Mine is the exact same and clearly the right one.  The mystery of the engine oil being full after 3.5-4L continues
    • Yes I as well would like to find out where I could get some of the seat material with the red or blue small squares in it
