Help
Rb25Freak
 Share
Ok I really want to get out and have a go at a track day. A week ago I went out and bought a new helmet and was planning on going out to the track that weekend but I cam across a little problem no rather a big problem. When I sit in my 33 my helmet hits the roof, and as you could imagine it is very uncomfortable just sitting there. I would hate to feel what it like while driving around a track.
There has to be a cheap alternative to get the problem fixed with out buying a fixed racing seat. So that’s were I need your help.
Is there a way to lower the standard 33 seat.
It would be much appreciated for some help.
cheerz
there are two circular things on the side....one adjusts the front of the seat and the other adjusts the rear...
it lowers the seat slightly... try that first...
heh...same happens for me :( i didn't realise until i was in the car ready to drive out on the track :P
Try tilting the seat back a little, and dragging it forwards (though this not the best option as far a keeping your hands on the wheel is concerned :)
 Share
    • From there, as the manual says....assembly is the reverse of disassembly, no tricks worth mentioning Much better (for me)
    • In my case, the standard wheel I had was in good condition but the buttons had more wear, so I swapped them across from the original wheel from the car. The plastic rear cover is held on by 4 tabs, and once the wiring is removed you can get access to 2 screws on each side the hold the buttons in From there I just swapped the wiring over. What was interesting is the standard style wheel is 2.0kg but the carbon fibre one is 50% heavier at 2.9kg. It even has a weight inside the wheel at the top to make up for some sort of imbalance in the design. weird
    • Once the airbag is off, to remove the steering wheel.... Undo the 2 plugs into the clock spring, and the horn connector from it's clip. Hit the 19mm nut with a rattle gun (preferably) or if you don't' have one, you probably want an assistant to hold the wheel in place while you use a breaker bar to undo the nut Then, screw the nut back on 3 turns, and pull the wheel sharply towards you. If that doesn't work hit it medium force with a rubber mallet on either side, or possible behind if you can get there. If that all fails (it shouldn't!) you might need a steering wheel puller
    • So, to next task....the carbon fibre steering wheel was either an expensive factory option or a chinesium special. Either way, I don't like either the flat bottom or thick ring style, so it had to go So...to remove the steering wheel.... First, disconnect battery negative and stomp on the brake pedal for a few seconds. Then, remove the small circular covers on each side of the wheel's rear surround to uncover the airbag clips. You need to push something like a flat bladed screw driver through, to push the steel clip inwards and pull the side of the airbag forward. Once you've done the easy side, same on the centre console side. You can see the tab you are shooting for circled in red Then, disconnect the horn spade connector and for the yellow airbag plug you need to get something small under the black locking tab to pop it out, then the connector releases......airbag is off
    • @99RS4just wondering if you ever took photos of the footwell lighting / how you bypassed the controller, im keen to haver footwell lighting come on when I open the doors too
