williamsf1 Posted June 4, 2005 Share Posted June 4, 2005 G'day all! I have searched and searched for detailed instructions on here..... but alas, nothing with any detail to help out the guys fitting it! I am currently not in australia, so it makes it hard communicating to the people charged with fitting my pump anyhow, if anyone has fitted an 044 in tank, with no dramas and can post a detailed fitment instructions I will be most greatful!!!! basically my car isnt going anywhere till I can get this pump in, and my next thread involving the AFMS! cheers.... Link to comment https://www.sau.com.au/forums/topic/75783-mounting-044-bosch-in-r32-gtr-in-tank/ Share on other sites More sharing options...
williamsf1 Posted June 5, 2005 Author Share Posted June 5, 2005 BUMP help Link to comment https://www.sau.com.au/forums/topic/75783-mounting-044-bosch-in-r32-gtr-in-tank/#findComment-1391950 Share on other sites More sharing options...
MidnightGTR Posted June 5, 2005 Share Posted June 5, 2005 I dunno man, but if your so called mechanics cant even fit the fuel pump id be going elsewhere myself. Im no mechanic myself, i know they arent straight fit but my mechanic had no problem mounting it, might be a little bit of working out to do but thats what your paying them for. Link to comment https://www.sau.com.au/forums/topic/75783-mounting-044-bosch-in-r32-gtr-in-tank/#findComment-1391995 Share on other sites More sharing options...
williamsf1 Posted June 5, 2005 Author Share Posted June 5, 2005 my thoughts precisely..... seems to be a "bolt on boys" place... however they do a very good tune job just need to learn the aussie way of engineering things to work well, and not just off the shelf :) no real grumbles, they are top guys! just need to give them the right info so they will know how to do it.... I think 1 hour is all that is needed.... Link to comment https://www.sau.com.au/forums/topic/75783-mounting-044-bosch-in-r32-gtr-in-tank/#findComment-1392263 Share on other sites More sharing options...
boj01 Posted June 5, 2005 Share Posted June 5, 2005 From memory, they will just need to used the standard sock from your original GTR Fuel Pump. Then use male/female type terminals to handle the wiring side of things. Then all thats left to do is mount the pump on the bracket in the same position the original pump came from with a large hose clamp. Link to comment https://www.sau.com.au/forums/topic/75783-mounting-044-bosch-in-r32-gtr-in-tank/#findComment-1392273 Share on other sites More sharing options...
180bfj20det Posted June 5, 2005 Share Posted June 5, 2005 YoU considered anti surge tank and going external? Link to comment https://www.sau.com.au/forums/topic/75783-mounting-044-bosch-in-r32-gtr-in-tank/#findComment-1392282 Share on other sites More sharing options...
7heavn Posted June 5, 2005 Share Posted June 5, 2005 Hey mate Had my car down at Bel's the other day while they were sorting out your pump the 044 is certainly alot bigger then std and won't go anywere near being able to sit in the stock craddle . We thaught we would be smart and pull my pump out to have a look but turns out my pump is just standered . That was a few days ago do they have it mounted now ?. G'day all!I have searched and searched for detailed instructions on here..... but alas, nothing with any detail to help out the guys fitting it! I am currently not in australia, so it makes it hard communicating to the people charged with fitting my pump anyhow, if anyone has fitted an 044 in tank, with no dramas and can post a detailed fitment instructions I will be most greatful!!!! basically my car isnt going anywhere till I can get this pump in, and my next thread involving the AFMS! cheers.... Link to comment https://www.sau.com.au/forums/topic/75783-mounting-044-bosch-in-r32-gtr-in-tank/#findComment-1392286 Share on other sites More sharing options...
williamsf1 Posted June 5, 2005 Author Share Posted June 5, 2005 Hey mateHad my car down at Bel's the other day while they were sorting out your pump the 044 is certainly alot bigger then std and won't go anywere near being able to sit in the stock craddle . We thaught we would be smart and pull my pump out to have a look but turns out my pump is just standered . That was a few days ago do they have it mounted now ?. Hey mate, I'm not too sure on the whole "where are we now" as its the weekend, and I'm still in singapore but will be back in sydney late monday night.... back to the pump issues, I have it on very good authority from both paul and stace, and also SK that all that is needed is it to be mounted in the factory cradle after slight massaging of the mounts, then a relay added to the system... I have given them paul's contact as he is more than happy to talk to them about it.. and to quote him " its a 1 hour job easy " as for the only other drama I think they are having problems with the AFMS? I cant see why? as they should squeeze over with the stock rubber being streched, and then the new apexi filters bolted to the front.... as SK said to me " 2 90 deg brakets to the stock holes and you are done!" good to see you were there to see how it was going..... I hope to have it all sorted by mid week and tuned ...... I am 100% sure the pump and AFMS are a simple job, it is as they say "simple when you know how" ... I just dont want to end up with the bill for the learning experience.... as you could understand naturally.... Link to comment https://www.sau.com.au/forums/topic/75783-mounting-044-bosch-in-r32-gtr-in-tank/#findComment-1392568 Share on other sites More sharing options...
Mintie Posted June 5, 2005 Share Posted June 5, 2005 i have fitted a 044 ext fuel pump intank in a r33 gtst not sure if gtr is the same, the hard part is finding the hose for the fuel intake from the bag to the pump intake. u need to modify the rail that the fuel sit on and try to make the bracket for fuel pump smal as you can.. good luck Link to comment https://www.sau.com.au/forums/topic/75783-mounting-044-bosch-in-r32-gtr-in-tank/#findComment-1392592 Share on other sites More sharing options...
GTRman1992 Posted June 7, 2005 Share Posted June 7, 2005 I have one installed in tank on my R32 GTR. Got some fittings from Pirtek and did some machining to make the filter fit nicely. Used a BIG cable tie to secure the pump in the factory cradle and also got another fitting to attach the pump to the fuel hose. Disposed of the check valve that comes with the 044. To be sure we ran heavier cables as the 044 draws more current than the standard pump, and put in a new relay that is switched by the factory relay. It works fine. Only took a few hours. Link to comment https://www.sau.com.au/forums/topic/75783-mounting-044-bosch-in-r32-gtr-in-tank/#findComment-1395047 Share on other sites More sharing options...
2rismo Posted June 7, 2005 Share Posted June 7, 2005 Sorry, BEL couldn't fit the pump?? WTF?? Not being a mechanic is no excuse. I'm in a totally unrelated field and I could do it. WTF?!?!?!? Adrian Link to comment https://www.sau.com.au/forums/topic/75783-mounting-044-bosch-in-r32-gtr-in-tank/#findComment-1395117 Share on other sites More sharing options...
Steve Posted June 7, 2005 Share Posted June 7, 2005 http://www.skylinesaustralia.com/forums/sh...light=Bosch+044 pretty sure it covers in enough detail Link to comment https://www.sau.com.au/forums/topic/75783-mounting-044-bosch-in-r32-gtr-in-tank/#findComment-1395194 Share on other sites More sharing options...
williamsf1 Posted June 7, 2005 Author Share Posted June 7, 2005 All sweet, fitted with no dramas... usual story, just need the right info the first time, and then you can do it time and time again.... thanks to all who helped out!!! Link to comment https://www.sau.com.au/forums/topic/75783-mounting-044-bosch-in-r32-gtr-in-tank/#findComment-1395446 Share on other sites More sharing options...
