Ok so i took the car for a run yesterday and thought it was off the show (not able to keep it straight and just lighting up the rears) anyway i dont have my boost gauge yet and wasn't 100% sure what it was running. Figured it to be around 12 -14psi so i borrowed Griffo's boost gauge and "BOY" was i off.
The little old RB20 was boosting at slightly over 1.5 bar.
So we turned the boost back to 1bar and is MUCH better, still very easy to loose the rear end from time to time, just have to moderate it with the right foot.
Im going for 240rwk's once i get the FMIC on an exhaust but i think TimmyB can back me up on this as i think i have one of the toughest sounding cars getting around on Tassie roads
Pics to come guys.
https://www.sau.com.au/forums/topic/75617-slightly-over-boosting/
240rwkw from an rb20 with fmic and exhaust??? dont you mean 140....even 140 is a good effort, an rb20 is lucky to reel out over 100rwkw. and if you dont have an exhaust...how does your car sound tough??? does the car have any other mods??
wierd post man, try and clean it up a bit.
cheers
Linton
cheers
Linton
Sorry guys was in a bit of a rush when i posted this yesterday. Realised i had posted it in the wrong section and then reposted it in here. Just realised though that i cut over half the original post off.
Hope this helps to clear it up a little now.
Car mods as follows:
TD-06 turbo with external waste gate (50MM i believe)
bigger injectors (with extra injector for high boost)
GReddy injector equaliser control (is what i've been told it is)
aftermarket ECU
electronic boost controller
upgraded fuel pump and swirl pot
adjustable fuel regulator
Z32 AFM
GReddy BOV (currently venting to atmosphere
GTR intercooler (replacing stock intercooler) want a FMIC
3' dump from the turbo into rear muffler which is standard at the moment, with extractors.
GTR rotors and calipers (is what i've been told)
irridium plugs and upgraded ignition coils
rods and pistons have been done as well as bearings (is what i was told)
set of race springs and HKS front and rear strut brace.
Apexi air intake with modded CAI /Heat shielding (thanks to SAU thread)
button racing clutch and locked diff (want to change diff)
Have not dyno'd the car yet as im still getting it on the road and everything sorted out. When i do i'll let you know how it goes.
Talking to the tuner yesterday and he said if didn't have a couple of hundred kilowats after driving it he said he would eat his hat
Can not wait to get it on the road although i have been re thinking it as a daily driver now!!!
I'm more interested to know why you decided to post this dribble in more than 1 section.
You haven't given any details or asked any questions. Whats the point?
As mentioned above i cut over half the post off after realising it was in the wrong section. Sorry to dribble BHDave, wont let it happen again :cuddle:
My question are:
other people with similar mods just wondering what kinda or power your putting out and how have you got the car tuned?
What is it like on fuel? ( as this is my daily driver)
Any tips on suspension set up and what tyres are people running?
I have other questions but iahve been told that i dribble on so dont want to get anyone's back up at all.
Cheers GMB
You better not :chairshot
Now 1.5 bar without exploding seems plausible.
Im guessing you have one of the original style td06 highmount kits with the extra injector mounts in the cross over pipe. Nice one.
Should easily be capable of 200rwkw plus, closer to 250rwkw actually.
Yeah tell me about it. As i only really just picked the car up (after importing it from Japan) it appeared to be running high boost.
As the boost gauge didn't work (split line from the joiner under the hood) i didn't know what it was running althought figured it around 12-13psi, but after hooking up my tuner's boost gauge it was actually boosting at slightly just over 1.5bar.
Yeah i got one of the original TD-06 high mount set up's with extra injector. (can see in pics)
My tuner recon's 240rwkw's should be pretty easy once we know what the car is doing.
Im still confused, u have all these mods, and dont have a boost guage?  wouldnt u think to put a boost guage on before slapping cash on other mods. ?  It can you know, be sorta handy ...
All the gauges that came with the car dont work. As i have only had the car for a couple of days im slowly working everything out.
As for slapping cash at other mods, the car came like imported from Japan. The only money i have spent is purchasing the car and importing it.
As for smart arsed remarks like that, keep them out of my posts. You got something like that to say, PM me. For any other advice/comments or questions then post away.
a GTR intercooler IS a FMIC...
:confused:
you've had all this work but it hasn't been on the dyno?
something doesn't sound right...
or did you buy the car already modded?
The GTR cooler is where the original intercooler is normally situated. It has been modified slightly to fit.
