Hylomar aero grade gasket joining compound RRP Price (AUD): $50.00
Non hardening and non setting. Unlimited assembly time. Vibration resistant. Allows metal to metal contact. Resistant to combustion products, water, engine coolant, petroleum, lubricating oils, kerosene and fluorocarbon refrigerants. Seals surface imperfections. Withstands rapid variations in temperature. Flame, dust and moisture proofing properties 100gm Water and oil pumps, instrument inspection covers, cylinder heads and sumps. Coating pre-formed gaskets, weatherproofing motors and outdoor high voltage circult breakers. Inlet manifolds, timing case covers, oil pump joints, gearbox and transmission components, thread sealing. Gas turbines, water cooled generator, turbo vacum systems and any machined surface.
they come in 100g tubes like a big tube of tooth paste i purchaced a box in from a mate in england. i am selling fifteen tubes may be more depends on how much i use he he @ $15 free postage this stuff is definatly top of the line thats a huge saving
these tubes will be avaiable untill 2nd july 05
https://www.sau.com.au/forums/topic/75739-aero-grade-gasket-joining-compound/
Hi mate,
I'm after enough compound to seal 4 gaskets. 100g is around the size of a medium toothpaste tube right? Put me down for one please and let me know the banking details.
Thanks!
Mark
Hi mate,
Thanks!
Mark
hi mark i did two skyline engines rocker covers with one tube and had a little bit to spare. I will pm you with the bank details the new price is $15 deliverd to your door
thanks Dave
some info from the technical data sheet
HYLOMAR AEROGRADE (PL32)
Aerospace version of Universal Blue
Description
Hylomar Aero Grade is a highly engineered, polyester-urethane based non-setting and non-hardening
gasketing compound, for use in the aeronautical industry. Hylomar Aerograde was developed in
conjunction with Rolls Royce - Aerospace Division for sealing joints in jet turbine engines. Hylomar
Aero Grade can operate at temperatures from approximately –50°C to + 250°C.
Guest
    • Hows your intake piping? Are you still running stock? Having in the stock AFM position would mean, if the BOV was shut/venting out, it'd create the almost stalling kind of effect right // "the rich pulse behaviour" due to MAF thinking air is flowing ? But this would be better than having the bov in the stock position + MAF on/just before cross over piping right?
    • Essentially, yes. Although I wouldn't put the AFM on the crossover pipe. I'd want to put it into what amounts to the correct size tube, which is more easily done in the intercooler pipework. I bought a mount tube for card stile AFM that replaces the stock AFM - although being a cheap AliExpress knockoff, it had not flange and I had to make and weld my own. But it is the same length and diameter as the stock RB AFM, goes on my airbox, etc etc. I don't have a sick enough rig to warrant anything different, and the swap will take 5 minutes (when I finally get around to it and the injectors & the dyno tune).
    • So to summarise, the best thing to do is to move recirc to between turbo and IC, and maf on the crossover pipe. Meaning I'd need a recirc flange, drill a hole in the piping on turbo outlet area. And drill hole on crossover to fit/weld maf sensor? Either that or put the MAF on the turbo inlet right?  Is an aftermarket recirc/blowoff valve recommended? Do currently have family in Japan so could probably bring something back with maybe a cheeky lil SuperAutobacs run?
    • Yep, so far most have said that it looks like corrosion on the wall from piston not moving. Which then has probably damaged the oil rings and caused those vertical marks. The longest the engine was still after the rebuild, was the winter of 2018 - 2019, plus the boat trip to Japan. When I shipped the car, it had normal gas in the tank but before that winter pause, it had E85 in tank.  In any case, even if either one of those was the cause, it happened close to 6 years ago and the car has been driven something like 30 000kms after the fact. Again, apart from the plugs and the dip stick, there is nothing in the way the car runs that would indicate what has been going on in the engine. I am going to consult a shop and ask their opinion, what would be the best approach. I do have some access to a garage I could use to diagnose further myself, but time is very restrictive. Might end up buying another engine that could be used while this one is being remedied. Without pulling the head, it will be impossible to find out if it needs another bore, but here's to hoping a hone would suffice.  Goddamnit, I would really have preferred this not happening.
