I have had problems with the locks on my doors ehich are very stiff to open and lock. They lock and unlock fine by themselves but its very tough to turn the key in the lock - andnow the central locking doesnt work very often... as in te passenger side door just wont lock when i lock the driver door. I pulled out the lock about a month ago and sprayed all hinges associated with CrC which seemed to make a difference but now the problemhas come back.
Also with mysunroof, it will slide all the way back no problems but when i try to close it it gets stuck at certain points and needs a 'pull' to get it closed - this is obviously a lube issue and was wondering what i should use and how i should apply it.
Any help is appreciated.
-Marcus
    • Ha ha ha! I know those feels mate I've finally got the garage cleared enough that next weekend I'll do some actual work on my car (hopefully). Unfortunately garage isn't usable after 10am at the moment That said, I've done a lot of work this weekend on helping finalise a friend's Production Race car. Full started Christmas Eve. We're down to about 8 tasks on the list, including "get a wheel alignment". Sometimes it's just easier working on someone else's car or project than our own stuff 😛
    • Ha ha, ended up going it alone.  I just sent it (in a very nervous fashion).  Once I'd released the locks and it didn't automatically start spinning out of control i felt a bit more confident.   It made some loud sounds (cracking and creaking noises) when I first spun it which got the heart rate going again!  I couldn't bring myself to leave it tipped on the side.  I feel a bit more comfortable having back right side up while it sits there. I'd get angry with your last point but you're 100% correct! 😅 Even yesterday I managed to distract myself at numerous times to make a bracket to fit an LED flood light off the back of the house and fix my sons pushbike.  There were other little taks nibbling at my brain for the rest of the day too...
    • Probably one of the more nerve wracking experiences of my entire life! 😂😂 The balance (centre of gravity) is out still but in a direction that gives me comfort!   It's quite bottom heavy still meaning it takes a bit of muscle to rotate it.  The plus side of that is that it wants to to go back to upright.  Better that than wanting to go all stranded turtle on me!
    • hmmm that's not ideal. This is a pretty new engine right, will be interesting if your engine guy has any theories about causes
    • A universal ball joint removal c press kit is better money spent and will work for the Hicas ball joints.  Here's a 45$ CAD Example. ATPEAM Heavy Duty Ball Joint Press Kit with 4WD Adapters | Professional 4 in 1 Ball Joint Press Removal and Installation Tool for Cars and Trucks | Universal Ball Joint Tool with Storage Case, Ball Joint & Tie Rod Tools - Amazon Canada
