Howdy Yall,
Wondering if anyone has any ideas as to what the asnwer to the following problem might be.
I have an '89 R32 Gts-t with HKS exhaust, apexi airpod, HKS EVC III, Blitz Turbo Timer and pretty much standard everything else engine wise. Now my problem revolves around the use of the EVC. When i run the car on stock boost (ie boost controller on monitor only) it works beautifully however when i turn the boost controller on it does the exact opposite of what it should, that is control the boost levels. If i set the boost at a modest 0.80 kg/cm^2, my turbo timer tells me that it is peaking at around 0.9 kg/cm^2 and above in some cases. If i set it at 0.85 kg/cm^2 it peaks at over 1.0 kg/cm^2 according to the timer and when it is on boost the turbo keeps surging. Basically the power to the wheels will rise and then drop off a bit, rise and drop off a bit and so on.
Since this has happened ive kept the controller off so as to not do any damage to the car till i can get it working properly. Not sure if it might be dodgy wiring, broken connection or what, so any help would be greatly appreciated.
Thanks
Laine
Can the duty cycle of the solenoid be adjusted using the evc? If so then you should probably drop it down a bit to bring the turbo on a bit slower.
I have seen guys running 100% gain on blitz ebc's and on the dyno it was causing boost to bounce around wildly.
You will also find that the gauges you are using to check boost aren't properly calibrated. my DSBC reads very high (1.2bar when making ~1bar) vs my boost gauge which reads slightly high.
What you are experiencing does not sound like turbo surging to me, more like missfire due to the spark plugs not liking the extra boost. When was the last time you changed and gapped the plugs?:D
Ah ok, well i had the car fully serviced about 2 months ago, however I think i better check the plugs and make sure they are ok.
And yeh ill have a look at the solenoid duty cycle but not being much of an expert on that stuff i cant say ill have much luck!
Thanks guys and anyone else with any ideas id welcome your comments too.
Laine
    • My idle is set at 950rpm though - Moving the timing around 20 degrees is not really what I'd call a calm idle. That said... neither is chop, by definition. The LS ECU likes to adjust timing to hold idle as opposed to air. It'd work, but generally speaking there'd be a discrepancy in the base idle and the IACV would want to move the timing around anyway to maintain said idle. I think I'm just going to keep the timing steady anyway. Preserve my engine mounts.  My aircon is now officially regassed. As the guy was reversing I noticed my reverse lights do not operate, along with my reverse cam. This is a bit distressing, because 100% of guides talk about which wire to connect to backup cams as "the goes with the [other color] wire". Often when doing conversions. Unfortunately the R34 colour wires aren't documented Unfortunately I had a T56 Magnum gearbox with it's reverse switch, which also isn't documented. Unfortunately there's definitely not documentation for people with both of these in the one car. Unfortunately I forgot. After many hours of this, I have a reverse cam and reverse lights again. The wire going through the trans tunnel to the reverse switch had broken. Upon inspection, it looks like this one wire had about 7 spade terminals and extensions in it.. for reasons I cannot possibly comprehend. I also spent the 750 hours required to clean up the wiring behind my head unit which now looks like this: This is a monumental improvement relative to what used to be there WRT triple gauges, head unit, traction control, wideband controller, and whatever the f**k OEM stuff still exists there in various states of connectivity/needed. Next step is to check in at the Exhaust shop to see/confirm how much clearance I have, to decide what mid mufflers or 'resonators' (which are just straight through, narrower mufflers) I can add and hopefully cut out a lot of exhaust leaks, pinhole, v-band or otherwise. But first step will be to 'take a look' before the next step.
    • Fark the AFM card and Nistune, Haltech Nexus S3, DBW, cruise control, flex fuel, dis dat.
    • It's most likely the bolt/bush where the cover bolts back wore and allowed cover to move forward.
    • Still haven't put the injectors and R35 AFM in so we can tune the bloody thing for the HG highflow it got mid last year! I think I can forecast the upgrade path to a bigger twin scroll, external gate, Haltech, flex setup, Samsonas, dis dat, etc will be .... a while away!
    • Should have taken that opportunity to slot in a twin scroll turbo setup. Maybe next time.
