I'm running about 9-10psi but in 2nd gear the boost tends to trail off quite a bit after about 5000rpm. I reckon probably to about 6psi.
I have tried a couple of different boost control methods...all the same. I think it happens when it is stock aswell.
Feels a little flat whereas before it really took off after 5000rpm.
All the hoses seem fine. Could the actuator have deteriorated?
There is a couple of missing manifold bolts. Can't hear a leak though. Intercooler pipes etc are tight.
I've got a 3" dump/front and 3 1/2inch cat back (kakimoto)
Bugger about the manifold bolts. I can't hear a leak. It is the front most bolt and the rearmost. I can see a tiny little soot around the front one but the rear seems to be still sealed perfectly..
Al the other bolts/studs appear to be intact. It just seemed to have more power up high when I first got it about 6 months ago.
Not looking foreard to pulling the turbo off. Also the rear stud might be hard to drill out (need compact drill???)
Thanks
    • I think you're missing the point here Duncan, I was trying to say that if you want to go fast around and have a spare $80K to $100K, easiest option is to just buy another car instead of modding your Skyline. Sure blowing $80k to $100K would make it fast, but then you'll have a car that you can't drive on the street comfortably. But use that $80k, buy a fast factory car, spend like $7K on AliExpress pipes, email tune, tyres, pads and you can be fast, not to mention now you have two cars.
    • You're 20 years too late mate. Used to be 80% skylines back in team trackday days
    • There's a lot of drug money on that side of Sydney. Just sayin'.
    • At SMSP, I mainly see Hondas, M cars, A90 Supras and of course, plenty of Evos. Have not seen a single R32 ro R34 Skyline on the night sessions that I've been to. That's really saying something.
    • I like mine. Much better than stock. Like i said before the reverse/parking cameras look even worse than normal, still useable. When you buy one make sure it's the latest version. Heaps of cheap ones that run the old hardware and software. Got mine from AliExpress. Mine is quick no lag, boots up 1-2 sec. Menu is fast. Netflix is fine and so is YouTube. Android Auto is random taking 3sec to 15sec. Most of the time it's quick. Very rare it doesn't connect. But that could be a phone thing.   Now I think they use a Pixel 3XL to run this whole thing which i guess is fine, but the problem is that some apps will not work on old hardware like Disney Plus  Maybe Prime Video too 🤔. they will not update. Iv'e tried getting the APK Disney + but i still couldn't get it working. I have a Data sim installed so i have internet all the time. You can't Hotspot off your phone and connect Android Auto at the same time. Not that you need too, if you want you can hotspot off your phone and run any internet map app (google maps) and you can run the Spotify app on it's own (the app runs better than android auto) You can still access the INFINITI intouch system for all the o.g stuff    P.S i got new non Polarization Sunglasses too 😎
