400HP,
As usual with most coil-overs they come in variety of different types from stiff to very stiff, and some with bound and rebound adjustment. They use these on V8 supercars and other high performance racers. They are extremely well made, but just buy them for a purpose, not just to lower the car.
I have full racing coil-overs in mine, which are very stiff on the road, but excellent at high speed cornering.
See'ya :burnout:
https://www.sau.com.au/forums/topic/7581-ohlins-coilovers/#findComment-111031
I have a set on my 'line. I personally think they are awesome. Not harsh kidneybelt material. I haven't tried them on the track - a few more mods before I head down that street, so to speak. Roadholding is excellent, height adjustable via a circlip type setup, adjust in about 5mm increments (I haven't acutally measured them). There is a damper adjustment on the rears -mine is set to four for general street driving and that seems to work fine. I do believe that they are a bit rare on street cars 'cause new they are around 1g a corner, though I got mine alot cheaper second hand. To sum up, I am very, very happy
Steve
https://www.sau.com.au/forums/topic/7581-ohlins-coilovers/#findComment-111139
I'm sorry, I dont know what model they are. I got mine for $1300 in what can only be described as excellent condition - bought them through a tuning shop but that price was alot cheaper than normal 'cos I have been dealing with them for a while. Another thing with Ohlins is that they can be rebuilt in Aust, so it might be worth checking out how much for a full rebuild, as you can pick up Ohlins for alot less than what I paid. I have seen examples for as little as $900 in the for sale section on this site.
Edit: try www.ohlins.com
https://www.sau.com.au/forums/topic/7581-ohlins-coilovers/#findComment-111582
    • I made a little more progress last night and added some E85 safe fuel tank baffle foam in behind the stock cam cover baffle plate.  It still feels really wrong shoving foam inside the engine but apparently its fine based on it pretty much being the MINES/Hi-Octane RB26 cam baffle kit and the few posts here I have found of people doing it and the lack of posts saying the foam broke down and ruined the motor... Still plan to check it frequently though lol The last step for this round of oil control modifications I plan to make is to add some -12AN fittings to the cam covers and connect them to some (already existing luckily) -12AN fittings on the sump. Basically a sudo head drain/sump breather/pressure equaliser without having to remove the motor and do the one on the rear of the head. My plan is to add them to either the tops or the sides of the cam covers at the back. unless there is a compelling reason to have them at the front on the sides which i have seen a few times though they were all on RB26 cam covers from memory so that may be due to the stock breathers being on the back and the integral baffle being different ?
    • from an old insurance company i was with (Budget Direct) I had someone roll back into me at the lights got them to pull over. Got a picture of thier licence with address, had a dash cam video and, thier phone number. But only had 3rd party on the shitbox i was driving. insurance did nothing, cops wouldn't do anything due to the value of the damage (under $3000) so i just had to suck it up and go to U Pull It.
    • Small Update on the Exhaust Situation A 200-cell cat was a bit too expensive for now, so I had the exhaust shop fabricate a new exhaust from the cat to the rear and an exhaust tip. I went this route to avoid cutting into the original exhaust and keep it intact. It’s essentially straight-piped, and the sound is noticeably different. The exhaust tip came with a silencer, so if it gets too loud, I can easily install it to tone things down slightly. Right now, the car bangs and pops like crazy -- which I personally love. In the future, I might add a resonator or a 200-cell cat, as niZmO_Man suggested, but for now, I’m really happy with how it turned out.
    • And that's a massive problem, because deadshits will deadshit and give you false details. At least in these days of mobile cameraphones, it is trivial to take photos of any ID they are carrying at the same time as the 300 photo extensive documentation of the state of the vehicles that I recommend even for minor incidents. And you get photos of the person's face, any visible tatoos, etc etc, while you're at it. Then you try to avoid mentioning that you're fully capable of making explosives of various power levels and will wreck their shit if you are forced to hunt them down.
