  • Replies 57
You got a fair bit of power given the weight of your car. You should of taken the GT and SS not only high end but up to 100km/h as well.
I think traction / throttle control is my problem 0-100 even with 275s :) I see the car still near me so I open the throttle up more wanting it to go faster but I must still be wheel spinning, I’m concentrating too much to realise lol.
Had a clubsport trying to catch me from 50-100 the other day, I was running stock 7psi ‘not expecting to race’ & we seemed to be even ‘wish I was running 12psi :)
309.6hp = 230.87kW for ~1.3 tonne
Actually my car is supposedly 1390 kg, it was weighed when at the EPA, I'm not sure if there was someone sitting in there not when they got that figure, I assume while it was on the dyno getting tested for emissions 'which it failed 3 times lol' it was weighed.
I guess the skyline guys I talked to were right when they said that the problem with these gtsts are that there are quite a few out there with poor suspension/tyres therefore it doesn't matter how much more power they add to their car they can't launch properly. That probably explains why you do well up top when traction isn't an issue.
Are they R34 N1 turbos or R34 GTR turbos?
ok, just looked and I think the turbos say Garrett A/R T3, can't tell if its a T or a 3 tho...
Also what colour injectors?
The injector tops are a dark yellow/orange sort of colors
cheers
Tom
cheers
Tom
Ahh ok
If they have the A/R written on the front then they're not R34 N1 turbos unfortunately. Prolly just the 34 GTR ones.
And if they're a yellowy coloured injector top they're most probably standard.
cheers
Tom
Ahh ok ...
If the turbos have got an A/R rating on the front, then they aren't R34 N1 turbos.
They may well be R34 GTR items but you'd have to get them looked at.
And yellowy coloured injectors are the colour of the standard injectors
Hope that helps :rant:
My car has been dyno tuned yes... My power curve is as follows:
I'd really like to know my torque.  On an old dyno sheet I had a peak of 3400 lb when I was making 292 rwhp, how you convert that into an estimated Nm I dont know!?
IT of 56deg?
someone has been playing with the figures a bit...
I just did a quick search and found that 1 ft.lb = 1.356Nm
so in your case 3400lbs = 4610.4Nm :rant:
IT of 56deg?
The sensor was off yeah, there'd be a few kw in inaccuracies there. I’ll get it dyno’d again one day.
LMAO Holy shit wouldnt that have some throw back!! Nar I'd guess it would have to be somewhere around 500 Nm. I'm such a yutz, I read the wrong line on my old dyno sheet, its more like around 1100.
huh, well I must have gotten a different conversion then
TORQUE RANGE: 50600 ft.lbs./68814 Nm NBT* (Nut Busting Torque): 1000 ft.-lbs./1356
Nm Max. Torque: (Forward)-625 ft.-lbs./848 Nm; (Reverse)-700 ft.-lbs. ...
so thats aboviously wrong!, my bad :chairshot
    • In a few years from now, you'll regret that. It'll eat away at you, knowing the truth of the ugly hiding beneath the beautiful exterior... 😛
    • I don't think the G2 profile is particularly dangerous for the engine per se, more just are you actually ok with the turbo lag trade-offs? If the answer is yes then go for it. I personally don't think I'd be ok with it because I spend so much time at lower RPMs and I really enjoy the feeling of being able to stay in 5th gear on the highway and just roll into the throttle to get boost. Or staying in 3rd gear on "gentle canyon cruises" without feeling the turbo lag too badly. The 525 pump should be able to run flat out on factory lines but I would bet the pressure drop from pump to regulator is quite impressive. I don't know how much it would be exactly but I've seen figures like 30 psi thrown around.
    • It's interesting seeing everyone talk about what level of risk they are happy to tolerate.  Building a GTR always has a level of risk, you could be that lucky guy that drops 20k on the engine build alone and still has the thing go pop on the dyno. Life is fun like that.  The way I see it, the thing is a toy to be enjoyed. I'd be happy to turn up the power on stock motor and limit the risk with sensible tuning and engine protection. If it still goes pop, it is what it is. The car isn't a daily driver so it can happily sit while a plan is made to sort it out.  Given this thing will be a street car only, I really feel it's worth the (relatively small if managed well) risk to turn the power up to around 350KW on e85.  I don't think anyone getting into the skyline game now is doing it out of logic. Surely it is a purely emotional decision so I'm not sure how important it is to think about the engine build logically. The heart wants what it wants.  @joshuaho96 little note for Josh, I run my 525 pump flat out all the time and through the factory lines without any issues. (excluding the melting connectors, that's sorted now. we'll pretend it never happened lol)
    • But the Nexus S3 is very expensive and won't be as purpose-built for the application as a separate electronic boost controller :^) More seriously my pet issue here would be that the Walbro 525 running at 100% duty cycle is going to require more FPR than the stock setup can handle. I'm also pretty sure from what I've seen elsewhere you might want to slow down the pump regardless unless you're going to come up with some way of upsizing the fuel lines coming from the fuel tank. Factory 8mm fuel line doesn't actually flow very much if you want to keep pressure drop down between the fuel pump outlet and FPR. If you really want to "keep it simple" I would run only as much pump as you need and source a fuel pump controller to slow down the pump in the vain hope of being able to run stock-style FPRs which are pretty dinky. Or just use the HICAS lines and it should be mostly fine. OP should also really think hard about what profile they'd want out of the turbo. My pet choice here would be the G1 profile rather than anything higher power but YMMV. I already think ~stock turbo lag is pretty bad so I don't want to make it worse. In "gentle canyon cruising" I found that I spent a lot of time around 4-4.5k RPM. I also recommend DIYing labor if you're detail-oriented enough. Costs are high for labor + if you do it yourself you can be your own quality control.
    • GTSBoy is again on the money. My actual advice? Sell the car. (really). For what it's worth as is, you can sidegrade into something much better. If you care about function then this is the actual move. If you want a Skyline to perform, set aside about $100K to do it. This is NOT a typo. You will see right away these are two very different mindsets. Realistically we're talking full restomod for any Skyline still kicking around. Have an honest think about which one you are.. and what you want to do, and how much you want to invest in this (with no return).
