gun32gtr Posted June 3, 2005 Share Posted June 3, 2005 hey all, ive done a search and couldnt find much on what i need to no so here goes. my gtr makes loud ticking noise from head all the time and goes up as revs do? 1-is this my lifters and there worn? 2-could it just be a sticky lifter and needs a clean? 3-and is if lifters are worn will this cause engine problems if not fixed? ive just done oil and filter change,used mobil 1 0w 40?dam dear shit? any help would great and sorry if has been covered just say so and ill keep looking?cheers gun32gtr Link to comment https://www.sau.com.au/forums/topic/75706-rb26-lifters/ Share on other sites More sharing options...
gun32gtr Posted June 3, 2005 Author Share Posted June 3, 2005 bump come on ne one Link to comment https://www.sau.com.au/forums/topic/75706-rb26-lifters/#findComment-1389548 Share on other sites More sharing options...
Fitzpatrick Speed Works Posted June 3, 2005 Share Posted June 3, 2005 GTRs make this noise standard as they are set with such a large lifter to cam tolerance around 18thou in the old language or .35mm which is a really big clearence and causes them to tick away. Usualy people over react but yours could be louder than normal and i wouldnt worry about it as it is a really big job to fix. If your dead set checking it pop the cam covers off and with a feeler gauge turn the engine over and on the base circles of ever cam lobe check the clearences. If its over 22thou you probably should re shim it to close the clearence but check it first and if you have any probs post here as it will require a massive post to explain how to fix it......Hope this helps. Link to comment https://www.sau.com.au/forums/topic/75706-rb26-lifters/#findComment-1389585 Share on other sites More sharing options...
gun32gtr Posted June 3, 2005 Author Share Posted June 3, 2005 mate thats great its not to loud.cant here it over exhaust note just when all windows are up ill get off the gas and just roll u can here it?does that sound normal?thanks for the help mate Link to comment https://www.sau.com.au/forums/topic/75706-rb26-lifters/#findComment-1389615 Share on other sites More sharing options...
Fitzpatrick Speed Works Posted June 3, 2005 Share Posted June 3, 2005 yeah you usualoly cant hear it in the car only when like you said you roll and everything nice and quite you might just notice but on all gtrs its pretty noticable once you pop the hood!!!! Yours I would say sounds pretty normal to me! Link to comment https://www.sau.com.au/forums/topic/75706-rb26-lifters/#findComment-1389741 Share on other sites More sharing options...
Cubes Posted June 3, 2005 Share Posted June 3, 2005 The Rb26 runs solid lifters, or more correctly called followers. Link to comment https://www.sau.com.au/forums/topic/75706-rb26-lifters/#findComment-1389745 Share on other sites More sharing options...
gun32gtr Posted June 3, 2005 Author Share Posted June 3, 2005 thanks fellas just makes things a hole lot better now dont have worry that my car is going to shit itsself now thanks again Link to comment https://www.sau.com.au/forums/topic/75706-rb26-lifters/#findComment-1389937 Share on other sites More sharing options...
