Hi everyone
I got my new car yesterday and i noticed a couple of times when idling it will just start adling up and down without anything being touched after a while and sometimes it will sit at around 800rpm steadily and then sometimes around 5/600. Is something wrong? or do they just have dodgy idle sensors or something cause my last 1996 series 2 gts-t didnt do it but this is a 1995 gts-t
https://www.sau.com.au/forums/topic/75777-upand-down-idling-s/
Usually, a problem in the TPS is a constant high (around 1500 - 2000 rpm) idle. Usually caused by the sensor getting out of alignment and not sending the "throttle closed" signal to the ECU.
Variable idle is usually caused by a dirty / sticking AAC valve. That's the little cylinder on the back of the plenum chamber. It can be removed, disassembled and cleaned out with a bit of Car-B-Clean, then re-assembled and re-fitted without too much drama.
could be a vacume leak,
blind elk, thats true however my tps was out of wack in the other direction, what would happen, is it would idle fine, but you woul pull up to a stop sign, dip the clutch and the idle would **** around for a few seconds, worth checking, also the
and low speed driving was a bitch, car runs like crap, i dont think it will see 100% throttle either when you nail it
if your going to adjust idle , disconnect the brown plug on the solinoid behind it when your finished, reconnect it
Just had my 33 serviced not even a month ago, and after 3 mnths of pretty crappy idling, apparently a vacuum leak near idle starter motor was fixed, afm cleaned, tps adjusted, and timing reset.
Just last week it started ranging again from like 200-1200 rpm up and down as if i was stepping on and off the accelerator...
I have a non-oil blitz pod filter, and a blitz 3inch exhaust.
Any ideas on what else could be causing it in my particular case would be appreciated.
Cheers
-Serge
    • It's kind of interesting - They definitely do builds that split the difference between what they like and what will generate views and engagement. The NC Platform always surprises everyone in a good way, in an uncomfortably good way some may say. They could throw a LS in there and arguably have the best (and best performing) car of the entire stable. But that isn't necessarily what draws views, because people viewing don't want to accept the vegetables of a LS NC MX5 being a superior vehicle in every way (including fun) than a RB26 240Z. This is also why there's not a lot of content about the GR Yaris (on the web in general). They're too good, yet 'only a Yaris' The community doesn't want certain cars to be as good as they are - to beat their hero cars, and I believe the NC MX5 is absolutely one of those cars.
    • Yeah - My key still does the chime thing. I followed the procedure but it didn't activate on the (identical) third set of keyfob that I had. I vaguely remember the alarm saying you can only pair two keys with it. Now that I've dug it up, it appears that you very much can pair keyfobs to the alarm system. (which are the fobs I use to unlock the car). I have successfully diverted the thread and can probably not use the OEM keyfob ever again unless I use the aftermarket alarm and attempt to pair the OEM keyfob to it. Which might just work, or not :D. I definitely used the nissan method and not the aftermarket alarm method.
    • What makes it worse is that Nissan made keys in the same style, for example R34 and Stagea, but they work at different frequencies or something like that. So they look the same but the remotes are not interchangeable. I learned that from some guy selling aftermarket blank keys.
    • Does your door chime work when you have the key in the lock and open the door? I've had that disabled because it's f**king annoying and it is one thing that messes with the pairing. Because now the car doesn't detect key in ignition anymore and the slide-key-in-and-out sequence does not trigger the pairing mode anymore. The service manual has a section on the various bits involved in doing the syncing. I presume it'll be similar between Stagea and R34.
    • Agree, but meh, I think is is based more on LOLS than actually apples to apples, like, who would have thunk a turbo 4 cylinder would not beat a NA 4 cylinder  I think with just basic N/A mods, like a exhaust and tune, it would be equal to the Mini in its current form, maybe I know my current 2.5 would "chop the mini" as the midrange now has a night and day difference in power delivery compared to the tuned 2.0, by around 20kwatw and 30nm from around 2k rpm "ish"....... I'm kinda hoping that they do a N/A build, either with the MZR 2.0 or with whatever they decide to use If I recall correctly they did talk about K swapping one a while ago
