I see there is heaps of threads on it. But what I am looking for is spark pugs for an R33 RB25DET.
I don't really want to spend $17 a spark plug though.
Could I get 25k-30k out of the cheap ones (about $4 each)
I just see there is a bit of plumbing over the top of the engine and the the coils have to come out etc. It's a reasonable job.
Is there any that will give approx 50k or more for around the $10 each mark. I read somewhere that the mid range price ones aren't great i.e. some poeople werehaveing truble with iridiums.
Also gap them down to 0.8mm? I guess if platinum you shouldnt change the gap..
Thanks
You are right, there are heaps of threads on this topic, even for the RB25DET.
One simple rule to remember, the less you pay then shorter time between changing plugs again. Dont expect 25-30000 kms out of $4 coppers. I suggest get the coppers and do the job yourself, its pretty easy with the right tools and change them every 10 - 15000 kms. If u find this task too hard then pay someone to do it and get the platinums or iridiums put in. They will last longer but are more expensive.
Final thought:
U say you dont want to spend $17 on a plug (total of $102) that will last you 50,000kms.
This works out to be .204 cents a kilometer compared to coppers at .24 cents a kilometer.
Money should not be an issue here and i would never put sub standard parts on my R33 just to save a few bucks
Here are a few links. You should be able to make up your own mind after reading them.
http://www.skylinesaustralia.com/forums/sh...k+plugs+rb25det
Ive studied plugs a bit, and copper ones wear a little as when copper sparks it burns part of the metal on the plug. Its ok if you want to change them regularly. Iridiums are great but you generally find you have to gap them down, ive gapped mine at 0.8mm.
To gap them it only takes about 2mins anyway right. Just put the feeler gauge in and bang them a little on a metal table etc. THat's how I ususallly gap them anyway.
Surely coopers could last say 25-30k? I heard that even platinums you may not get the 100k kms as the plugs may foul quite a bit.
Iridiums the way to go??
You can't gap platinums can you>
Thanks
Coppers cant last 25-30k's, they wear away!!!
Iridiums are a better conductor of spark than platnums
Copper's give a better spark initially then start to wear. Within a couple of thousand k's theres nothing in it. iridiums give a more consistant spark for longer.
If you get iridiums you can get 100k on a stock, sedately driven car according to ngk literature.
If you get copper's im sure you could get 30k plus if you baby the car and it is still stock (ngk state 20-40k from memory). Just be prepared for the inevitable miss fires associated with worn sparks at high load/high revs.
For coppers get bkr5es-11 for stock car, bkr6es-11(or -8 if you experience miss firing) for slightly modded car, bkr7es for heavily modded car.
For platinum/iridium equivalent check the ngk aussie website. You can find it on google.
Coppers last a lot more than a couple of thousand km's.
I had my last set for 15,000 km with no issues. My A/F ratios are on a flat 12:1 so it gets hotter than a stock car would.
Only reason they were changed was b/c they were suspected of causing the misfire which turned out to be the coil packs.
I put the old ones back in b/c I cracked a few new ones from over tightening and the car felt no different. (new ones were in for a few hundred km's then removed again b/c they were not gapped properly.)
Iridiums do last much longer, but on a street driven car, they are a waste of money IMHO.
BCPR7ES - Coppers @ 0.8
Good for Sr20det's too.
that plug is too cold for a daily driver.
As BHDave said, a 5 heat range is good for stock, and 6 for modified.
7 is too cold, and should only be used when heavily modified.
BKR6E, or BCPR6E are your best bet.
They should be gapped at 0.8, and have the V groove which allows more edges for the spark to arc from.
You can purchase them pre-gapped. Just buy the plugs with the number that ends "-8" ( = 0.8mm gap) - the standard, recommended plug ends in "-11" ( = 1.1mm gap).
You shouldn't need to gap them down anyway. If you find that you do, then you should be looking at the coil packs, not the plugs.
Apparenly they don't do the -8 in the iridiums. Would I lose much power if I am running with .8mm instead of 1.1mm if it could actually handle the 1.1mm. I'm going to check my coil packs when I replace the sparkies. Thre is a slight hesitation when boost comes on so I'm thinking either sparkies or coil packs. I don't know how old spark plugs are....
Some say that the cracks are so small you can't even see it?? I was going o do the araldite trick if I can see cracs in them like what some of you guys have done :P
Thanks
What i ment by that was the coppers initially provide a better spark then iridiums/platinums. but within a few thousand ks they perform about the same and by 10k or so they are starting to get a bit past it, not that they are completely rooted after a couple of thousand ks
Anybody?
Is the BKR6E the platinum, and BCPR6E the copper?
If I get 2 years out of the coppers it should be ok.
both the bkr and bcp are coppers. Both fit though the bcp is the copper equiv for rb20 and 26, the bkr is the copper equiv for rb25.
generally the plugs with IEX (i think) at the end of the part number are iridiums.
    • Hi. A little bit of an update. It maybe(hope not) looks like i would need a new tranny(it would be "maybe" a cheaper or better option anyway) So i need some info. I know i need a different propshaft(i can make custom one) LSD is not a problem cuz the engine will be still(for now) N/A RB20. So if i buy RB25DET NEO tranny...is there something else i need? I read something about push/pull type but i do not know if i need to "change" something or i can just plug n play onto my engine a go? Thanks for the advice
    • Good morning all, Bit of a random question but figured I’d finally throw it out after wondering for a long while. Before I start, I'm hoping to do this purely out of personal preference. I think it would look better at night, and don't mind at all spending a few hours and dollars to get it done. I've copied this from a non-Skyline specific forum, so I apologize for the explanation of our headlight switch setup that we all know. Here we go: Zero lights (switch off) Parking lights (switch position 1) being a rectangular marker on the outside of the housing, my low beam being the projector in the centre (position 2), and a high beam triggered by my turn signal stalk. Most North American cars I’ve owned of this era have power to the amber corner (turning indicator) light as part of the first switch (parking lights). I’d love to have these amber corners receive power when the headlights and parking lights are on (headlight switch), yet still blink when using the turn signal which is of course a separate switch. Hopefully I’ve explained my question correctly. Is anyone aware of a way in which I might be able to achieve this? Thanks in advance
    • My heads are cathedral port! It's likely possible, but I don't want to add any extra moving parts (I know they don't move) between the heads, manifolds, etc. It will also affect how injectors/fuel rails etc sit and I don't really know if it would change how the FAST manifold goes/sits/fits. I have the LS6 steam pipes already as I have a very late LS1 block so it should be fine. I couldn't find anyone who had ever actually used one for this purpose, it seems 100% of people grind the water pump. The thermal spacers are 12mm and are half way to the cost of the newer water pump anyhow... so if it comes to that I suppose I'd rather buy a new pump. The bearing in the pump I do have is a little.. clunky, but it hasn't done that much time and I never noticed it when the car was together in the past few years, so..
    • The bushing has failed, not all that uncommon for a car of this age.  Any mechanic should be able to push in a new bushing for you, or you can probably buy the entire lower control arm, complete with bushes.
    • Could you not use "thermal" spacers to give the clearance, like the ones I used between the blower and head? That raised the manifold height by around 10-15mm Albeit the ones I used were for cathedral ports, but I assume they have similar for rectangular ports????
