went cas other day after long lay off....
went in with $200 and i walked out with $1320 so i made abotu $1100
my biggest win ever! i was playin that 3 card poker for First time and i started bad lost like 60 bucks without evan playing a hand...then i moved onto another table and ripped three 5's like this 5 5 5 ahahha and i thought ohh no bad 3-1 maybe ...when they flipped my cards they were like WOW i was like hmm is that good? well 33-1 to one good and i won 380 on that hand...i hit about another 2-3 full house wateva it is called 35-1 it payed...so great game but prob beg luck!
we love you cas for now!
  • Replies 94
Played in my second No Limit Texas Holdem tourney last night at Clown.
Man it was amusing. Ended up finishin 23rd in a field of 217. Not bad a for a beginner if I say so myself. Sitting down playing for 3 hours with a 10 minute break was pretty stressful though.
so did you win anythign for finishing 23rd?
also i have a really saw neck....it sux when you gota piss also..and your on a roll...
Nah, just missed out this time. It paid down to 20th which was like $100. For a $75 buy-in, it's pretty good.
1st place paid 2k last night.
Damn that is good Leewah, well done :P
What happends if you do need a piss or something? can you just blind-off/autofold?
funny you mentioned that, i joked that i needed to go and needed a bottle... and the dealer said that many times ppl have pissed on the floor bcoz fo not wanting to lose their seat or ruin their winning streak.....
From what I could tell, you hold onto it.
I was busting by the time the 1st (my only) break came after 1.5 hrs of play.
thats not right, pissing on the floor, surely you'd get kicked out for that?
only one way to find out i guess....?
if you were a young guy pissed with say a couple hundred i would think so.....
but if you were in a tie n suit and had like thousands hmm then im not sure...
... I can just picture a group of high rollers all standing up for a break and having the 'Billy Maddison piss stains' on their expensive suits :Pimp2:
Its true, i saw it quite a bit. People dont want to leave the table so they just make a mess of everything, they think that they are lucky and if they leave their luck will run out. Happened to the dealer next to me one night, i was almost dry reaching!
Always thought this was an urban legend.
From what I've seen, people will always give up and go to the loo if they need to.
Disgusting if they don't.
"I pity da fool."
Your missing the $2.50 chips leewang, i'm just nitpicking..they look like good chips. I was playing black jack, well dealing actually yesterday with friends and showing them how to play, we also dabled in poker, i practiced my card toss. i got a long way to go before i get any good at that. So when are we going to put these to use?
why not get a real dealer?
i would do it for a slab
    • The max they would go for me is 50.
    • That cannot have been a fun set of drilling. The stock "baffle" looks identical to rb26, I just cut fuel cell foam to fit the full length under the baffle.
    • I understand your sarcastic exasperation. But to be fair - the baffles do indeed fit OEM cam covers. They did omit to say that you need to do a bunch of stuff. But they do fit them.
    • Got started on the modification to make these splash plates fit over the long weekend. First the surprisingly time consuming task of swapping all the cam cap bolts to Tomei cam cap studs. I did the method of removing one bolt at a time, applying loctite to the stud, double nutting to torque as the manual described. Then carefully unlocking the nuts without disrupting the torque of the stud (and going back to re-torque a few times when it slipped). Finally applying the nut and torquing to spec. Repeat x28 Next up I went about removing the stock cam cover baffle so I could ensure it was fully clean after drilling for stud clearance.  As the blind rivets holding the baffle on were domed I used a punch to mark the center then used 4mm drill bit to carefully drill out the rivet without going too far part the baffle. As seen in other thread here is what is inside the stock baffles I decided on M4x6mm bolts to bolt the baffle plate back on with. I used a 3.3mm drill bit with some tape to mark the depth at ~8mm. Next was to tap the threads using a cheap bunnings kit M4x0.7. With the baffle removed I also drilled out the spot welds holding in the baffle plate oil returns. Unsure whether this was the best option or if I should have cut holes in the Hypertune splash plates to allow the oil drains to still function... time will tell. I then removed the the Hypertune splash plates so I could rest the cam cover on top and use a dab of grease to mark where the studs impacted the oem cam cover baffle. The most obvious spot was on the hump from the stock mesh is held. Using this hole as an anchor I bolted the oem baffle plate back into the cam cover and lined up the Hypertune splash plate. Marked the rest of the holes for the studs and drill those out too. Total 32 holes drilled and 12 threads tapped on the passenger side cam cover alone for this bolt on part that totally clears all OEM cam covers.. Drivers side next as well as some E85 safe fuel foam to fill the space behind the behind cam cover baffle plates. oh and some lock nuts for the splash plates of course.
