Hey,
I try and do as much as possible to keep my families cars running well.
One thing that I've never been taught is wheel alignment. Seems every so often throughout the year this needs to be done and wouldn't mind knowing how to do this.
So can a backyard mechanic do this? If not, just say no you idiot. If so, please explain.
Many thanks.
https://www.sau.com.au/forums/topic/75489-can-you-do-your-own-wheel-alignment/
Well...unless you know what you are doing take it somewhere with a 4 wheel laser aligner like most Bob Janes. We tried to do the toe ourselves the other day, thought we had it right (1mm in at rear) but actually had 17mm out ;) not as easy as it looks :rofl:
Wheel Alignments are really important, they have a hge effect on handling and tyre wear.
A $35 wheel alignement will get you a front toe adjustment, if you are really lucky they might do the rear toe as well. Forget about camber or caster adjustments, that isn't going to happen for $35.
We have a camber gauge, 2 pieces of box section aluminium and 2 lengths of 1.5mm hat elastic and I align the race cars with that equipment. But I have been doing it for a lot of years. I couldn't possibly explain it, would take me 10 thousand words or more. Pop out to a race meeting and I can show you though. :cheers:
Thanks for the feedback guys, appreciate it, I'll keep paying to do it.
I also found this great website:- http://www.familycar.com/alignment.htm for anyone else looking on this issue.
Thanks for the offer too SK, I won't trouble you with that, but If you need an extra hand to help out with something at a track one weekend, just PM me, cheers.
my dad did his own wheel alignment on an old ZH Fairlane he had after changing some suspention parts
when he took it down to get it done properly it was within 1mm of being dead accurate (all done by eyesight) the guy at the tyre place couldnt believe it
so it can be done but better to get the pros to do it that way you know its right.
The only thing you could do by yourself would to adjust the tie rods to centre the steering wheel if the steering wheel is offset in a straight line. However this would only be a temporary fix. Doing a wheel alignment by hand should not be attempted by the light hearted and it is definately not easy to do for someone inexperienced in doing it. As SK said it would take too long to explain it over a forum and that the only way to show you how to do it would be in person.
Best off spending that $35 for a wheel alignment.
    • looking forward to your t56 swap man its a game changer if it works!
    • So, when are you trying the new GR86 or BRZ?
    • Uncle Duncan Yeap, FI Interchiller  Works well, normal IAT's cruising with the WTA only went from 50°c+ to 25-30°c with the interchiller  Before, when on it hard, the IAT would see 80-90°c, now, the highest has been was around 38°c IIRC IAT is measured under the blower hat I recommend it for the street or strip where your only on it hard for 10 or so seconds, but it wouldn't be efficient for sustained track use as it would heat soak from the AC turning off or whatever it does during WOT to protect the compressor It really needs the AC running for it to not heat soak and keep the WTA coolant chilled My WTA coolant temps when just cruising is around 2°c
    • Hey Mark...sorry to interrupt your career change to hair dressing... but...did you ever fit the interchiller to the commodore, and if so how was it? And, who made it?
    • I've been pondering this, I really enjoy the convertible thing, for me, it's like riding a motorbike, without all the issue of riding a motorbike, mainly, my old sore arthritic joints getting beaten up, and, being able to do it in shorts and a T-shirt and not needing a helmet and all the other gear required, especially like wearing jackets and pants in the summer, or needing 6 layers of cloths in the winter, or not having wet weather gear handy when your 100km away from home on the bike when it decides to start raining As for the hard top and its Coupe look, whilst I do lose all that open top feeling that I really enjoy, from my experience with the NB with a detachable hard top, the cabin is a much nicer place to be, the difference in noise for one, a hard top quietens down the interior, alot, with the soft top up or down it's pretty noisy, which, after 5 or so hours, can get tiring But, as you stated, the detachable hard top totally changes the look of the car, in a really good way, and for me, the look of a detachable hard top is so much better than the PRHT which looks more like a after thought with its weird bulbous rear roof line For me, the minimal effort of putting in on, or storing it after removing it, is well worth the time and effort for the look alone And yes, I'm sure the next owner will be grateful for it as well.......
