For Sale:
Rear R33 turbo k-frame. Comes complete with:
calipers
discs
hubs
axels
4.1 lsd centre
four wheel steering motor and module
all rubbers and bushes
rear half of tailshaft
k-frame assembly
LSD is tight and quiet. asking $850
0427988066 (Western Australia)
https://www.sau.com.au/forums/topic/75587-fs-r33-turbo-lsd-assembly/
  • 4 weeks later...
    • It is an absolute lottery. They can and have died at stock boost with low usage at all. The turbos are now anywhere up to 36 years old!
    • Huh, wonder why it blew then. I never really beat on the car THAT hard lol I dailyed it and the turbo blew after 6 months
