just recently my oil gauge stopped working which i think is just a oil pressure sendor but now my oil light comes on but only when the revs drop below 1000 rpm what do you think could be causing this my oil levels are full i have one idea which might be that the oil wasnt suited for my car and now its thinning out a bit from the service which is 1500 ago and causing it to do this ? what do you think.
is it the sendor which is causing my light to come on or what
Could be, seems coincidental that the gauge stopped working and now the light is on. If it truly had zero oil pressure at idle, then the hydraulic lifters would be rattling their heads off. Since you haven't mentioned that, the most likely suspect is the sender, so time to replace it. When the gauge is working you will have a better idea of what the oil pressure really is.:)
PS; if you want to check that it does indeed have oil pressure, take the oil filler cap off while it is running and make sure there is some oil moving around the cams.
proly the sender, on my rb20 s13 install i wired up the r32 cluster into the car.
all gauges worked but my oil was always a bit weird.
it would register pressure and all but if revs dipped down it would say i had no oil pressure.
now in my s14 the only time that the light comes on is when the car is shut off (new pressure switch).
    • Factory LSD is supposedly a 2 way with a very conservative cam. If you've already tried adding friction modifier to the diff oil and it still locks up too much for your liking you might want to adjust the ramp rate on the cam to be more like OEM instead of reducing initial torque even further. People claim the 8 kgf-m disc kit for the OEM LSD is still very streetable but I've never been able to compare everything side by side on my own.
    • Oh man, at least it sounds they've accepted they stuffed up and not put it back on you...could see some confusion if they asked if it had a hardtop or not, and you've answered truthfully but maybe not answering their real question which is what roof did it have from the factory! Glad your keeping it N/A 2.5
    • Nah, I much prefer colour matched Talking about colour matching stuff, the new/used boot lid turned up, all painted up perfectly......aaaannnndddd, it's for a power retractable hard top, not a soft top.....LOL They are now sending a boot to fit a soft top.....,  whilst frustrating, life is like that sometimes, sometimes you just need to dodge, duck, dip, dive and, ummm, dodge.
    • You would need to paint your hardtop again though
    • I have an old R32 in the shed that hasnt moved much in the last few years and probably should see the light of day. At one point I had a Nismo 1.5 centre put in the rear diff. It is a clunky nightmare POS of a thing on a good day. To make it less painful the initial torque setting has been put on the minimum (7.0kgf-m, mid is 9.5, high is 14) and the oil changed out to something more slippery. But it is still awful and ruins the vibe of the thing. So my questions are: Given I have the original parts sitting in a box somewhere would it be better to rebuild the thing again, reverting to more purity? Is there a standard kit or do you just go and replace the friction plates etc and shim it the way you like it. How much initial torque does the standard R32 rear diff have? Or does the Nismo disc kit offer a better solution - the caveat being the initial torque for both options appears to be higher than the clunky 1.5 way. There appear to be two Nismo disc kits: 3843S-RS520 for 8kgf-m. 3843S-RS521 for 12kgf-m. Or is the easiest solution to reshim the Nismo diff to make it looser?
