Dropped my car off on Saturday, as the people who were at Autosalon know I was a little dissapointed with the dyno results I got there.
I figured that as I just bought it I should let Ben take a look, after all you all keep saying how great he is. Well damn if you aren't all right!!!
To start with it Dynoed at approx. 220kw at all 4. After Ben tuned it...... 330kw at all four!!!!!!! :kick:
OMFG that is awesome :P
B :D
https://www.sau.com.au/forums/topic/75411-another-i-love-racepace-threads/
  • Replies 61
Minor mods and 2530s do not equal 220rwkw. On the other hand, it is Qld tuning. Apparently someone got 400+rwkw from stock injectors up there. Must have been highflowed :D
Benno, da man with the Mida's touch :P
Car must feel better with another 50% at the treads.
Just booked my car in for a service, tune up SAFC & dyno run.
Earliest was over 2 weeks. D'oh!
Can't wait - but I will.
If everyone else's comments are correct, hopefully Ben can squeeze a few hundred extra kilowatts outta the engine! *wishes*
Seemed a nice guy too.
If you want to get your car done sooner, send it to Ice Performance in Cheltenham.
Nige is also a master tuna :D
They should be able to fit you in before the 2 weeks.
Yep - definitely there seems to be large number of people on here turning gay. There's far too much Ben love.
Personally I'm in love with the chick that came 4th at Indy. So close to winning it and DAMN hot. I'd go her over Ben any day! :P
But great result Brett. Your car definitely didn't sound right at Autoslaon. Wonder who in Perth did the tune on it!
Reckon we could dress Brisby up a bit at the next track meet? We are short of cute chicks on the track. Maybe we could lure the young lady in the Porsche from the Maser club to join us. Amber Andersson.
    • Hows your intake piping? Are you still running stock? Having in the stock AFM position would mean, if the BOV was shut/venting out, it'd create the almost stalling kind of effect right // "the rich pulse behaviour" due to MAF thinking air is flowing ? But this would be better than having the bov in the stock position + MAF on/just before cross over piping right?
    • Essentially, yes. Although I wouldn't put the AFM on the crossover pipe. I'd want to put it into what amounts to the correct size tube, which is more easily done in the intercooler pipework. I bought a mount tube for card stile AFM that replaces the stock AFM - although being a cheap AliExpress knockoff, it had not flange and I had to make and weld my own. But it is the same length and diameter as the stock RB AFM, goes on my airbox, etc etc. I don't have a sick enough rig to warrant anything different, and the swap will take 5 minutes (when I finally get around to it and the injectors & the dyno tune).
    • So to summarise, the best thing to do is to move recirc to between turbo and IC, and maf on the crossover pipe. Meaning I'd need a recirc flange, drill a hole in the piping on turbo outlet area. And drill hole on crossover to fit/weld maf sensor? Either that or put the MAF on the turbo inlet right?  Is an aftermarket recirc/blowoff valve recommended? Do currently have family in Japan so could probably bring something back with maybe a cheeky lil SuperAutobacs run?
    • Yep, so far most have said that it looks like corrosion on the wall from piston not moving. Which then has probably damaged the oil rings and caused those vertical marks. The longest the engine was still after the rebuild, was the winter of 2018 - 2019, plus the boat trip to Japan. When I shipped the car, it had normal gas in the tank but before that winter pause, it had E85 in tank.  In any case, even if either one of those was the cause, it happened close to 6 years ago and the car has been driven something like 30 000kms after the fact. Again, apart from the plugs and the dip stick, there is nothing in the way the car runs that would indicate what has been going on in the engine. I am going to consult a shop and ask their opinion, what would be the best approach. I do have some access to a garage I could use to diagnose further myself, but time is very restrictive. Might end up buying another engine that could be used while this one is being remedied. Without pulling the head, it will be impossible to find out if it needs another bore, but here's to hoping a hone would suffice.  Goddamnit, I would really have preferred this not happening.
    • Boot is going to be replaced eventually. I just wire brushed what I could and rust converted. Then painted in rust kill primer. the spoiler also got repainted and plugs replaced on the ends. The under side of the bonnet is going to be black also, currently white. But red on the top side, same colour code as the silo to begin.
