Originally posted by RoboPope
I dont mind what you get up to in private, so long as you are not ramming it down my throat. :(:P
The greeks have a lot to answer for, Nana Mouskouri for one thing
hehehe.... we don't ram around here. Minh likes to shove it and choke people with it. Most of us are on the recieving end.
thank you... sorry to raise the tone of this thread but there seems to be a much bigger GTS scene over here than in the UK. what power / mods do you all tend to run out here?
Paul
I think the majority of us over her are just looking at the
200+rkw mark.. which is basically exhaust, cooler, filter, boost
controller, computer, fuel pump.. i think thats about it.. cause any
higher will result in big $$$..
You will get the few who make it past this mark.. off the top of my
head.. Merli? 270rkw?
I'm pretty sure its the same as over there as i've read a few
UK sites which basically recommend the same upgrade options.
What are u running Paul?
We must listen to Minh.. 400hp at the lips gives quite a bruise!
:bahaha:
Mine currently has filter, exhaust, decat etc and an fcon V. it pops out a sneak over 300bhp @ .78 bar (flywheel, but im not sure how to equate that to yours) with the injectors at 90%. It has a hybrid needle roller turbo from turbodynamics but i cant raise the bost pressure enough for that to have any real effect over the standard one yet
Jan 4th its booked in for a HKS fuel pump, Tomei injectors, HKS FMIC, HKS Steel head gasket and boost controller should make a bit of a difference once the boost is cranked up a bit, shall have to wait and see.
Must admit the cost has sort of put me off doing too much more though unless i can pick up a RB26 engine with some trick internals at a sensible price
It does put a smile on my face though :( any increase in power is directly equated to increase in size and duration of smile
Paul
    • That ring thing is interesting how it's holding everything together
    • Hey guys. I have a 400R on its way to Australia from Japan currently and have a few questions I’m hoping others may be able to help with.   Wondering if anyone here has had any luck getting the Sat nav unit to work in Australia!? Assuming the Stereo is as simple as a band expanded and tv won’t work?  Seeing as they’re based off a Q50 which is Aus delivered is there any way to link that system to the nav? Nav modules and head unit are different part numbers and appear slightly different at the rear with plug ins etc. can I put my xtrail sd card into the rv37 and will that convert the maps or update to Australian? Has anyone got any advice here?     also has anyone fitted the factory remote start and Security system once it’s landed in Australia? I put an enquirey to Nissan Japan in via a third party, and they suggested it needs a Nissan Japan dealers device to setup and couldn’t guarantee if one here could do it or not. They can supply and I can physically fit it but to setup I would need a dealers device. Any information here would be appreciated also. I’ve seen one here with it fitted already prior to leaving Japan at a dealer/inporter, so clearly passes compliance and works when fitted Japan and doesn’t need changing here.      also, does the tyre inflation sensors work here? Does anything change with them when the vehicle arrives? Where are they actually situated? I’ve read they have batteries and they need to changing at times and seems like resetting involves the nav system?    any help here would be appreciated and any other aust specific information to help would be great. Looking forward to see what the current generation skyline is like and eager to see how many of the gadgets can be utilised here.  Thanks in advance
    • Do need to take it with a pinch of salt. One of the adapter failures, they clearly had setup issues with the flywheel.  One of the slipping ones I spoke to and it was pretty clear the throwout was riding, rather than fix, just swapped to a new clutch.    These clutches are being put in anything from 5k offroad 4x4 beaters, GR yaris, 500hp commodores to 1200hp barra monsters. Bound to be some issues in some of them when they are not a simple bolt in affair due to the changes in height.    There is a lot going on in this picture and unless I did the job myself no way to tell what really happened.
    • I did this mod in 2019  You just have to modify the top bracket of the ABS/TC/Fuel Pump Control ECU so it sits more upright and closer to the back seat and run a good quality positive battery lead from the engine bay, the negative lead i just bolted down to the body in the boot.
    • Damn... Not the feedback I want to hear.
