its amusing to see how scared Skyline owners are of fitting decent rims..... the ns boys cant get enough.
Yeh i hear ya Trent, wheels need to be sticking out to Fcuk well camber and even spacers, Pitty i just bought wheels, Oh well..... Good luck with the sale! :uh-huh:
different width front and rear on a gtr affects the attessea - spelling. if only they would fit on a gtst without much lipping/roling or guards.
Actually - the above is wrong.
ATTESSA takes input from front and rear wheel speed. This in turn relates to rolling diameter. It is therefore possible to use these rims by having different profile tires to ensure equal rolling diameter front and rear.
Personally I prefer to have the same width of rim and tyre to achieve this, but each to their own I suppose.
I do believe the width isn't such a problem, Its when you stagger 17" on front and 18" on da rear then the profile of tyre on top, and i'm pretty sure its all about the diffs being level. So therefore its all about the circunfrence of each wheel(tyre included) If they are the same then SHE no worry, In my eyes width is all good to be different, alsong as you account for the tyre profile.
would probably best consider widebody on a gts-t.
12's with 13mm offset will stick out rear guards on 32gts-t by a good 6cm or so. should be ok clearing coilovers though.
check out http://toy4two.home.mindspring.com/offset.html for wheel-offset calculator to compare your current rims with these
man, these rims are pimp! suprised they haven't been sold yet
good luck with the sale trent,
(lol @ skyline owners are scared of decent rims!)
-tim
who cares? ;)
DUDE you should care! being the face of AUTOBARN!!! If no one on here wants your wheels, maybe they are just not as HARDCORE :freak: as you, which reminds me havent seen you slide for a while...........(what happend?)
i dont see what the differnce is if you have 265/35/18 on the front and 285/35/18 on the rear they are still the same profile hight 35 so same rolling diamater, correct me anyone if im wrong.
the profile is not an exact sidewall height, as tyres get wider in same profile the sidewall gets higher also iirc (its one way or the other), even though would make an unnoticable difference to the speedo the attessa still picks it up.
Thats my understanding of it anyway
Jamie
The profile is shown as a percentage of the width.
    • I’m doing some side developments on SR20det S13 engines, its one my hobby cars used it to compare flow capacity of some smaller size wheels. SR20det is one of another JDM legendary engines I'm sure there are plenty of SR enthusiasts on this forum, I will share results some common turbo configurations here. a quick run down of what the car is: Wide body 180sx Type X with black top engine (blue). It has: Stock bottom end Haltech 1500 ECU 5-0 motorsports trigger kit Kelford SR20DET Beehive Spring with Titanium Retainers Kelford Cams SR20DET S13 188-B 268/272 Cams G25-660 Turbocharger in T2 .64 rear housing internally gated ARP Head studs MLS head gasket 1000CC ID injectors Walbro 450L Fuel pump Front mount cooler kit JJR’s 3 inches turbo back exhaust (its too short for the 180sx it had to be extended) Pump 98 fuel Hub Dyno tune So far made 270rwkws at 22psi full boost by 4500RPM. Engine is very knock limited hence a pretty bad looking top end. From previous experiences it seems like SR20dets are happier with bigger size turbine, some thing like a GT30 would make way better top end, but on same time response is lost. It won't be a problem with S15 VCT engines. I'll be testing alternative turbine housing, turbine wheel and possibly dump pipe options for extra flow to resolve the problem and of course E85 would resolve all the issues.
    • Awesome writeup and details. Thanks for sharing the story so far. I can relate to parts of it with my previous car and some of the issues I had to deal with.
    • Wow the colour matched hard top completely transforms the car. Are there any nice front lip options for the car or is that off the table?
    • Generally yes but for some reason I've been ruthless this time around!  I might even need to do another tip run after the way I've finally been able to hit the delete button on shit I've stepped over, stepped around and tripped over for the past 10 years!
    • I just quote the Rolling Stones. Paint it black.
