does anyone have any information about standard or forged pistons, I never knew if i had forgies or not so I was told to take the spark plug out and have a look to see what was on top of the piston.
there are only 2 possible things you could see and that wil tell you either if you have forgies or stock pistons,
outcome 1: you have a little blister on top of the piston which indicates that the piston was frm an injection mould which means they are stock,
outcome 2: piston has a little indentation which means the piston was spon on a lathe making it forged.
from what i can see by taking out the spark and shining a light down the hole, is a little ring the size of a 5cent piece and some writing which looks to say 05U
i have no idea what this means and havnt come to any conlusions cause of this, if anyone has any pictures of some stocky or forged pictures from top would be much appreciated....
https://www.sau.com.au/forums/topic/75593-rb26dett-pistons/
no idea. the only reason i said that is that standard GTI-R pistons have '54C' written on them as this is nissans code for that variant of SR20, makes sense the other nissan pistons would have a similar code.
forged ones will generally not have any writing on the top of the piston.
https://www.sau.com.au/forums/topic/75593-rb26dett-pistons/#findComment-1387221
and the 05U would be 0.5mm OS perhaps??
No....05U is part of the Nissan part number for the piston. It will be something like xxxxx-05Uxx. I believe it identifies it as an R32 GTR part.....certainly an R32 GTR flywheel has 05U cast into it, as does the standard RB26 block (N1 block has a different number). Usually the last 2 numbers after the '05U' will be different for o/size pistons.
https://www.sau.com.au/forums/topic/75593-rb26dett-pistons/#findComment-1387607
yup "05U" appears on alot of R32 GTR part numbers :)
https://www.sau.com.au/forums/topic/75593-rb26dett-pistons/#findComment-1387706
    • Howdy friends, So another weird one today, I was looking into replacing some broken clips holding the front grille for the R32 GTR (part number 01553-03831), and noticed the brackets which are supposed to hold the grille in place were also missing 😑. I do recall seeing this issue many years ago, but didn't fix it at the time. A quick look on eBay and I was able to find the genuine brackets, along with all the screws which suited the headlights (part numbers 26042-08U05,26092-08U05). Happy days!....  Once they arrived however there was an extra nut in the packaging which implied that there should also be a bolt or a stud, and sure enough, after a bit of searching I found this thread from 2013, and @Ants clearly shows a stud should be present. Reading around a bit more, it's possible the headlights on my car are the "povo pack" headlights as mentioned by @funkymonkey in this thread way back in 2008. This could explain why the studs are missing on my set of headlights. Looking at the headlight diagram I wasn't able to see a suitable part number for the stud itself. The headlight did indeed have a recess that looked like it would accept a stud, but interestingly no thread or anything obvious how the stud would be affixed to the headlight, I suspect it may have been glued in, press fit, or melted into the plastic at the factory. Another member may be able to clarify if they happen to have a genuine set of N1 headlamps. The only thing we have to work with within the recess is a keyway which likely is there to prevent the stud from rotating within the recess. In any case, back to 3D printing, I put together a model which acts like a pug with a friction fit inside this recess, making use of the keyway so it doesn't rotate while tightening a bolt. Printing in TPU will allow it to slightly swell making a nice snug fit without cracking the part. I've designed the adaptor it to accept an 20 mm M6 bolt (stainless with a cap head in my case), as opposed to the standard M5 stud and I made use of the standard galvanised split washer that came with the genuine brackets from Nissan. Once the bolt and screws were all in place, giving the bracket a gentle shake gave the classic "shaking the car" feeling, very solid, which gives me confidence this is going to be able to hold on much better than the janky solution which seems to have been here for the past decade or so. Overall I'm really pleased with how this turned out and maybe there are more people out there running these headlights without a centre stud at all! Link to the freely available model on Printables: Click here Regards, Sean
    • Hey everyone, This is my first post apart of the introduction. I tried searching a bit on the forum but couldn't really get a straight answer. I got the car to my mechanic as I felt it being weak. It seems that it was missing on two cylinders due to the injectors. I had all my injectors clean and the car runs much better. The mechanic also confirmed my suspicions that the cat is clogged and needs to be tackled asap. The cat rattles a bit and the hot exhaust warning frequently lights up when driving after getting the injectors clean. In my introduction I was asked about what modification I might be interested in and mentioned a cat delete. From what I was told, this is not really beneficial on the RB20DE and there are more cons than pros.  Could perhaps anyone give some suggestions on what the best course of action would be since the current cat is toast and needs to be removed/replaced anyway? I can also sometimes smell a strong smell of fuel, but I'm not sure if this is related.
    • Hope the cans went down well at least
    • 255 can't go wrong with the price.
    • When I was replacing my pump due to being stranded in the wrong state, I went with the Deatschwerks 320lph kit. It is a direct plug in to the stock wires, harness, everything. It comes with a plug... but you can plug the OEM plug directly into this thing. https://justjap.com/products/deatschwerks-dw300-fuel-pump-nissan-s13-silvia-r32-r33-r34-skyline-c34-stagea?currency=AUD Downside: Won't actually flow that much on boost if you want to push it on E85, but it's comparable to the 040/255 etc. Little more actually.
