Hi guys,
I dunno how it happened but my car somehow made 230+rwkw at just 13 psi stock boost for hks2530.
Even the tuner was surprised. He now believes that with somemore tuning and upping the boost to 1.2 bars (around 17.5psi), we can make at least 250rwkw.
This was done on a dyno dynamics dyno!!!
I will post up pictures when I up the boost and fine tune the car.
Mods are HKS2530
GTR fuel pump
Power FC
3' turbo back with HKS split dump and race-cat
550cc Nismo injectors that somehow flow 565cc when flow-tested
Z32 afm
Hybrid FMIC
Splitfire di ignition coils
irridium sparks
I am now too scared to drive the car as even at stock boost, the car keeps burning the road when i dun want it to!
The tuner is still insisting on upping the boost to 1.2 bars though...what should I do. Will the car become even more undrivable then???
Dan
https://www.sau.com.au/forums/topic/75530-r33-gtst-makes-230rwkw-at-13psi/
  • Replies 41
If you can't control the power, either
a) Don't turn up the boost more!!!
B) Invest in a decent tyre / suspension setup to reduce traction loss
c) Drive by the throttle
With that kind of power though, I don't think you'll ever NOT get it to spin. Ahhh, how I wish I had your problems !!!! ;)
Dan
well done. I had 220rwkw with a similar setup except stock injectors, but the bottom end was fully rebuilt with forgies and GTR rods/ ACL race bearings so was good for running that consistently on the track.
I would recommend staying with what is comfortable, plus if the bottom end is stock it becomes more of a time bomb the longer you punish it, and will no doubt go bang at a moment most inconvenient. Also your clutch will be susceptible to burning out with hard accel through 3rd if you cane too hard. You decide what you want, not the tuner.
For the suspension I recommend a set of pineapples (120 plus fitting) which will allow greater traction. Also the stock suspension is crap so maybe some HD systems from UAS (1400ish) but order the softer springs (120 per pair or get them specced with the softer springs) for nicer road work if you don't track. Search for spring weights by Sydneykid who is our suspension Guru for examples. With this I was just chirping through second on the irregularities on the road on Dunlop 9000SP road tyres.
Hope that helps.
More boost!
But thats my answer to everything.
I'd get used to what you have then go for more :rofl: 2530 + rb25 = response. You'll have to start rolling on the throttle rather than stomping on it you lucky punk.
I'm running 240rwkw at 16psi at the moment and although my brand new tires managed to hold second without losing traction for 2 weeks, they're now starting to spin whenever boost comes on. 3rd gear can hold traction, but second no longer.
Once you start losing traction it just gets worse because the more traction you lose, the faster you lose tread and then you lose more traction blah blah. Just like a turbo boosting it creates a chain effect that gets worse and worse.
Good tires for the win!
Far too often I read a list of Skyline mods and I can't find anything that would improve the handling or brakes. Spend a small fortune on the engine and then can't use it. They don't have too much power, they have TOO LITTLE HANDLING.
Well Dan, it's time to balance up the equation, pop over to the suspension section for details.:cheers:
PS, aftermarket injectors always flow a little more than their rating (it's only 2.7% after all), nothing unusual there.
Thanks a lot guys for all yur answers....
I think I will up the boost to 1.2 bars then see how it goes. If I don't like it, I can simply turn the boost controller off. At least my PFC will be tuned to handle 1.2 bars when i turn the EBC back on.
Right?
The car is virtually permanently on boost. Even when it is not moving, u can sometimes hear the ball bearings still going for a while after the engine is off. Boost comes on very very hard suddenly and pins you in your seat with wheelspin just under 3000rpm.
So yes, I personally found that boost came on earlier and very much harder than the stock turbo.
i had to release my accelerator pedal to gain traction....i keep losing traction each time i overstep the acceleratiors. I am now practicing to be very friendly with the pedal.
Oh yes, I am surprise....my clutch is not slipping....how come? Its only a heavy duty 860kg organic!!!
I managed to drag the car up till 90km/h in 1st gear. That took me 4 seconds.
u must mean second, as first runs out way before 90 :)
and benl1981: i have a friend with same car as me apart from is have stock turbo and he has 2530, the 2530 is no laggier than stock, i would not say less laggy though, either way very very close.
the difference is when the 2530 comes on boost(with higher boost levels obviously contributing) it hits hard!!
in second/third gear in the 2530 equipped car u really gotta hang onto it with stock suspension so dan i know what u mean, and you really should change your springs/shocks and adjust camber.
Yo Aaron,
Im running a blitz dsbc type R. But the car is currently running on stock boost (apparently its 13 psi on my HKS2530) :D I see you are in SA as well!!! Me and a few other guys around our age of 20-24 meet up now and then. You should come join us mate!!!
just today, Sam, Duc and myself went for a drive in my car... and it reved cleanly to 9000rpm and wheelspins all the way in 1st and abit in 2nd....pity i forgot to get a picture of 3 R33s together in a row! You must come join us some time buddy. My hp is 0403671496
Dan
What boost controller are you running?
If you had say an AVC-R you could run just enough boost in each gear for the wheels not to spin/just spin.
or just don't plant it all the time :(
    • You're 20 years too late mate. Used to be 80% skylines back in team trackday days
    • There's a lot of drug money on that side of Sydney. Just sayin'.
    • At SMSP, I mainly see Hondas, M cars, A90 Supras and of course, plenty of Evos. Have not seen a single R32 ro R34 Skyline on the night sessions that I've been to. That's really saying something.
    • I like mine. Much better than stock. Like i said before the reverse/parking cameras look even worse than normal, still useable. When you buy one make sure it's the latest version. Heaps of cheap ones that run the old hardware and software. Got mine from AliExpress. Mine is quick no lag, boots up 1-2 sec. Menu is fast. Netflix is fine and so is YouTube. Android Auto is random taking 3sec to 15sec. Most of the time it's quick. Very rare it doesn't connect. But that could be a phone thing.   Now I think they use a Pixel 3XL to run this whole thing which i guess is fine, but the problem is that some apps will not work on old hardware like Disney Plus  Maybe Prime Video too 🤔. they will not update. Iv'e tried getting the APK Disney + but i still couldn't get it working. I have a Data sim installed so i have internet all the time. You can't Hotspot off your phone and connect Android Auto at the same time. Not that you need too, if you want you can hotspot off your phone and run any internet map app (google maps) and you can run the Spotify app on it's own (the app runs better than android auto) You can still access the INFINITI intouch system for all the o.g stuff    P.S i got new non Polarization Sunglasses too 😎
    • I also don't mean to rain on your parade. But with a 5-10k budget for road only? I'd want to check confirmation that everything IS working correctly and I'm with @GTSBoy for a plan of action here. I'd be checking subframes, bushes, exhaust hangers, interior bits and generally QOL things and CONFIRMING they are working right before thinking about motor. You can get 250KW+ on stock RB26 hardware by simply removing the built in restrictors and tuning the stock ECU. If you want purity that's as far to take it, which I would be worried to do and won't think the budget would allow for when earnestly checking for 30+ year old car stuff.
