can anyone run me thru the procedure to remove and clean my FMIC
I have an R32 GTR and I was getting a LOT of blow-by before my engine rebuild. I drained a heap of oil out of the std BOV pipping - and expect a good deal of oil is still trapped in the FMIC and pipping.
1: what's the steps to remove it
can I get it off just by removing the front bar
2: what should I use to clean it
I've herd metho is the go as is evaporates quickly and will not react with the alloy
3: how long will it take
can I get this done in a day - or will the FMIC take longer to dry
4: or should I just take it up to ARE and get them to clean and flow test it for $165
https://www.sau.com.au/forums/topic/75735-remove-and-clean-fmic/
Should be easy to do yourself. (have you taken the front bar off yourself before? this would be the hardest bit)
Once the bar is off you have easy access to the clamps and brackets.
I used petrol to clean mine out (I think it picks up the oil easier than metho (metho is an alcohol product, and petrol is an oil base product - Like disolves like as my yr 12 chem teacher would say)
Leave it to air for an hour in the sun before putting it back on.
If the cash isnt a problem, its always easier to have someone else do it, but I enjoy the personal satisfaction of doing it myself.
PS - my car is a 33 gtst so someone else with a 32 GTR may be able to confirm how easy the job would be if the front bar was left on.
    • I would paint match the whole thing to avoid unwanted attention  I had a similar bonnet, paint matched, on my old R33 GTST, but mine was a fibreglass jobbie made by Blitz in QLD, they work extremely well for radiator efficiency and under bonnet temps
    • Does anyone run this kit with factory plenum? Does the adapter and bosch tb fit under factory strut brace? I wanted to get this setup before going forward facing manifold. Thanks
    • small update time, after always wanting a "cool" looking bonnet for my car and always struggling to find one for the series 2 that i liked and wasn't an insane amount of money. Saw one i liked on RHDjapan from D-speed in Japan the price was very good for a carbon bonnet so good infact i was a little unsure how much i trusted it, decided to bite the bullet and with the help of jesse streeter in not long at all it was at my door. Once it was delivered i ran in from work and quickly unboxed it and to my surprise the quality was actually pretty good i quickly removed the old bonnet and placed on the new one to test it out and even the fitment wasnt too bad at all. Then decided to paint the little grille in the bonnet black to stop it sticking out so much.   I decided to not mess around with the hood latch and just install some aero catch hood pins, having never installed them before did some YouTube university classes and i was good to go. fair to say it is not a fun job at all from making brackets so the pins sit nicely and actually cutting through the bonnet but also being very scared of cutting the holes too big it took wayyyy longer than i would like to admit but finally got it there. Then it was time for a quick test drive to ensure the latches actually worked and thankfully the bonnet looked very stable. I still think paint matching the bonnet and leaving just the part that sticks up as carbon would help make it all look alot neater as im not sure how i feel about all that carbon on a very fridge white car but will leave it as is and see how i feel with time.
    • I think it's bound to happen, you finally get it all perfect, and bam, something will happen. I took a while to get a Commodore rear quarter repaired where a P Plater clipped it. Two days after getting it back, Sarah wiped it out on a concrete pillar in an underground car park... This is why I take forever to repair them, it stretches how long until it gets bent again... 😛
    • Nah, not really responsible for that little fiasco, but I'm still pissed at myself for writing off my 86, or when I reversed my VX into a pole just before selling it, but, meh, 5hit happens to stuff, all it takes is a slight distraction, and life is full of distractions, and "dooh" moments