I will be buying a new FMIC when i can find either a kit or a good price on the cooler and piping.
So if you have the heads up then let me know.
WazR32GTSt i have bought the car as is from Japan, so all work done was buy the previous owner/s from over there. Im trying to get some info on everything on/in the car so when it comes time to tune and dyno then it will make life a little easier.
well the GTR cooler is normally quite a large unit, not sure how it would fit in the side of the front bar even with extensive modifications. must be a tight fit!
you could pick up a FMIC in the group buy section for like $300 i think. go have a look. or keep your eyes out in the for sale part...
the hardest part is piping. my suggestion would be to get an exhaust shop to custom-make you some pipes. works out the cheapest (if you are on a budget). if you aren't on a budget then check out www.modyourcar.com.au i think they have piping kits there...
oh, now i see
you should have said at the start of the thread that the car just came from japan!
i think we just asumed that you did the modifications yourself
yeah these cars can be a mystery sometimes with what has actually been done to them when they arrive.
it seems a bit of a coencidence that ALL gauges aren't working... including the stock ones?
if just the aftermarket ones maybe they were unplugged? or all linked somehow? i don't know.. maybe someone pulled a fuse? i'm not much of a gauge expert...
i hope you can manage 250rwkw will be nice to see the 'ol rb20 pull some nice figures
Warren.
oh, now i see
Warren.
yeah i would prefer to buy a kit that included everything, then there is no messing around. Been looking around and i think the cheapest i can find one is a R32 Hybrid copy kit with piping and clamps for $650 plus shipping.
Or i can buy the same core for $299 then piping???
Either way i'll look into it.
The intercooler is an extremly tight fit at the moment and thats why i want to sort that out asap.
Yeah sorry about the mixed post. I left so much out when i realised it was in the wrong area. :chairshot
omg that's a tiny rear muffler... what size is the exhaust??
i would attend to that too if i were you...
BWAHAHAHAA yeah its the stock muffler it appears at the rear.
Exhaust is 3" off the turbo then into the stock system. As previously mentioned it has the extractors set up on it and the external waste gate.
Want to look into an exhaust but very expensive in Tassie. :crazy:
What are the exhausts from Autobahn like, anyone got one on there car at all???
    • Hello, I'm trying to make this thread basically the thread with all the answers to common questions regarding specifically the RB20 DE NEO + T engine, that comes in the R34. Answers will and only should be provided by those who have done this conversion or actually have some relevant real life experience please. Please feel free to ask questions in the comments if you have any so other members can answer. I feel like this thread is really needed, especially with more Americans buying (unknowingly going to regret it too) rb20 neo r34s. My first question being - What do you guys use for tuning? I have purchased a haltech elite 2500 Plug and play kit for the rb25det NEO because the ecu plug is the same, but I am unsure if any of the pins would need to be repined to match. Second question that I see asked very often - After this conversion, did you install the boost solenoid/ actuator? I see many people doing a + T setup on their rb20 NEOs while running stock RB25DET NEO ECUs with no tune. I am wondering how they are going about doing that and consistently abusing the car because many of these people have had these untuned setups running for a very long time. That was my original plan, but my engine cuts out at 5 psi of boost using the stock ecu with no tune and no boost solenoid/actuator.
    • interesting. ive read and heard otherwise over the past year. ive been doing this +t conversion on a rb20 neo using all oem rb25det neo parts including the ECU, and im having engine cut out issues when I hit around 5 psi of boost. Everywhere/everyone ive asked has told me its because I never wired in a boost solenoid/actuator to the ecu, so the ecu isn't getting the right signal once it hits 5 psi of boost, causing the engine to get shut off.
    • Mate, I take this thread in random directions on occasion myself, so no foul I'm a old fan of MCM anyway, I like their banter, and enjoy most of the stuff they do
    • Something strange is happening. I didn't touch the car since we last spoke on the forums. Yesterday was the first day of good weather, so i took it out for about 2 hours. It started up on first crank every time about 5 times total. I literally didn't do anything to do the car.
    • I purchased this one. Very well priced and works great. I was rough with it to see if it will last and had no issues.  Teslong Two-Way Articulating Borescope with Light, Industrial Endoscope Inspection Camera with Articulated Probe, Flexible Mechanic Fiber Optic Snake Scope Cam for Wall Automotive Engine Inspect-5FT : Amazon.ca: Industrial & Scientific
