You'll need
-Pedal Box
-Brake Master cyclinder to slave cyclinder line made up
-Gear box mount, s13 ca works in mine.
-Tail shaft to be modified and balanced (the yolks are different in the two box's)
-clutch
and flywheel.
I think thats about it. Should take about 2 days or so.
  • 2 years later...
i am in the middle of doing mine... Manual and auto gb mounts are identical..looking for a manual mount is pointless, you will need to modify your gb bracket and lengthen it, my mate did mine with some steel and modified the existing bracket and welded an extension on the bracket as the brackets on the BODY are in a different location.. the hole in the tunnel is also about 35mm further back. But im pretty sure it will be ok to use that hole still.. the manual tailshaft still bolts up however... auto doesnt as the auto box is shorter
Edited by BANGN
    • You can try capping the power steering idle up valve at both ends if it's old. The valve and the intake manifold. That is something that is known to fail in Toyotas with age and it will suck power steering fluid into the intake and burn it in the engine which can cause issues. Then bleed it again with engine off first. Do like 30+ lock to lock turns with the front wheels off the ground.
    • Hi Brent, I am wondering if you ever worked this out? I have upgraded this unit to a newer one and everything works bar the reverse camera, so i really want to know what plugs are what so I can patch the camera through. many thanks in advance Mike
    • Once you have to get up in the morning and be useful, you suddenly value sleep it turns out :p
    • Update:   smoke test all pipes no issues cleaned reservoir   fluid put in ( dexron 3 atf)   steering turn side to side and could hearing  gurgling from steering rack which I assumed was air lock, opened one of the steering rack connections and could see loads of air getting pushed out( not sure if you meant to do that / whether it will re introduce air into system)   anyways, loads of side to side sound was gone. Turned car on, pump was slightly ( barely) wining so turned side to side few more turns and fluid level when car on was almost none in resorvoir which I guess is normal if car is one. Turned car of and fluid was gushing out. Almost 200-300cc was pushed out. Repeated engine off side to side followed  by engine on and same result       going mad now. It seems system is either sucking air in whilst on or there is tons of air which I am not giving it enough time to bleed. Thoughts?   would it work like brake caliper if I open steering rack copper pipes and let gravity pull all air out?   or maybe have a restriction somewhere? What is the red circled item, could that be blocked? It i
    • Yeah, the plan is to just put some black rubber vacuum line caps over them to "hide" them a bit I don't want to trim them in cause I need to put the OEM box back on at some stage
